Question about Kenmore 62602 Electric Dryer
Dyer is getting power but will not turn on - Kenmore 62602 Electric Dryer
Dyer will not start with start button,but will run with cycle button in cycle when you turn it to the cycle want
Posted on Nov 14, 2009
Why wont my matage dryer get hot
If you recently had a power failure or just installed your dryer sometimes its necessary to reset your breaker box. Unplug your dryer and turn off and then back on the breaker switch to your dyer. then re plug in your dryer and see if that works
Apr 27, 2014 | Dryers
Reset after power outage
Assuming this is a 220 volt dryer, are both sides of the breaker on? It should not blow only one side of the 220, but worth checking.
Jan 26, 2014 | Kenmore Dryers
May Maytag dyer Performa Model number PYE3300AYW will not start the light in the dryer is off i turned to turn off and on the breaker but nothing happens. My question is that if the light needs to be...
no the light has nothing to do with the dryer not running, sounds like a breaker issue. You will need a multimeter and some screwdrivers. first make sure that the breaker has power, you will need to take the front panel off, then with the meter check for your 220 volts at the breaker(where the wires are hooked up), next check for voltage at the outlet, if all these have power then it is in the dryers cord, you will need to move the dryer out and remove the plate and check for voltage, if it does then you will have to trace it into the dryer. Good Luck Tim
Nov 25, 2010 | Maytag PYE2300AY Electric Dryer
I have a Kenmore gas dyer that has developed a burning smell
check vent line,either check outside to see if flapper is blowing open or disconnect vent line from back of dryer and see if it helps.if not there are two thermostats Number: 660036 Substitution: 279048 and
Number: 3387134 ,this one is on blower wheel housing and the other is in the back,take back wall off and you'll see it on right hand side on heater vent duct
Nov 03, 2009 | Kenmore Dryers
Dyer is not turning on acts like it is not getting power
The fuse is located on the rear pan here the heater is. Remove the screws holding down the top and then you can raise the top up and get the front off. the fuse part number WE4X800 looks like this:
7b78f21.jpgHere are some REPAIR PICTURES
Jul 29, 2009 | GE DBVH512EFWW Dryer
Dyer not turning at all
Is the dryer getting power? Check to make sure that the circuit breaker hasn't tripped of been turned off. If the breaker has tripped, you may have a short circuit in the dryer unit and you should have the unit check by a qualified technician.
Jul 22, 2009 | Kenmore Dryers
Attaching Power Cable
The two outside wires of the flat power cable are the power wires. The middle wire is neutral or ground.
Hook one of the red outside wires to the red, the other to the black, and the center one to white.
Feb 13, 2009 | GE Dryers
Dyer on combo won't start
This could either be a bad start switch or door switch
May 29, 2008 | Frigidaire GLEH1642DS Front Load Stacked...
Kenmore 67082 "PF" power failure code
Check your circuit breaker. Reset it even if it doesn't look tripped. It is a dual switch and sometimes you can't tell if one of them is tripped. Then try it. When you reset the breakers leave them off for about 10 minutes before turning them back on.
Dec 24, 2007 | Kenmore 67082 Electric Dryer
Kenmore 62602 Electric Dryer Logo
151 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
