Question about ASUS A8N-SLI Deluxe Motherboard
Boot usb cdrom a8n sli deluxe
I need to boot from an extern usb cdrom how can I do it?
    Scholar:
  • 124 Answers
Press Deleate key at boot enter bios goto boot settings set 1st boot devise as usb press F10 and enter to save changes
Posted on Nov 14, 2009
Asus a8n sli deluxe motherboard diagram manual?
Download page.
http://www.asus.com/Motherboards/AMD_Socket_939/A8NSLI_Deluxe/#download
You must choose an OS like XP. Required, but indifferent. Click on Manual and choose Global link.
Oct 14, 2012 | ASUS A8N-SLI Deluxe Motherboard
I don't know how to plug in the wires for the ASUS a8n sli deluxe motherboard
Here is the manual for your motherboard (since describing a diagram probably isn't very useful...)
http://dlcdnet.asus.com/pub/ASUS/mb/socket939/A8N-SLI/e2024_a8n-sli.pdf
You want to look at pages 27-35, they describe what you need to plug into the motherboard. Basically make sure you have connected:
1) 24-pin power cable (from power supply)
2) 4-pin power cable (for CPU from power supply)
3) Any case fans with 3/4 pin connectors.
3) hard drives (SATA or IDE)
4) USB front panel ports
5) Audio front panel ports
6) Case plugs (power LED, hdd LED, power switch, and reset switch).
Apr 19, 2011 | ASUS A8N-SLI Deluxe Motherboard
A8n-sli deluxe one long beep and end. Please help. Thanks
Hi krzysio007! If you hear a beep once you start the system and it does not go away, this might be the CPU fan not functioning correctly. Try disconnecting the fan, cleaning the connectors and then plugging it back again. I have a similar problem with a motherboard just like yours, and usually the beep goes away after it boots into Windows. Since this motherboard has an Award BIOS installed on it try these error codes: Here. Hope this helps you with the problem!
Feb 28, 2011 | ASUS A8N-SLI Deluxe Motherboard
Sata drive wont boot, at boot up it not reconziged
Go in the BIOS and set the SATA disks to be recognized as PATA (probably called legacy mode)
Nov 22, 2009 | ASUS A8N-SLI Deluxe nVidia nForce4 SLI...
Does ASUS A8N-SLI DELUXE support fan speed changing?
You can research *********** board and drivers at ASUS.com.
You may find a new BIOS update which controls the fan speeds and temp.
If not, you can find plenty of frreware which will handle *********** board.
Nov 08, 2009 | ASUS A8N-SLI Deluxe Motherboard
Coolmaster cm690 asus a8n-sli deluxe
the boards today have real fine typeset near the connection pins but they are there
Jul 31, 2009 | ASUS A8N-SLI Deluxe Motherboard
Problem adding Additional Ram to my Asus A8N SLI DELUXE system
Just because BIOS is recognizing the RAM doesn't necessarily mean it is usable. Also, ASUS recommends that you have the same amount of RAM in each bank. Another point they make is that your motherboard does not support double-sided DIMM chips.
I would refer to the manual for their specific instructions on proper RAM configuration:
http://dlcdnet.asus.com/pub/ASUS/mb/socket939/A8N-SLI%20Premium/e2435_a8n-sli_premium.pdf
If you are concerned that the memory stick might be bad, swap it out with one of your older ones, and see if your system boots and performs as it should. If not, then you know it is bad. My guess is that if you populate the memory slots with 4 gb, the system will recognize and make all of it available to you.
Cheers
Nick
Jan 08, 2009 | ASUS A8N-SLI Deluxe Motherboard
Start up
Try removing all IDE/CDROM/Floppy devices from the machine. Then remove extra PCI cards like modems and sound cards (if you have any). Then enter the bios, and reset the bios to it's defaults, and reboot. If that gets to the looking for OS section, then plug each device back in one at a time. Start with the most important devices like the hard drive and Cdrom drive. Then after testing that it still tries to load the OS after each device, you'll identify which one is preventing startup.
Steven
Sep 17, 2008 | ASUS A8N-SLI Deluxe Motherboard
System wouldn't Boot
If your CPU or memory were an issue your Asus board would sound off with BIOS beeps. Asus uses the Award BIOS & you can see what these beeps mean at the link below. Regaurding your PC not able to boot is an issue with your PCIE/PEG video card-in relationship with BIOS setting & the SLI switch card mode that came with your board. When running 1PEG video card you must set this in the BIOS to Auto & you need your SLI switch card connected in its slot. By default, the EZ Selector card is set for a single graphic card. When you install dual PCIE graphic cards on A8N-SLI series motherboards, please make sure EZ Selector card set to the Dual Video Card side and properly inserted. Link to Award Bios beep codes: http://www.bioscentral.com/beepcodes/awardbeep.htm
Will come in handy.
Reading the FAQ's at Asus site will help you better understand your A8N-SLI Deluxe. You'll need to fill in the, "Please Select the Product" first: http://support.asus.com/faq/faq.aspx?SLanguage=en-us
Dec 05, 2007 | ASUS A8N-SLI Deluxe Motherboard
Can't get past the post
Have you set the boot sequence in the bios to cdrom first. You are installing from a winxp cd right? Also, when it past the post and starts reading the cd it will ask you to press any key to boot from cd, if you do not press any key in a matter of seconds it will search for another boot device. Since you don't have any other operable boot device, it will not boot up. If you still have problems, please let me know
Dec 11, 2006 | ASUS A8N-SLI Deluxe Motherboard
ASUS A8N-SLI Deluxe Motherboard Logo
485 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
