Question about NComputing Nstation Ultra Thin Client Network Terminal
Machine get hung or very slow - NComputing Nstation Ultra Thin Client Network Terminal
  • 80 Answers
Cheaq server processing,if it gets 100% using memory increase RAM or try to change your antivirus
Posted on Nov 14, 2009
My mobility scooter keeps slowing down & nearly stops
Sandra,
There are many possible answers, we should narrow down the problem 1st. Make and Model of the scooter makes it easier to figure out your difficulties. Your brake maybe getting hung up and cause this if someone can check if the brake is getting hot when you slow down. That would mean your brake is the problem. If your batteries are loosing power and causing you to slow down that the batteries could be the issue. try my app to help you narrow down the problem. Scooter Doctor App
Jan 24, 2016 | Health & Beauty
Water pours out of machine from the door while filling with water.
Sounds like someone may have "hung" on the door whilst it was open, which bent the door or the hinge.
Some hardware stores or appliance stores sell a foam rubber strip with an adhesive backing, wherein you peel off the adhesive cover and stick it on the whatever you want.
Perhaps you could try a piece of sticky-backed foam stuck to the front of the machine or to the door to see if the water will slow down.
God bless your efforts.
Jan 01, 2016 | Maytag EPIC MFW9700S Front Load Washer
My Amana Front Loader sounds like a pachinko machine intermittently, and leaks water Idea's anyone?
you could have something hung up between the inner and outer tubs. A lot of times, a underwire out of a bra will get hung up between the tubs and can cause a hole in the outer tub. If the unit is over 5 years old and you have to replace the tubs, it's not worth fixing
Feb 26, 2015 | Amana 3.5 cu. ft. Front Load Washer
Very slow in everything,
Try:
Clearing out your hard drive, giving it more room or it could have a fatal failure as mine did or clear out your cache histroy in your broswer.
Feb 03, 2014 | Apple Computers & Internet
Updater hung
I have had this problem on two modern Dell laptops with 64-bit Win7 (issued by my workplace), and in both cases I used a slow AMD laptop (with 32-bit Windows) and that solved my problem. So try running the updater on a different machine. I have been unable to find a better solution. Maybe safe mode with networking would work? I haven't tried it, but think some driver might be interfering due to a high interrupt-rate.
Apr 19, 2012 | Jabra BIZ 2400 USB Bluetooth Headset
Fax is not answer ...
If the "Mode" was "Tx" or "Snd", you tried to send a fax, and the other fax machine did not answer, then it was either turned off, or out of paper or ink. If the mode was "Rx" or "Rcv", it means your fax machine tried to receive a fax, but none was sent. If your machine was in TEL/FAX or FAX mode and it received a regular call, the caller heard the fax tone and hung up. If your machine was in ANS/FAX or EXT.TAM mode, it most likely means a regular voice caller heard the answering machine and hung up without leaving a message.
Jul 06, 2011 | HP Officejet 4355 All-In-One InkJet...
Washing machine getting hung on a cycle
If the machine is 14 years old, it probably is time to replace it.
Jun 06, 2017 | KitchenAid KAWS850L Top Load Washer
A piece of clothing got hung up in the seal of our front loader washing machine. Now it leaks when in use and a round spring has come out from behind the seal.
you will need a new seal and the spring is what helps to balance the front of the drum , you will need to put it back on, trace down where it belongs,, should be a prong on the machine and another on the drum casing,
Jun 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
NComputing Nstation Ultra Thin Client Network Terminal Logo
255 people viewed this question
Top NComputing Computers & Internet Experts
Tom Chichester
Dan Shibata
Dan Shibata
Are you a NComputing Computer and Internet Expert? Answer questions, earn points and help others
