Question about Marshall MG10CD 10 Watt Combo Amplifier
I am trying to source a copy of the user manual for a Marshall MG10CD amplifier. Can you help?
  • Marshall Master
  • 5,603 Answers
MOST of these small amps are so SIMILAR to the competitors that you can get the users manual for one and use it for another. They are not as the saying goes, "rocket science".
That being said, try for instance the Fender Frontman manual. Here is a site for download:
http://www.manualnguide.com/download/manual-guide/fender-frontman-15g15r-users-manual.html
You will find that even the scematic diagrams are quite similar between the brands. Let's face it, they can't re-engineer much as there is little profit.
MOST of these amps use one of the TDA family of chip audio power amps.
Posted on Nov 15, 2009
Can I plug an ipod nano into my guitar amp, and if so what will I need?
The ipod is stereo and the Marshall is mono. You would need to "mix" the left and right channels of the ipod. You could use a simple passive mixer made of two resistors, one from each of the two channels from the IPOD to a single plug for the Marshall. Just joining the two channels without the resistors would have the IPOD outputs fighting each other. You can use 1 K ohm resistors. All parts are available at Radio Shack.
Apr 15, 2011 | Marshall MG10CD 10 Watt Combo Amplifier
Hi. I have a Marshal MG10CD amp. It was working fine, till a few days ago, when it suddenly stopped functioning. The amp gets power supply, as you can hear static when switched on, however, when the...
Check for a dry/cracked solder joint where the 1/4 inch phono input jack connects to the printed circuit board. Solid state Marshalls are renowned for this.
Feb 23, 2011 | Marshall MG10CD 10 Watt Combo Amplifier
When i press the distortion button, there is no sound. if i fiddle with it it gives sound, but i need to hold it in a certain position. clean works fine
Either the button is defective, or there may be bad soldering or a crack in the circuit board where it mounts. You will have to open the unit to repair it.
If you don't find a crack or bad soldering, try to spray a little CRC226 into the switch portion of the button. This is availablle at Home Depot in the electrical department.
Jan 03, 2011 | Marshall MG10CD 10 Watt Combo Amplifier
No volume amplifier
TRY CHANGING VOLE CONTROL BUTTON
Oct 07, 2010 | Marshall MG10CD 10 Watt Combo Amplifier
Want to take it apart
Usually there are screws, sometimes including those holding the handle that support the amp. Sometimes there are a couple from the sides... USUALLY the corner protector screws are not involved.
Hint, the amp is easier to handle and remove by setting on the side.
Jul 18, 2010 | Marshall MG10CD 10 Watt Combo Amplifier
Marshall mg10cd amp has no volume
Common causes:
Broken input jack.
Blown power amp chip due to overdriving.
Smashed pots due to tipping over or transportation damage.
Blown power supply due to bad power at a venue.
In some cases, grounding the headphone jack can blow amp.
Feb 11, 2010 | Marshall MG10CD 10 Watt Combo Amplifier
Hi im in Argentina and i accidentally pluged in my amp without an adapter now it doesnt work what needs to be fixd?
The power supply is blown. Argentina is 220V I believe. I have never seen a power supply schematic for this however being that it is low power it is a linear supply not switching. Either the rectifier diodes are blown out or possibly the output capacitors are blow due to approx double voltage. If you try this yourself be careful otherwise get a new amp. Good Luck
Dec 14, 2009 | Marshall MG10CD 10 Watt Combo Amplifier
Marshall MG10 cd guitar amp picks up radio frequency?
First of all I would call the radio station and let the know that there over modulating just a bit.this has happened to me a few times even on my tel/phone. I use to get WOKO on my amp. You can try and move the amp to diffrent location , reverce the polarty switch on the back , not much more you can do. But watch out when you here music comming from you toster your in big trouble, just kidding. Good luck DFD
Apr 13, 2009 | Marshall MG10CD 10 Watt Combo Amplifier
Marshall MG10CD 10 Watt Combo Amplifier Logo
244 people viewed this question
Top Marshall Music Experts
Michial Gueffroy
matt martin
matt martin
Leonard Jeffrey
Level 1 Expert
Are you a Marshall Music Expert? Answer questions, earn points and help others
