Question about Toshiba 50H82 50" Rear Projection Television
The picture doesn't fit the screen. It appears as if I am looking at everything through a convex lens, and the corners of the picture are being pulled away from me. It warms up, and flicks to the picture fitting the screen. The corners appear to be drawn away as if it was viewed through a lens.
    Genius:
  • Toshiba Master
  • 1,039 Answers
Bad solder connections on the convergence ic. Resolder them to store to normal operstion. If this does not fix then replace the ics.
Posted on Dec 05, 2009
Can anyone identify this PC Wallpaper
that's probably that your wallpaper isn't fit with your monitor resolution,for example,if your wallpaper size is 1280x1024 but your screen resolution (size) is 1024x768,it doesn't fit your screen and the wallpaper will only show half or even less
to check your current resolution,click
Start->Control Panel->click Appearance and Personalization->Click "adjust screen resolution" on the Display categories
you can see your current resolution and also you can set your resolution
To check the picture resolution,right click on the picture,select properties,click the Summary tab,and it doesn't show the resolution, click Advanced on the Summary tab
But I suggest you to download the wallpaper with a fit size instead of changing the screen resolution,because too high resolution will make your screen goes black
geez,i'm so sorry for my poor english
please rate this solution if it's work and let me know if you still has a problem.and thanks for using Fixya!
Aug 28, 2012 | Toshiba Computers & Internet
How can I change the screen to wide when it doesn't appears in the Picture menu?
first pull off powersuply and out it back in,then set up wizard will start.
after you set your your connection comes picture wizard.there you choose in the right below corner sreen you want.after that you ger page to see from all your settings and your done.
Jul 26, 2012 | LG 42LC2D 42 in. LCD HDTV
My D80 fell from a foot n half above the ground level well packed in a good quality carry case few days back.uv filter attached to 18-135 Nikor lens cracked & lens cap was jammed. After carefully...
Hi, allow me to suggest using another lens to see if you still see the dark patches in the top corners. If not it is the lens, if so it is the camera. Either way it sounds as though something is maladjusted. Call Nikon digital 1-800-645-6689.
May 14, 2010 | Nikon D80 Digital Camera with 18-135mm...
Nikon Coolpix p80 blacked out, rounded corners
Have you attached some sort of lens shade to the front of the lens? The vibration might have something to do with the shake reduction system but I can't be sure. It certainly shouldn't vibrate heavily. You might get a better answer if you e-mail the tech guys at the support section of the Nikon website.
Feb 19, 2010 | Nikon COOLPIX P80 Digital Camera
Canon Power Shot S1 IS
canon has a recall on this camera. call them and they will send you a box to send it back. If you are one of the lucky ones the will send you a canon s5is back...really nice camera
Oct 29, 2008 | Canon Power-shot S1 IS Lens Converter
Hd52w59 convex looking picture
If you do not see convergence in menu then you have open fuse FL231
Aug 28, 2008 | RCA D52W19 52" Rear Projection Television
Patch of purple "scribble" lines on corner of screen
This is a common problem on a faulty Mainboard of a Projector.
Not much you can do about it except repair or replace the Mainboard
Aug 01, 2008 | Sony VPL HS10 Multimedia Projector
E 18 problem
the E18 means the lens system has a problem. I had it with my S2 and sometimes it worked, sometimes not. Eventually it stopped working. The only solution was sending it to repair, they changed the lens system.
Best Regards
Nov 19, 2007 | Canon PowerShot S2 IS Digital Camera
The picture is convexed,or hour glass.
Sounds like problem in B+ voltage line to horizontal output transistor. Possible bad filter capacitor or leaky diode in power supply.
Dec 22, 2006 | RCA F32672SB 32" TV
Sony kv-32hv600 picture problems
Problem 1. Color patches at lower corners. These are caused by magnetic sources close to the TV. Do you have any Speakers close to the sides of the TV? Are they Magnetically sheilded? No? Move them away from the TV. Problem should then resolve itself in a couple of days. Problem2. Screen Slumping. Most likely a problem with the Pin cushion correction ckts. Get a good technician to have look. cost should not be much. Under 100$ plus Technician fees.
Aug 18, 2006 | Sony FD Trinitron KV-32HV600 32" TV
Toshiba 50H82 50" Rear Projection Television Logo
152 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
