Question about Cameras
The message on the screen of my camera says CARD PROTECTED .i cannot take photos or delete any . Also the memory card will not come out of slot
    Brigadier General:
  • 11,967 Answers
Card protected usually means the slide switch on the side of the card is in the locked position. To get the card out of most cameras (since you didn't say what your camera is) you press in on the card and it pops out. Sometimes there is a button alongside the card slot that you push in to get the card to pop out.
Posted on Nov 14, 2009
How to unlock a photo in camara
The protect function allows a user to protect a picture from accidental deletion. To unprotect a picture on your camera, scroll to the protected picture that you want to delete, then press the Menu button (the button to the right of the Play button.) Scroll down the menu and you should come to an option that allows you to Protect/Unprotect the picture. Since your picture is currently protected, deselect that option. You should then be able to delete the picture normally.
Alternatively, you could also format the memory card, however this deletes ALL photos and data you have on the memory card. If you are trying to completely clear the memory, this is the best way. After turning on your camera, simply press the Menu button, scroll to Setup, then scroll down to Format. Select Format, it will ask you if you want to format the memory card, or the camera's built-in memory. Format whichever one you want to clear, if you are using a memory card then your pictures are stored on the memory card. It will take a few seconds to format.
Hope this helps.
Dec 05, 2012 | Kodak EasyShare M1033 Digital Camera
How do I transfer photo's from my PC to the memory card in my Panasonic DMC-TZ8
The photo processing shop most likely will have trouble downloading the photos from your camera/memory card.
I suggest you purchase an USB memory stick and copy the photos to this USB memory stick and then take the USB memory stick to the photo processing shop.
Jun 17, 2012 | Panasonic Lumix DMC-ZS5 / DMC-TZ8 Digital...
I have a panasonic lumix camera and there are a selection of photos which i want to delete. When i try to delete them there is a message saying 'this photo can not be deleted'. These photos are not...
Maybe you just lock the memory card of your camera. Take the card and unlock the lock of you memory card, simlpy slide the button according to the icon display. Then Plug it again to your camera and repeat the steps you made.
Aug 25, 2011 | Cameras
I have a vivitar camera from a friend and she took her memory card out then i bought my own brand new memory card with nothing on it and new batteries too. then when i try and take a picture it says memory...
From the manual:
http://static.infoteldistributors.com/pdf/VC8025%20User%20Manual.pdf
Installing SD Memory Card
Your camera has a memory card slot that enables you to insert any "SD" compatible memory card up to 8BG. Adding a memory card will allow you to increase the capacity of your camera before you have to transfer photos and videos to your PC. Install the SD memory card as below:
  1. Locate the Memory Card slot within the battery compartment.
  2. Insert the Memory card into the slot in the correct direction. (see the sketch below)
7
  1. Push the card in until you feel it "click" into position. The top of the card should be flushed with the surface of the camera. An icon will appear on the LCD screen after you turn on your camera.
  2. Once the external memory card is inserted into the camera all the images taken with the camera will be stored on the card.
Note:
  1. Limited internal memory is provided for test images. The image will be deleted when camera power is turned off. Please download the images before power off .SD memory card is required for normal use.
  2. An external memory card is required for normal use. Your camera supports any compatible SD memory card (up to 8GB).
  3. If there is a photo in the internal memory when you insert the card into your camera, a "Copy to card" message will appear on the LCD with Yes or No options. On selecting 'Yes' the photo will now be copied to your card.
  4. Formatting will delete all data on the SD memory card including protected data.
8
  1. Don't remove the SD card during formatting as this may damage the card and render it unusable.
  2. When your card is full, download the media on the SD card to your PC and delete the photos and videos from it in order to continue using your
Dec 24, 2010 | Vivitar ViviCam 8025 Digital Camera
I can't delete photos off my ScanDisc stick unless I manually do them individually, nor can I upload photos from my computer ONTO my camera. I get a "write-protected" message. How do I undo the write...
First of all, you're not supposed to upload from the computer to the camera. You risk corrupting the card and camera. If you want to delete all the pics from the memory card, just insert the card into the camera, go into the menu and find "format" and follow the on-screen instructions.
Jul 21, 2010 | Canon PowerShot A540 Digital Camera
Memory card is locked, how do I unlock this?
