Question about Yamaha HTR-5890 Receiver
HTR-5890 receiver keeps shutting down
Yamaha HTR-5890 receiver keeps shutting down.
After it shuts down it will not turn back on until power to it is disconnected for some time. It seems to be random at when it shuts down--sometimes after four hours or sometimes after just two minutes. Under troubleshooting in the manual it said to check impedance setting and that doesn't seem to be the problem. Could it be that an internal cooling fan is malfunctioning which is causing the unit to shut itself down? (The temperature of the unit does not seem to be a factor-hot or cold it doesn't matter). The problem started about a week ago, going out only once or twice a day and now is going out once or twice an hour. Has anyone had similar problems and can help me figure this out?
  • 4 Answers
For the past month i have been shopping for the perfect home theater system and have narrowed it down to a bose system,a sony system and a paramax p510...i have listened to all 3 systems and have found the paramax to be the better system not a cheaper system but seem more bang for my buck at 3200$,a very powerful tube amp and downfiring sub maxes out at 2000 watts...
Posted on Nov 14, 2009
My yamaha htr-5640 receiver will turn on for a sec then a small click and then shuts down....no speakers hooked up....what is the deal?
With the power off, try to disconnect every component and then power on the receiver. If it still shuts down, then it is an indication of an internal error and the unit needs to be serviced.
Regards,
Yamaha Support
Nov 28, 2011 | Yamaha HTR-5640 Receiver
I have 4 speakers connected 2 on A channel and 2 on B channel....Was listening to a dvd music concert at + 1.5 volume on my Yamaha HTR 5890 receiver,after 5 min my amp shut off and I was never...
Register and download the manual for free at retrevo.com
http://www.retrevo.com/s/Yamaha-HTR-5890-Receivers-review-manual/id/394ci071/t/1-2/
Page 25 discusses the minimum speaker impedance setting for expected lower-than-8-ohm loads. Running A AND B may present a load that is dangerously low. BTW: 6 is not a whole lot lower than 8.
Look at your speakers' impedance specs. Running them in parallel would present a much lower load than either pair alone.
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
You very well may have blown and amp or a speaker.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Eure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked
Mar 04, 2011 | Yamaha HTR-5890 Receiver
I have a yamaha htr 5890. I would like to hook up
You are probably connected to the pre-out jacks. These are not amplified. Connect them to the B speaker outputs(screw down connectors). If that won't work (and it should), you can connect to the "Presence" speaker connections(spring loaded connections).
Feb 02, 2010 | Yamaha HTR-5890 Receiver
The receiver is not turning on. Try all possible solutions ie;Power cord. What is cicurity protection and how do I check for that or correct?
Circuitry protection means the unit is overheating so a fuse blows and shuts down the power to save the electrical components.  You need to find the fuse and replace it.
Oct 25, 2009 | Yamaha HTR-5890 Receiver
Yamaha HTR-5890 not powering up
Power supply is burned out. surge or spike got it, replace power supply unit.
Sep 08, 2009 | Yamaha HTR-5890 Receiver
Yamaha HTR-6130 Receiver will not stay on! Shuts
One last try with everything disconnected!
Other than that I suspect internal surge damage.
Aug 04, 2009 | Yamaha HTR-6130 Receiver
HTR-6130 will not turn on
Remove all speakers from the receiver and try powering it up again. If it still shuts down odds are it needs repair of one of the output channels.
Jan 31, 2009 | Yamaha HTR-6130 Receiver
Yahama HTR-5560
I own this unit also and have found that it is very sensitive to speaker wire shorts. Please recheck all speaker connections to make sure you have no "stray wires" touching someplace to make a short.
Oct 27, 2008 | Yamaha HTR-5560 Receiver
Yamaha HTR-5890 Receiver Logo
626 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
