Question about FrancisFrancis! X1 - Stainless Steel Espresso Machine
Im not able to faund the resistance of boiler, can you give me one solution? a site where i can faund it
  • 1,089 Answers
HI
If you are using an ohms meter and you measure across the 2 terminals of the element and get no resistance your element is bad. You will only get resistance if the element is good.
Posted on Nov 14, 2009
I HAVE ERROR 189 ( TIME TOO LONG FOR HEAT UP BOILER ), CAN YOU HELP ME PLEASE ?
Sounds as though the boiler has lost the supply to the heating element, or the supply is low.. Check that the thermal fuse in series with the boiler heater is not open circuit (there may be more than one in series). If it is OK, check for continuity across the heater inputs - if that measures open circuit or very high resistance, the heater has failed.
Otherwise just backtrack along the wiring harness looking for the power supply to the boiler, there will be at least one relay (contactor) and switch. Make sure all are working correctly. You should be easily enough able to locate where the supply to the boiler's heating element is getting lost :o)
Nov 06, 2013 | WMF Coffee Makers & Espresso Machines
Hi. Had a code 10 on my Vokera UNICA HE boiler. This was due to the overflow pipe freezing up. The pipe has been disconnected from the boiler and the boiler pipe is now dripping into a bucket. However, the...
I had the same problem. There's another clear rubber pipe underneath, that runs from the front right to a pump in the middle. I had to pull it off and dry it with a hairdryer before mine would light properly. Blast into the hole the pipe came off too to dry the sensor if there is one.
Dec 20, 2010 | Water Heaters
My display says select beverage heating steam. I can pour shots of espresso but no steam or hot water will dispense
Heating Steam The steam boiler has fallen below set point... could be tripped hi -limit .. steam relay faulty
Oct 06, 2010 | Schaerer Siena Espresso Machine
Ive just had a new valiant 28 pro boiler
the faster the flow the low the temp , the slower the flow the hotter the temp
Feb 06, 2010 | Heating & Cooling
I have a gas boiler with 5 zone valves. The heat
The zone valve when there is a call for heat opens and the lever should give you no resistance. I am curious to know if other zones are heating ok. You could have a bad circulator or a frozen zone.
Jan 16, 2010 | Honeywell Electronic Programmable...
Boiler Venting.
There cannot be controlled venting of the flue , the products of combustion must have free flow to escape , The heat exchanger is above the burner which heats the water if you thinks this is high then maybe you a pressure problem . Or contact the makes tech line and ask them what they think the consumption might be for you heater .You may find this on google
Mar 22, 2017 | RTO W4 A.O Smith Gas Hot Water Heater...
2 green blinking lights
This is a cold boiler problem.
There are several reasons for a cold boiler...boiler element is open, no power to the boiler element, thermostat is not functioning properly, or it could even be a board problem not delivering voltage to the boiler.
First start by opening the top and reseating all connectors on the board, if this does not help then you will have to extract the insides of the machine from the case to get at any of the boiler and thermostat hardware.
Start by removing the 1 screw holding the inside workings to the outer case. This is located on the right top side of the machine beside the grinder.
Use great caution while pulling the guts out of the case and watch the dredge drawer switch does not hang-up on the case. Snake the power cord through the bottom of the case while pulling the inner workings out of the case.
There are 2 elements in the boiler check them both for a resistance (they will not be the same resistance) if either are open then then replace the boiler. Check the thermostat on the back of the boiler for resistance, if open or shorted, then replace. Check thermal breaker on boiler, this should be shorted if not, reset it by pressing the button in the center of the breaker.
If none of this works then you will have to depress dredge drawer switch front door switch and insert the brew group to depress the brew group switch, plug in the unit and turn it on.
Check for voltage on the elements on the boiler.
If no voltage then check all connections.
If you have gotten this far there is a good chance it is the board fault and it will need to be replaced.
Be shure to label all connections to the mother board as there are several connectors that can be placed in the wrong position while reassembling.
NOTE: This depth of trouble shooting should only be attemted if you are completely comfortable with electrical/electronic repair.
Mar 06, 2009 | Saeco Vienna De Luxe Espresso Machine
Webcam
you want to press mode, go to setup and language should be right there.
Jul 22, 2008 | Kaser Corporation Mambo Mano Digital Media...
FrancisFrancis! X1 - Stainless Steel Espresso Machine Logo
81 people viewed this question
Top FrancisFrancis! Coffee Makers & Espresso Machines Experts
dharmanos
Level 1 Expert
Joe Lalumia aka...
Joe Lalumia aka...
Jim Goldsmith
Jim Goldsmith
Are you a FrancisFrancis! Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
