Question about Dell Computers & Internet
LAPTOP RESTART AUTOMATICALLY
Using "VISTA ULTIMATE", going to restart automatically and before restart showing "DUMPING SYSTEM FILES"..........what to do.
  • 535 Answers
Try to on your windows in safe mode by pressing F8 key when u swith on your laptop befor booting prosses u have press F8 key then u get servel option ther there is 1st option is safe mode select his option and press enter when your pc will be on in safe mode its take 10 to 15 min taking to load windows when u load or on in safe mode then u reset your PC then on it in a normal mode
Posted on Nov 14, 2009
I was using winXp & vista before win 7 ultimate, now when i am going to install bluetooth driver the massage is bluetooth device not found. please give me solution soon
first attach the Bluetooth to the computer and restart the computer when it shows new hardware found so it automatically scan for driver from system If it found the drivers already in the windows so it run you device if it not found the driver so it ask form you to install the drivers and if is not showing any hardware so go to the control panel and click on add hardware
Aug 04, 2011 | Computers & Internet
Automatic restart my laptop.Windows vista
If you are able to boot the computer in safe mode, you can disable the Automatic Restart from the Control Panel.
Open Control Panel.
Click on the System and Maintenance link.
If you're viewing the Classic View of Control Panel, you won't see this link.
Click on the System link.
In the task pane on the left, click the Advanced system settings link.
Locate the Start up and Recovery area and click on the Settings button.
In the Start up and Recovery window, locate and uncheck the check box next to Automatically restart.
Click OK in the Start up and Recovery window.
Click OK in the System Properties window.
You can now close the System window.
From now on, when a problem causes a BSOD or another major error that halts the system, the PC will not automatically reboot. Rebooting manually will be necessary.
If you're unable to fully start Windows Vista due to a Blue Screen of Death error, you won't be able to disable the automatic restart on system failure option as described in the steps above.
Try the steps below:
Just before the Windows Vista splash screen shown above appears, or just before your PC automatically restarts, press the F8 key to enter Advanced Boot Options.
You should now see the Advanced Boot Options screen.
Using the arrow keys on your keyboard, highlight Disable automatic restart on system failure and press the Enter key.
After disabling the automatic restart on system failure option, Windows Vista might continue to load. Whether or not it does depends on what kind of Blue Screen of Death or other problem Windows Vista is experiencing.
Since you disabled the automatic restart on system failure, Windows Vista will no longer force a restart when it encounters a Blue Screen of Death.
Now that you have the STOP Code associated with the Blue Screen of Death, you can troubleshoot the problem:
The following is the list of BSOD error codes with troubleshooting, you can find the troubleshooting steps using the error codes in the MS website also..
http://pcsupport.about.com/od/findbyerrormessage/tp/stop_error_list.htm
Hope this helped you. Please do rate me.
Thanks!!!!
Dec 21, 2010 | Computers & Internet
I am getting an error everytime after 5 minutes, w...
Could you please provide me the exact error message?
However to stop the system shutdown first follow these steps.
Disable automatic system restart.
1. Restart the computer and press the f8 key to open the Advanced Boot Options menu.
2. Select the Disable automatic restart on system failure option.
3. Restart the computer to accept this change.
Then go to safe mode
This problem occurs after a memory dump file (error log file) is written by Windows XP. Because the memory dump file flag not reset in Windows XP the memory dump file will contiue to be written every time Windows is restarted.
1. Restart the computer and immediately press f8 repeatedly. Use the arrow keys to select Safe Mode and then press enter .
2. Click Start , right-click Computer , and then select Properties .
3. Click Advanced system settings , grant permission to continue if prompted, and then click the Advanced tab.
4. On the Advanced tab, click Settings
  1. In the Virtual Memory section, click Change .
  2. For Paging file size for selected drive, click No Paging File , and then click Set .
  3. Click Yes after the following warning appears:
If the paging file on volume X: has an initial size of less than xx megabytes, then the system may not be able to create a debugging information file if a STOP error occurs. Continue anyway?
(X is the drive letter and xx is the amount of RAM installed on your computer minus 1 megabyte.)
  1. Click System Managed Size .
  2. Click OK four times to return to the Windows Desktop Screen and then restart.
For more information plz check the below doc from HP.
I hope this will definitely resolve your issue.
If not plz get back with the exact error message so I can give you better solution on this.
If you find this helpful then Plz vote for me..Dreamkam
May 21, 2010 | HP Pavilion dv6000z Notebook
The Fix is updated drivers, or reverting to windows XP
Nov 14, 2009 | Computers & Internet
Starting vista problems
Bad sector in your HDD. Break all partition, install vista again, make partitions with disk management utility or partitionmagic. Compare your present disk amount with actual capacity.
You have no problem with your servicepack or update. Keep informing.
Feb 23, 2009 | Microsoft Windows Vista Ultimate Edition
My p.c automatically restarts
This happens when knowingly or unknowingly an memory that is not to be accessed is accessed or a electrical violation of a port of the computer occurs...
Nov 12, 2008 | Microsoft Windows Vista Ultimate Edition
Pc restarts automatically and unexpectedly
Good Evening Sunnyseber :
Hope that you are wellJ
You did not indicate the type of Operating System.
This document pertains to HP and Compaq computers with Windows Vista. If Windows Vista suddenly starts without warning, or restarts when you try to shut it down, it may be because your operating system is set to automatically restart when certain system errors occur. This feature of the Windows Vista operating system can be disabled. Use the information below to disable the Automatically Restart option. NOTE: In addition to the steps in this article, updating video card drivers is known to resolve many of the problems that can cause the computer to restart. Step 1: Disabling Automatically restart option to view error messages You can prevent the computer from restarting by turning off the Automatically Restart option:
  1. Click Start c00971562.gif .
  2. Right-click Computer , and click Properties
  3. Click Advanced system settings .
  4. Click the Advanced tab and select Settings in the Startup and Recovery section.
  5. Remove the check mark next to Automatically restart under System Failure .
  6. Click OK to close the Startup and Recovery window and click OK , again, and then close the System Properties window.
  7. Restart the computer. NOTE: The computer will no longer restart automatically when a problem occurs. Instead a blue screen appears with more useful information. You can now search for a resolution using the text from the error.
If I can be of further assistance, please let me know.
And, remember, always include the type of Operating System and the type of computer you own, when you submit your questions. It simply makes for much faster solutions.
Have a wonderful evening.
Sep 30, 2008 | HP Pavilion a1410n (ER890AA) PC Desktop
My laptop vista
Have you tried powering down the laptop, and rebooting with your recovery disk in the drive? If that doesn't work, try rebooting again with an external keyboard attached. If the external keyboard works, then it's not your OS.
Nov 09, 2007 | Microsoft Windows Vista Ultimate Edition
Computers & Internet Logo
37 people viewed this question
Alun Cox
