Question about Radio Communications
I have my T5428 set to 7/30 same as the other radios but they will not connect
  • Radio Commun... Master
  • 1,654 Answers
You might try turning off your interference code eliminator (set to zero) and see if this clears the problem. If you have your call tones turned on, you might try shutting them off also. This would put you back to a basic mode where you are communicating as simply as possible. If the radio is still not working, you have bad radio. Here is a link to the closest user guide I could find to your model: http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T5320_T5410_T5420_User_Manual_E.pdf
You did not mention if your radios are all the same T5428 model. If they are not, you may have some frequency differences between the units.
Best regards.
Posted on Nov 15, 2009
Radio wont save settings
if you recently installed your radio there is a wire designed to be direct connection to battery power , this wire is memory wire this is not connected to ignition barrel wiring . hope this helps
Mar 18, 2014 | 1999 GMC Suburban
Jvc car radio won't mute on incoming calls
I think the only hope you may have is the radio has an auto signal select in the menu somewhere. You can't use the mute wire as that will mute the AUX as well.
Dec 08, 2013 | JVC Ks-bta100 Bluetooth Adapter For Select...
Motorola t80 can it com with t5720 or t5428
Compare frequency charts here http://shop.giantintl.com/Manuals.asp?offset=30
Sep 06, 2013 | Motorola Radio Communications
1994 honda accord radio wont save settings.
If you have a multimeter or test light, try to find a wire that still has 12v when the key is off. Connect that wire to the yellow wire of the radio. The yellow wire has to have constant voltage going to it to maintain the memory.
Feb 11, 2013 | JVC KD BT11 CD MP3 CAR RADIO IPOD AUX...
I have 2 T5428 radio.How can i tune the 2 to the same frequency so that 2 people can use?
Here is a link to the manual http://www.giantintl.com/ContentManage/manuals/Moto/T5320_T5410_T5420_User_Manual_E.pdf
You will find programming instructions starting on page 15.
Program the frequency and interference eliminator code to match one another. For simple operation set the code to off (zero).
Best regards.
Aug 13, 2010 | Motorola T5522 (7 Channels) 2-Way Radio
Nokia 5200 - radio not working - connect an enhancement error
I Think there is some problem in Radio settings, so just make sure to reset mobile settings
Jun 17, 2009 | Nokia 5200 Cellular Phone
Samsung e730 problems
It depends on your service provider.
E730 support only gprs and you need to call your telecom Service provider to inquire if they have gprs connection.
If yes request for an activation settings and you will receive an sms from them notifying you of the activation or if more is required.
You will notified on what to do.
Just request for activation for both wap/internet & mms activation settings.
As for the Radio, you do not need the internet connection for that because it is just an FM Radio.
Select you Radio and select more to search for Radio Stations. After Searching you can then save it when you get a station of your choice.
So when next you go to Radio you won't have to search again.
NOTE: If you require an internet Radio. Visit wap.getjar.com
You will get an internet Radio which you will require internet connection before you will be able to listing.
Jun 17, 2008 | Lands Phones
How do i set it up
Going on the info provided.1. mount the radio. 2. connect your antenna. 3.Connect Power- Red to Pos. Black to Neg. 4. Connect microphone. Note, be sure antenna is mounted on vehicle in the center of the roof. This provides omnidirectional signal. Be sure to set your Standing Wave Ratio.
If this fails... READ the instruction manual that was packed in the box with your radio.
If you still have no luck, return the unit back to the store. Forget the whole thing. PLEASE!
Apr 23, 2008 | Cobra 29 WX NW ST 40-Channels Base CB...
Radio Communications Logo
220 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
