The ac power adapter type cannot be determined,your system will operate slower and the bettery will not charge. please connect a dell 65w AC adapter or Higher for best system operation.
  • 557 Answers
Dell power supplies use 3 wires. One detects the power supply. If you are using a Dell supply then that wire is broken inside the cord or at the connection. If this a universal power supply it only has 2 wires.
Posted on Dec 20, 2009
When I connect charger with my laptop 30 sec show battery is charging after 30 sec one message show:- QuickSet The Ac power adapter type cannot be determined. your system will operate slower...
del recognition circuit may have failed in charger , or could be fine central pin on charger plug or laptop plug has broken connection,it is used to tell laptop that this is genuine dell charger.If you remove battery will laptop work off charger.if does then definitely one of the three problem possible . for first only soln try another dell charger first,often has to be one to suit your model ,common dell problem ,if then work and charge battery ,you will need to replace charger as recognition circuit failed. If either of last 2 can repair but need to pull apart repair broken connection ,or open up laptop and check power connection and repair connection . If you remove battery will laptop work off charger.if does the definately one of the three problem possible . for first only soln try another dell charger first,often has to be one to suit your model ,common dell problem ,if then work and charge battery ,you will need to replace charger as recognition circuit failed.
Oct 27, 2013 | Dell Inspiron 65W PA-12 1525 LAPTOP
Not charging
Sounds like the ID chip in the battery pack has gone bad. This is a common issue with dells.. Otherwise your looking at the sensing circuit of the motherboard. If you know someone else with the same power supply as you try there power supply and see if it works.. If you continue with the same issue then contact the reseller and look into warranty repairs.
Oct 27, 2013 | Computers & Internet
I have a DELL Vostro 1500 laptop, since the last 2 weeks it appeared a message when i turn on my laptop, it says: " The AC power adapter wattage and type cannot be determined. The battery...
Certain models talk to a chip in the adapter, sounds like this one has gone bad. At this point you can live with, buy a new one or pick up a used. This is a fairly popular model and you should be able to locate one from a dead laptop.
Mar 06, 2017 | Dell Vostro 1500 Notebook
I get the following message when I try to charge the battery on my dell vostro 1500. "The AC power adapter type cannot be determined. Your system will operate slower and the battery will not charge. Please...
Hi, Sounds like the charging circuilty is starting to fail,
Check the connection from the power lead to the DC input , is it tight ?or is there a lot of play ? if so bad connection ?
if it still under warranty, get it looked at before it stops charging completey.
Lastly , is it possible to try another charger ? make sure it the correct voltage and amps. The charger could be going down.
Regards
GeWiz.
Dec 10, 2009 | Dell Vostro 1500 Notebook
Post Boot message for my Dell Inspiron 1521 laptop. Message: The AC power adapter wattage and type cannot be determind. Please connect a Dell 65W AC adapter or greater for best system performance. To...
When you received the system as out of the box and you get this message "The AC power adapter wattage and type cannot be determind" let the Dell tech service know that they sent you a wrong or incorrect type of AC Adapter.
If this message not was not appearing before it just happened recently try to download and install the latest BIOS version from the support site.
If all fails remove the batt and check if laptop can work with AC adapter alone, because issues like AC not determine may not charge the battery and laptop may not work with AC as well, maybe laptop is already running on battery power.
Nov 11, 2009 | Dell Inspiron 1521 Laptop
Battery Not Charging
Sounds like the power supply has gone bad. You should get a new power supply. You will get this message when he power supply goes bad
Feb 12, 2009 | Dell Inspiron 640m PC Notebook
Televison & Video Logo
164 people viewed this question
Top Televison & Video Experts
Electro Med Services...
