Question about Car Audio & Video
Hello. I have lost the 10 plugs connector behind my old PIONEER DEH-670, so I am unable to connect it without mistakes concerning the different colors of the wires... Please, can you help me by giving the identification of each plug? Thanks a lot.
  • michelpiotel Nov 14, 2009
    Thank you very much for your advice and for the technical solution you propose to me.
    Normally, I think I am now able to solve my problem.
    Greetings.
    President:
  • 1,462 Answers
If you lost the 10Pin connector of your Pioneer DEH-670 car streo system, you can buy a new replacement connector from the following link...
http://www.nexxia.co.uk/Car_stereo_spares/Head_unit_extractor_keys.htm
You can get all the accessories for all the brand from the following link..
If you manuall y connect using the color code, the movement during the car locomotion makes the power connector to short, leading to damage to entire system...So for the best performance and for the safety of the system, i recommend you to buy a new 10pin connector from the following link..
You can directly buy the lead for your DEH-670 from the followinf link
http://www.nexxia.co.uk/Car_stereo_spares/replacement_head_unit_leads/pioneer.htm
Please leave me comment, if you need further assistance
Thanks for using FixYa!
Rnj VINODKUMAR
Posted on Nov 14, 2009
I need the wiring/harness diagram for pioneer deh-1100mp
Order a new one. It is difficult at best to connect wires to the pins without getting a short. New ones are cheap and available from a bunch of places.
Aug 26, 2016 | Pioneer DEH-1100MP Car Audio Player, CD-RW...
Hello, I have an odd problem with my Pioneer DEH-P9800BT Screen
Clean all contacts chemically and check all wiring for good, tight connections.
Aug 25, 2017 | Pioneer DEH-P9800BT CD/MP3/WMA Player/Blue...
I have got a renault clio mk 2 98-01 its got the cassette play that came with the car so iam changing it for a pioneer 1400 when connect it it wont come on but when i plug the old one back in the player...
How are you wiring the Pioneer DEH 1400 to the Renault?
The Pioneer uses standard radio wiring, you must not have power and ground connected properly if you have nothing happening.
Jan 03, 2018 | Pioneer Deh-1400ub Car Stereo Cd Mp3 Wma...
I'm trying to install a pioneer DEH-64BT radio in
Check the ariel fuse with the power supply (+Ve) wire for open. If it found OK, measure the main voltage that come to that fuse carrier. You must have knoledge to use a multimeter. If fuse is found blown up, do understand that, there is some wiring mistake, caused a short circuit.
Chekc the wirings once again and replace the fuse only after that.
Feb 25, 2012 | Pioneer Car Audio & Video
Different cords
You will need to go to locate auto parts store and buy the adapter which will allow you to fit the stereo without any wiring modifications.
Jul 29, 2010 | Pioneer DEH3200UB w USB Input iPod...
Tring to install a pioneer deh-p2000 cd player in my 1994 volvo 850the speaker/power wiring is not the same
you must buy a wire harness connector from best buy or another dealer with knowlege and parts available / ps with this connector you just connect the wires from the radio to the connector following the color diagram and then snap on the connector to the car plug and it will work..
Jul 19, 2009 | Pioneer DEH-2000MP MP3 CD AM/FM Car Stereo...
Pioneer DEH-P3300 and 94 Mazda
Hello ryan_jaime,
It's good that you have an aftermarket Mazda wiring harness. It will allow you to make all of the connections in a well-lighted and comfortable location rather than fumbling around behind the dash.
If you are somewhat skilled at soldering, the most secure, electrically conductive, and positively insulated splices are made with solder and heat-shrink tubing. You can get the needed equipment from any Radio Shack, Lowe's or even WalMart. Be sure to put the heat-shrink tubing on the wires BEFORE you solder them together. I had to say that! Because I've forgotten many times! But if the soldering route is not for you, get properly sized insulated inline crimp splices and the appropriate crimping tool. Match up each wire by function on the Pioneer harness with the corresponding wire on your aftermarket harness. Most of the time, the wires will be color-for-color matched. But make sure, sometimes wires for things like "illumination", "dimmer", "mute", etc may not be the same colors.
Disconnect the negative battery terminal while you are working behind the dash. After you have the harnesses spliced together, plug the radio end into your Pioneer, remove the old radio from the dash opening, unplug the antenna and wiring harness plug and plug the other end of your spliced harnesses into the vehicle plug and the antenna plug into your Pioneer's antenna connector. Slide the Pioneer loosely into the opening, but don't secure it yet. Reconnect the negative battery cable and test the receiver. If everything works, slide it into the dash opening and secure it. Use the rear support stud and rubber bumper if needed. Install the trim ring or separately purchased dash kit as required. Put the "face-fixing" screws in to prevent removal of the faceplate if desired. Reinstall any dash trim removed and you're finished.
Hope this helps.
Jul 08, 2009 | Pioneer DEH-P3000 CD Player
I need help with wiring my deh-p5200
hey slickricky,
Try this site www.the12volts.com. They might have what your looking for...
Dec 03, 2007 | Pioneer DEH-P5200 CD Player
Car Audio & Video Logo
54 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