Problems typically are pretty rare with Panasonic Lumix digital cameras. On those occasions where you do have an issue, though, look for an error message on the Panasonic camera for some clues as to how to fix the problem.
he seven tips listed here should help you troubleshoot your Panasonic camera error messages.
  1. Built-in Memory Error error message. If you see this error message with your Panasonic camera, the internal memory area of the camera is either full or corrupted. Try downloading photos from the internal memory. If the error message continues to appear, you may need to format the internal memory area.
  2. Memory Card Locked / Memory Card error message. Both of these error messages are related to the memory card, rather than the Panasonic camera. If you have an SD memory card, check the write protect switch on the side of the card. Slide the switch up to unlock the card. If the error message persists, it's possible the memory card is corrupted and needs to be formatted. It's also possible the memory card was formatted using another device that is not compatible with Panasonic's file structure system. Format the card with your Panasonic camera to fix the problem ... but keep in mind that formatting the card will erase any photos stored on it.
  3. No Additional Selections Can Be Made error message. If your Panasonic camera allows you to "save" photos as your "favorites," you may find this error message because the camera has a limited number of photos that can be labeled as favorites, usually 999 photos. You cannot mark another photo as a favorite until you remove the favorite label from one or more photos. This error message also may occur if you're trying to delete more than 999 photos at one time.
  4. No Valid Picture error message. This error message typically refers to a problem with the memory card. Most of the time, you'll find this error message when you try to play back images from the memory card and the memory card is corrupted, empty, broken, or has been formatted with another camera. To fix the memory card, you must format it, but formatting a memory card causes all photos stored on it to be lost. Try inserting the memory card in another device or in your computer and try downloading any photos stored on it before formatting it with your Panasonic camera.
  5. Please Turn Camera Off And Then On Again error message. At least this error message says "please." This error message most likely occurs when one of the parts of the camera's hardware is malfunctioning, usually a jammed lens housing. To try to fix this problem, start by turning the camera off for a few seconds before turning it back on. If this doesn't fix the problem, try resetting the camera by removing the battery and memory card from the camera for at least 10 minutes. Replace both items and then try turning the camera on again. If the lens housing is jamming as the lens moves through its zoom range, try gently cleaning the housing, removing any debris or grime. If all of these steps don't fix the problem, you'll probably need a repair center for the camera.
  6. This Battery Cannot Be Used error message. With this error message, you've either inserted a battery that's incompatible with your Panasonic camera or you've inserted a battery that has dirty contacts. Gently clean the metal contacts with a dry cloth. In addition, make sure the battery housing is free of debris. You sometimes may see this error message if you're using a battery that's not manufactured by Panasonic. If the third-party battery is working OK to power the camera, you probably can ignore this error message.
  7. This Picture Is Protected error message. You'll see this Panasonic camera error message when the photo you've selected has been protected from deletion. Try working through the camera's menus to figure out how to remove any protection labels for the photo files.
Keep in mind that different models of Lumix cameras may provide a different set of error messages than is shown here. If you are seeing Panasonic camera error messages that aren't listed here, check with the user guide for your model of Panasonic Lumix camera for a list of other error messages, or visit the Support area of the Panasonic Web site.
Jul 11, 2010 | Panasonic Cameras
I cannot delete photos from my panasonic lumix FS5 camera via the PC like other cameras in my office. I get an error message stating it is not possible because of right protected - I have tried moving the...
To delete all or just one of the pics on the memory card -- go to the play mode and use the Q Menu on the very bottom right -- you can select your choice from there.
In play you can also go to Menu and Protection and select if you want all or one photo protected.
Hope that helps!
Took me a while to figure it out!
Nov 12, 2009 | Panasonic Lumix DMC-FX33A Digital Camera
Memory card is protected
Move the slide switch on the side of the memory card to the unlocked position.
Oct 02, 2009 | Kodak EasyShare M1033 Digital Camera
Cannot delete photos" Card Protected" appears on screen
There should be a small switch on the memory card that allows users to lock it so no one can delete pictures on it. Take the memory card out of the camera and look for this switch on the card and make sure it is not in the locked position.
May 19, 2009 | Sakar 87492 Digital Camera
Card stuck on lock
There is a switch on the memory card, you just have to slide it upward.
Nov 25, 2007 | Samsung Digimax S630 Digital Camera
Cameras Logo
144 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
