Question about ASUS P4PE2-X Motherboard
ASUS P4P2E-X 1 long beep that continue without end
1 long beep that continue without end and there is no signal detected by monitor.
No problem with others hardware. I have tested all of them it in another P4P2E-X. PSU is fine, GPU is fine, PROCESSOR and FAN is fine, MEMORY is fine, HARD DRIVE is fine, CONNECTOR is fine.
Before it hang, the system boot abnormally, turn on, turn off, and turn on again but not reach OS, it just freeze at BIOS POST, next time I turn it on it won't boot at all and the monitor doesn't detect signal but CPU and other devices turn on.
My full specs is :
- Pentium 4, 2.4 Ghz Prescott
- ASUS P4PE2-X
- 512 MB DDR 400 PC 3200
- ATI Radeon 9500
- WESTERN DIGITAL 160 GB
- 450W PSU
  • 81 Answers
I think One long beep that continue means RAM problem , Ram Can May be dead or faulty, check on other ram.
I hope that this has been very helpful for you
Posted on Nov 16, 2009
1 long beep and then 3 short beeps
Hello here is the homepage:
http://support.asus.com/Download.aspx?SLanguage=en&m=P5KPL-AM%20SE&p=1&s=22
Here is a list of beep codes:
http://www.computerhope.com/beep.htm
It seems to be a graphic card problem, or the power supply not giveing enoug power.
Try to change the graphic card.
If you are useing the onboard graphic, look for bad caps on the mainboard:
If they look like this, the mainboard is dead.
Good luck
Feb 16, 2013 | ASUS P5KPL-AM SE Motherboard
No signal on monitor, vga tested and ok
Did you check your monitor with other system or individually. If it works fine in these conditions then the issue belongs to your pc.
First of all, you have to confirm that is it the problem of VGA itself or the motherboard. For this, you have to see that does system beep when you start it because system with beeps having the error and the beep sound with continuous or 2-3 beeps relate with different issues. I am going to write down the beep conditions.
1 short beep Normal POST - system is ok 2 short beeps POST Error - error code shown on screen No beep Power supply or system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem 1 long, 1 short beep System board problem 1 long, 2 short beeps Display adapter problem (MDA, CGA) 1 long, 3 short beeps Enhanced Graphics Adapter (EGA) 3 long beeps 3270 keyboard card
Mar 11, 2012 | Computers & Internet
I installed the 3ngt430 into my pc, and when I turned it on it just started beeping and wouldn't start. After I removed the card it still won't start and continues to beep constantly without...
the beeps are post during post the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active untill turned off.
make sure that your RAM and Cmos battery are securely seated
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty
a computer needs its connections to continue its cycle and to have and end to function
the beeps are post pre operating system searching for some hardware it could be RAM cd/dvd hard drive or motherboard all of these must have secure connections for the computer to work
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure make sure the connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
hope this helps
Jun 18, 2011 | ASUS ENGT430/DI/1GD3(LP) GeForce GT 430...
Monitor says no signal when i take the caBLE OUT IT SAYS NO CABLE ALSO THERE is an alarm on
if the alarm are beeps
make sure that your RAM is securely seated
Test the PSU if the units fan is not working the power supply unit is faulty
Test all leads that attach to your hard drive including electrical extensions IDE,SATA
the leads from your "((motherboard to your hard drive))" make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error If your computer came with a motherboard disc the drivers could be on it or you might have a dirty graphics card remove the graphics card and clean the socket
hope this helps
Jun 12, 2011 | ASUS P4S8X-MX Motherboard
I have an Asus mozart 2 asm58 motherboard. When i connect the motherboard to the power supply nothing shows on the monitor. The alarm beeps continuously. Thanx Marius
obvisously the beeps are windows searching for some hardware it could be RAM cd/dvd hard drive or motherboard all of these must have secure connections for the computer to work
hope this helps
Jun 11, 2011 | Computers & Internet
Asus led monitor model vh197 shows no signal on screen and no display ,screen became dark
Good Day Dasarathi!
Please check the VGA cable if its properly connected and make sure two screws are fixed to both end connecting the monitor and the video card.
No signal comes out when there is no signal from the video card to the monitor. That is why you need to check if the VGA cable is fix to both end.
If that did not fix it, you will need to open the casing of your computer. Disconnect the video card from the motherboard. Gently clean by wiping a clean clothe over the contact surface of the video card. Then, reseat the video card properly to the slot in the motherboard. Return the casing cover and connect the VGA cable again.
Just remember doing the above procedure is only when the computer is turn off.
Turn on your PC and see if that fix it.
You will need to replace the video card if by booting the PC you will hear a series of beep codes. If no beeps then you are lucky VGA cable is the faulty one.
Jun 09, 2011 | ASUS Computers & Internet
No output to monitor. Monitor tested with good PC and is OK. No alarm beep code
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive boot up
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
one bad lead will end with a computer error
hope this will help
Mar 27, 2011 | ASUS P5GC-MX/1333 Motherboard
I removed the Asus fan to clean the dust from the fan and inner computer. I am worried that I have somehow damaged the pins from the fan and inserting it back to startup computer. It seems to start...
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error hope this helps
don
Feb 20, 2011 | Computers & Internet
Motherboard will not POST, no signal sent to monitor. Tried without RAM, without drives, without graphics card...
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
don
Feb 15, 2011 | Computers & Internet
Turn it on it beeps cdc
You really aren't giving much info, so here are some beep - codes, also make sure nothing came loose on the motherboard or other components ( do this ONLY if you know how ) Safety first.
BIOS Beep Sound core list
AWARD BIOS
1 short(Beep) System booting is normally.
2 short(Beep) CMOS setting error
1 long - 1 short(Beep) DRAM ERROR
1 long - 2 short(Beep) Display card or monitor connected error
1 long - 3 short(Beep) Keyboard Error
1 long - 9 short(Beep) ROM Error
Long(Beep) continuous DRAM hasn't inset correctly.
Short(Beep) continuous POWER supply has problem.
AMI BIOS
1 short(Beep) DRAM Flash Error
2 short(Beep) DRAM ECC Check Error
3 short(Beep) DRAM Detect Fail
5 short(Beep) CPU Error
6 short(Beep) Keyboard Error
8 short(Beep) Display card memory Error
1 long - 3 short(Beep) DRAM Damage
1 long - 8 short(Beep) Display card or monitor connected error
Jul 16, 2009 | E-Machines T6520 PC Desktop
ASUS P4PE2-X Motherboard Logo
820 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
