I was working with sd tech steve for a few days on this..basically my mitsubishi ws-65869 went out & we were in the process of disconnecting the front keyboard so I can operate the tv by remote...that did not fix the problem so here is the last response from steve: If disconnecting the keyboard does not restore the set to operation---the receiver is bad---there are 4 or more caps and some pico fuses that can fail in that unit---Mitsubishi no longer sells or repairs these--if it is bad and not the caps there is a company you can send the unit to and have it repaired--if you need to know their name let me know...if you can forward to steve or if anyone else has the info please forward...thanks
  • 5,807 Answers
First of all , im not SD Tech , im here just to help you
if ever you need my assistance please post back or write an email
to experts@fixya .com that you would like his assistance. and have these premium canceled
if however you need my assistance you might be needing a complete
service manual to aid you troubleshoot, then repair the unit you are
having.
here is the link
https://www.completeservicemanuals.com/mitsubishi/crt-projection-television/ws-65869-service-manual/prod_125.html
you can also reply back to your former post.
you may need also to measure voltages on the unit just to troubleshoot
what part of the TV you are having problem with.
Posted on Nov 14, 2009
  • Rommel Cana
    Rommel Cana Nov 14, 2009
    to start with:
    there should be 5V on the red line on the image shown
    the voltages on pin 1 of the Remocon Preamp Unit should be having a fluctuating downward voltage from 5V everytime you press any button on your remote control.
    if it does it means your IR receiver unit and your remote transmitter is partially working.
    you can also test your remote control if it is really working by using AM radio and pressing any button just to test your remote is working.
    we need to do this cause you mentioned you disabled the front controls.
    you can also use an auxiliary power supply just to test if the 5V line is OK.
  • Rommel Cana
    this is the image
Mitsubishi 65" WS-65869 Blinking Green Light 3-2 pattern,
two ideas:
Make sure you tested the pico fuses inside the unit with the caps==two or three of them.
Also from front of set behind speaker grill unplug both plugs that go up to front keyboard--set will still work with remote===if set functions now then the reset micro switch is bad/damaged.
Mar 12, 2012 | Mitsubishi WS-65869 65" Rear Projection...
Picture is completely out of alignment, went to do
It means the convergence IC gave up already ang needs a replacement. And also check the 5A picofuse in the power supply.
Dec 28, 2009 | Mitsubishi WS-65869 65" Rear Projection...
Picture is bowing at top and bottom also has shadows and has converance problems and lines on tv be red and white
ws-65869?
This model uses a single convergence IC chip----
STK-393-110.
The chip needs to be replaced and there are about a dozen light blue resistors in front of it that need to be checked also.
Considering you can buy the part on Ebay for about 12 dollars plus shipping---if you or someone you know can do it for you, you can save the set and a lot of money.
I have done hundreds of these repairs and I have had so many people here asking that I composed step by step-----start to finish instructions for this repair in this set----
The instructions tell you everything you will need to do the repair and are detailed.
I just today received a comment from someone who got the instructions tell me the repair went perfect and he now has a working TV again for a fraction of what a shop wanted to repair it.
If you want the instructions let me know, I am not allowed here to post MY email address, but you.....
If you have any questions or need advice let me know.
I am here to help people, I do this here for free.
SD TECH
Oct 28, 2009 | Mitsubishi WS-65869 65" Rear Projection...
Not work ws-65869
The DM capacitors need to be replaced. Heres a link to the DM kit for your model which contains the replacement capacitors and instructions with pictures that show how to do the repair.
http://servicemanuals.vstore.ca/product_info.php/pName/v21v19-mitsubishi-dm-repair-kit/cName/repair-kits
Jun 13, 2009 | Mitsubishi WS-65869 65" Rear Projection...
Mitsubishi WS-65869 65" blue color problem
Yes, you need to replace the convergence output amplifier IC's. They can be ordered on line. After removing the back you must remove the circuit board which houses the amps. Then desolder them and install the replacemnts. If you are extremely lucky there won't be any re-alignment issues with the new amps. Then you should be good to go.
May 03, 2009 | Mitsubishi WS-65869 65" Rear Projection...
Mitsubishi WS-65869
This set will require that the power supply voltage problem be fixed...accordianman
Jan 20, 2008 | Mitsubishi WS-65869 65" Rear Projection...
Mitsubishi ws 65869 green led turns on for 2 sec then turns off
Your problem is not shown on schematic, C9A60 (470 pf @ 1000 v) capacitor and check and see if F9A04 & 05 are open. If so then its off to a whole different area. Do you have an email to send Sch.?
Jan 15, 2008 | Mitsubishi WS-65869 65" Rear Projection...
Televison & Video Logo
44 people viewed this question
Top Televison & Video Experts
Electro Med Services...
