Question about LG KC910 Renoir Cell Phone
Hi, i am not able to install prog's like google
Hi,on my LG Renoir i am not able to install prog's like google maps, messenger etc
any ideas
Can GPS be instaled in LG KC 910?
yes u can
You'll need to pre-install maps onto it first. Be aware that you should do this at a PC, then use the USB connection to copy them across to avoid costly data charges.
In terms of charges for GPS the Renoir has 2 settings - Stand alone GPS and AGPS (assisted GPS). Basically, stand alone works exactly like a Tom Tom - link is made directly to GPS satellites with no data charges but it takes time to link up and refresh details.
AGPS uses your network's towers to link directly with GPS satalites through your mobile network. It differs from network to network but you will incur data charges using it this way. I'd recommend a data bolt on if you plan on using AGPS as it can be pricey.
To switch between modes, go to Settings, Connectivity, GPS type and select the one you want to use.
In terms of map software, you're best off googling Java GPS applications - Way Finder is good and Google maps isn't too bad either, but it all comes down to personal preference.
Sep 13, 2010 | LG KC910 Renoir Cell Phone
How to get free gps on virgins lg renoir
gps is a hardware. if you have it you have , if you dont you dont. However, you can download and install google maps ver3.0 orabove from either www.maps.google.com or from www.getjar.com and subscribe to Latitude, a free facility from google along with maps. You will not only be able to get your approximate location thru your service providers communication towers, but also be able toshow your own approximate location on yout site or on other's phones who also use google maps.
Aug 31, 2009 | Cell Phones
I want to know how to use GPS in LG KC910...
you can use trekbuddy application instead of google maps , also you can use atlas map creator to create maps fro trekbuddy
May 11, 2009 | LG KC910 Renoir Cell Phone
How do i get the gps maps on my LG KC910
you do it using WAP via your mobile. go to the google mobile map web site and enter the link into your mobile browser and install from there.
Apr 18, 2009 | LG KC910 Renoir Cell Phone
Gps maps
try going to http://www.amazegps.com I installed it and it wasnt too bad, best improvement on the google maps, just be a bit weary of if you get free web mins on your phone as it could cost you a bit!
Apr 07, 2009 | LG KC910 Renoir Cell Phone
Gps not initializing
Go to security < location< it should be on E911 only if it is, turn it to "location on"
Mar 19, 2009 | LG KC910 Renoir Cell Phone
How to use gps on lg kc910
hi, i dont think it has GPS as in Sat-nav kind of GPS. I think what it meant by GPS is that you can use sattelite signal for the jogging buddy application. However, if you want, you can download google maps which is pretty much the same, except you wont have the voiced directions.
You could also try typing "Java GPS applications" into google and download one of the softwares e.g Amazegps and see how it goes?
Hope that helped
http://stores.shop.ebay.co.uk/Sabka-Hosiery
Mar 09, 2009 | LG KC910 Renoir Cell Phone
LG Renoir software on Laptop problem
Where did u get your software from? is it the original software or an uopdate?
Feb 22, 2009 | LG KC910 Renoir Cell Phone
LG KC 910 Renoir how do I set up for GPS working
the gps on my renoir works fine with orange maps , couldnt get it to work for a while though but seemed to sort itself out, does take a fairly long time to get the positioning but once it found the satellites it worked no problem at all gave me directions to my house... havent used it since but it did take about maybe 15 minutes to find the signal u have to be patient
Jan 29, 2009 | LG KC910 Renoir Cell Phone
LG KC910 Renoir Cell Phone Logo
74 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
