Question about Sony KV-35S65 35" TV
No power at all
If I remember correctly, the horizontal went small then the set died.
I think I was able to turn the set on a couple times then it completely died.
So far this is what i have learned from this site:
Replace IC601, Q501, Q502, and 0.1ohm fusible resitor (part numbers unknown)
Check for cracks and cold solder joints on flyback and horizontal driver transformer
Clean, tin and solder leads.
Can I get the correct part numbers to order from Sony as well as a guide on how to... I don't know which boards to remove from tv. I won't have a problem replacing the parts and cleaning, tinning and re-soldering the leads and connections.
I really would like to fix this set because it worked great before it died.
4 Suggested Answers
  • 10594 Answers
SOURCE: Sony Trinitron KV-32XBR15
You should check Pin-Amp stage for subject problem. Pin Amp is located at Horizontal area. Pin Out Transistor is suspected.
Posted on Jun 08, 2008
  • 116 Answers
SOURCE: KV-32s66 Flashing stby timer LED- no pic no sound
check for any short circuit on the board.
Posted on Oct 07, 2008
  • 6771 Answers
SOURCE: SONY TRINITON KV-32XBR15 The picture has
From your description it sounds like a yoke problem, you describe an hour glass picture which is a classic symptom of the horizontal sector of the yoke is at fault. The easiest way to test for this is a ringer tester, chances are it will show a short in the horizontal winding which causes the high voltage to load down and draw more current in the process.
Posted on Mar 08, 2011
How do I reset my Microsoft password
I'm not an XBox user but my sons are and I think we're helped them out with this a couple of times. If I remember correctly, we went to the XBox website (using a computer, not the XBox) and reset it there. If we did not have the password to log into the account, we clicked "Forgot Password" and a reset email was sent. We used that email to set a new password and then the boys went and used that new password on the XBox without any trouble. Again, it has been a while, so some of the details might be slightly off but the general concept - go to the website and reset there - I'm fairly sure about. I think it's also possible to do it over the phone with Microsoft support if you have time to wait on hold for a while.
Jun 19, 2014 | Microsoft Xbox 360 Console
Black and White Horizontal Lines
Sounds like the graphics card just died. You will need that repaired.
Apr 15, 2014 | Apple iMac Computers & Internet
Turn tv on, asks to select language and does convergence
II don't think it's a setting. Maybe some sort of battery has died. Kind of like a CMOS battery in a computer. If it dies it can't remember the settings. Good Luck.
Dec 28, 2012 | RCA D52W15 TV
Jenn air wall oven control panel not working properly
You will need to replace the front control board and the touch panel
Mar 28, 2017 | Ovens
We have a Sony Triniton 32 inch TV we bought approximately in 2000. For a couple of weeks we had horizontal lines across the screen, then it just went black, no audio, nothing. Just comes on and off....
It is probably you horizontal output or horizontal output drivers. The newer TVs derive all there power from the horizontal circuit. This can only be fixed by an experienced technician as that area produces in excess of 20,000 volts to light the screen. Don't try to fix it your self as you could cause more damage or be electrocuted.
Oct 07, 2009 | Televison & Video
Main Menu
power supply regulator and horizontal output transistor.
Jan 17, 2008 | JVC AV-27230 27" TV
Lines on tv
Set starts, horizontal and vertical deflection work, HT ok, crt heaters ok, but no sound or picture
I turned the G2 voltage up and noticed a white screen with flyback lines, frame ok. I detected two badly soldered double diode rectifiers in the secondary part of the power supply ! I checked all other joints, and everything was ok !! success
White horizontal line (no vertical deflection)
Check / replace R548, R549
Sound but no picture except for a couple of horizontal colour lines
Replaced the frame chip TDA8356, set now ok
Nov 23, 2007 | Mitsubishi WS-65511 65" Rear Projection...
Tv doesn't work
If your projection went down to a single dot in the center then you are most likely at the minimum replacing all three projection tubes due to that dot. It will leave a permanent mark in the center of each CRT and not repairable. The cost on that old set aren't worth it.
Mar 30, 2007 | Sony KP-48S75 48" Rear Projection...
Tv will not come on
Sounds like a short issue. More than likely a shorted horizontal output transistor. First all fuses need to be checked. If good, check the HOT. If the HOT is shorted and a common part you'll be ok. Apex does not support it's products. In most cases they are impossible to repair due to unavailability of parts. Anything beyond the HOT will probably not be obtainable. If you are going to look at this unit remember safety. Good luck.
May 29, 2006 | Apex Digital GT2011S 20" TV
Sony KV-35S65 35" TV Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
