I fprgot my phone code.I want to decode my Nokia 1661-2 RH-122, Please give me the solution.
I want the unlock code of nokia 1661-2 which imel no-356940/03/025142/2
I forgot my security code. i already used mastercode but it didn't work.
IMEI: 355221036175407
MODEL: 1661-2
TYPE: RH-122
Nokia 1661-2 unlock security code nomber forgoten
Just go to this site
unlock.nokiafree.org
but simply you find ur IMEI first, then your location and you`ll got solution.
izulthea.com
I also forgot security code, it would be really appreciable if someone provides a solution:
IMEI: 358269038030358
Model: 1661-2 (V 04.30)
Type: RH-122
Code
Hallo pls i want to decode my phone.
Help mee securiti code ime:358286039712750 model:1661-2 code:0575843 type:rh-122 plsss:(
IMEI: 012146006188251
MODEL: 1661-2
TYPE: RH-122
SOURCE: how to open security code in my nokia 1661
dear it is very easy to open the security code if you have not changed the code ...by default code is 12345.if this code have been changed then only one solution then renew the software.ok.
SOURCE: security code for a nokia 1661
When you power up the phone if it asks for a security code, power it down and up 2 or 3 more times, then enter 12345 which is the default security code. I don't know why you need to cycle the power several times but without doing this, the default security code often doesn't work. I hope this helps you out.
SOURCE: i cannot unlock my nokia 1661 security code
Try putting in the PUK code given to you when you purchased the sim card for your phone
