Question about Mercury P4VM800M7 Motherboard
800fsb ram modules are not showing it's actual
My system is pvm7 pro, i have tried to install 1Gb 800 ram in one bank, but is showing only half of the size i.e 512mb in winXP.3, any solution
  • tetali_ragha Nov 14, 2009
    bad solution. I think it may due to the fsb factor, as per the manual the ram fsb should be 533, it is may be suitable.You better think from that angle.
    Champion:
  • 206 Answers
Is it possible that the max ram size for your MB is 2GB(counting that you have 4 RAM slots)
Posted on Nov 14, 2009
I bought a new 1GB ram(DD2) when i insert it it nt work bt whenever i insert it with old 512MB ram then its work bt in bios setting only show the 1GB ram
Maybe 1GB is the maximum amount of memory that your system will hold. And maybe your system likes memory to be in pairs, so when you put the 1GB in by itself it didn't work, but when you put it in with a 512MB it works.
May 18, 2012 | Computers & Internet
Here's my issue. Ok i have 2 ram slots. When I have 2 1GB ram cards in the slots the computer registers 2GB ram. When I put in 2GB card and 1GB card, it only registers 2GB RAM. No idea why. I bought...
the issue may be the ram is not the same like a PC100 will not work with a PC300 ram card but if you have the same like a 2GB DDR2 and a 1GB DDR2 it will work unless your computer can only see 2GB of ram then i cannot help you
Jan 02, 2011 | Computers & Internet
Machine is running but after a few minute there is no display screen shows black in mercury motherboard PVM7 pro model. I install 2pcs new ram (1GBX2) but machine shows each slot 512mb instead of 1gb...
Any beeping if there is
CPU cooling fans seized of about to seize?
This should happen in 30 second for a thermo shutdown.
Reseat the cpu make sure there is thermo white compound between the heat sink and Top of the CPU
make sure there is proper flat seatin of the heat sink and CPU make sure the fan is working.
It can be ur video or monitor,
Aug 26, 2010 | Computers & Internet
Hp Compaq dx2200 MT RAM Problems
Firstly, you have to know that you can upgrade RAM as Double or Half of your pre-installed RAM. For example, like your pre-installed RAM is 256 MB, you can only upgrade RAM of capacity 128 MB or 512 MB. Secondly, check your previous installed RAM's speed that is shown in Ghz. You can only upgrade RAM to its similar speed, otherwise you get slow performance of PC.
Jul 18, 2010 | HP Compaq dx2000 Microtower PC Desktop
I have 4 banks of ram slots. Can I keep the Bank1 256k Bank2 256k. Can I put 1G into bank3.
It is strongly recommended that you install RAM in matched pairs. So if you add a 1GB module in bank 3 then you should add 1GB in bank 4
But you can add just the one module and it should work, but not at optimal speed.
http://www.crucial.com/store/listparts.aspx?model=Pavilion%20a1410n
Jan 12, 2010 | HP Pavilion a1410n (ER890AA) PC Desktop
Dual core E2160 1.8ghz doesnot display actual speed
i think the reason for not using 800fsb is your memory. make sure that you use ram that supports 800 fsb (ddr2-800).
as i don't have the manual i describe you another problem that may be the reason if you already use ddr2-800 ram -> on some mainboards the fsb is rated down when a defined level of memory built in is reached. please check your manual if your board has such a limitation.
Jul 26, 2009 | Biostar P4M890-M7 Motherboard
Wheres the ram?
RAM modules must be installed in special locations on the motherboard called Sockets. These memory sockets are what hold the RAM module in place and can range from 1 to 16 or more. Banks consist of a group of 1 or more sockets. A system can have 1 or more of these banks of sockets. If a system has more than 1 socket in a bank, a Kit must be purchased for that bank. A kit is simply more than one, usually 2 or 4, like RAM modules. All sockets in a bank must be filled. Typically you will see 2x512MB or 2x256MB signifying you get 2 units of 512MB RAM modules or 2 units of 256MB RAM modules, respectively.
The Toshiba Satellite A40-S270 has 2 bank(s) which have 1 socket(s) in each bank for a total of 2 memory socket(s). This means the Satellite A40-S270 can support up to 2 individual RAM modules.
Below is a visual representation of the memory bank(s) and socket(s) configuration for the Toshiba Satellite A40-S270.
socket_1.gifsocket_1.gif This graphical representation above details what the memory configuration would look like with the maximum memory installed and does not necessarily model your system memory configuration. This graphical representation is not drawn to scale and should only be used as a general reference. Please consult your system’s user manual for your actual memory configuration.
May 11, 2009 | Computers & Internet
How much Ram am I using?
Unless you are running a 64-bit version of XP or Vista, Windows will not report the full 4GB. It's because of the way the program addresses and uses RAM. Here is a page that gives a little explanation. The bottom line is that if you want to get the full use of 4GB of RAM you need the 64-bit operating system.
Apr 18, 2009 | Dell Dimension 5150 Intel Pentium 4 w/HT...
1gb shows 512mb only
Your mobo is quite old and its chipset can only support a maximum of 512MB PER SIDE (technically called a bank) of a memory module. I would guess that your 1gb memory module has 8 chips that are all located on one side of the module, putting all of the 1 GB on one bank. Thus, only 512MB of your 1 gb RAM is detected and usable by your motherboard (the remaining 32 mb is most likely being used by your onboard video). You'll need to find a double sided 1 gb memory module (usually 8 chips on each side).
Mar 06, 2009 | ASUS P5VDC-MX Motherboard
Install memory not showing total only half
Hey,
it should show in the bios as 2048.
looking at the details of the motherboard
Memory Type dtrquestion.gif DDR SDRAM Number of Memory Slots 2 x DIMMs Supported RAM speeds 400 MHz
Got the right speed ram etc?
Thanks,
Ekse
Feb 20, 2009 | Computers & Internet
Mercury P4VM800M7 Motherboard Logo
199 people viewed this question
Top Mercury Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
vsri9
Computer Links
Are you a Mercury Computer and Internet Expert? Answer questions, earn points and help others
