Question about HP Computers & Internet
What cable do I need to connect my HP Pavilion 5229uk with built in TV tuner to an external antenna socket?
  • 2,567 Answers
Here is a direct link to the user's manual of this model of PCs:
http://h10032.www1.hp.com/ctg/Manual/c01863412.pdf
On page 11 of this PDF file, you will find a section with a title "Connecting the Television Signal and Video Cables". In this section, you will find all details regarding connecting your TV tuner to an external antenna.
Posted on Nov 14, 2009
How to properly connect the channel Master antenna tuner to my TV so that I can connect an antenna to the tuner. I have the CM-7001. I'm connecting through the HDMI port on the tuner to the HDMI port
Confusing question! The CM-7001 is meant to be used for displays or monitors that have no means of connecting an antenna and don't have a built-in tuner. HDMI to HDMI would be the correct way and make sure you select the proper HDMI port. Or use the other video and audio cable connections.
Sep 03, 2014 | Channel Master CM-7001 ATSC Antenna and...
I am moving tomorrow and won't be able to afford cable or satellite for awhile. I have a newer model Sanyo tv. Will I need a converter box or can I hook an antenna directly into the tv to pick u
If your TV has the screw-on coaxial cable connection on the back, then you will not need a converter box. You can attach an internal or external antenna and have your TV scan for digital channels. The converter boxes are mostly for old CRT TVs with analog tuners or newer home theater "monitor" TVs which are being produced without built in tuners.
Dec 21, 2012 | Sanyo DP32746 32 in. LCD Television
How to connect tv tuner
there is a simple way to connect the tv tuner just socket is given on the panel and connect in inlet it .
please give your ratings.....Thanks to giving me chance to help
Mar 30, 2011 | Televison & Video
The antenna/cable connector looks broken. can this be replaced?
Hello
In most models of Sharp Telivisions,antena socket is an integrated part of the tuner itself and cannot be replaced with an other one. There is only one way and is to replace the tuner itself.
If you don't mind of style, you can solder two wires, one from the center pole of the antenna socket, and other from it outer rim, and take it out and connect to an external ariel socket [can be bought from electronic sparepart shop as a seperate socket] , to whcih you can connect your ariel pin. It will look a little dull, but you can face the probelm, without replacing the tuner. When making these connections, use sigle cored shield wire. It center wire must connect to the center pole of the broken tuner socket. OK.
Dec 09, 2010 | Sharp 27N-S300 TV
I have a 2 tuner tv. When Cablevision installed my digital cable box, I lost the 2 tuner capability. Is there a special way it needs to be hooked up to get back the 2 tuner capability?
Your cable system is probably QAM (digital cable). The tuners built into the TV are analog and digital OTA tuners (ATSC and NTSC). If you connect the Cablevision box to the component video input (and connect the audio out of the box to the appropriate audio in) on the TV and an appropriate antenna to the coax (antenna) input, you will be able to swap use the tuners in the TV. (See tvfool.com for antenna types and direction or antennaweb.org for directions of the most likely stations to be received at your location. antennaweb assumes an external antenna and is conservative in the list it provides.)
I hope this helps.
(please note, you probably need to get the component video cables. These have 3 RCA plugs on each end (red, green and blue). To carry the audio you need a cable with 2 RCA plugs on each end (red and white). Match the colors as you connect them.)
Nov 05, 2010 | Proview PA-32JK1A 32 in. LCD Television
The sylvania plasma tv does not have a coaxial cable connection, how do I connect my local cable?
You just can't. Not without an external receiver.
Your TV is simply missing a piece of hardware - it is called TUNER - that can understand the signal that runs through the cable (or an antenna) and decode it into simple video signal.
So the only solution is to buy an EXTERNAL TUNER device (also called external receiver or external set top TV box).
Those are rather cheap compared with what they used to be, but if you care for an advice from professional it is: sell your TV and use the revenue towards the purchase of a new one. All TVs currently in the mainstream sales channels have that thing built-in.
Some of the older models that you will find on Craigslist (like yours) do not.
it is usually not a problem for users with cable TV because most cable TV boxes also have a built-in tuner. If you are talking about how to connect your TV to your local cable company then the right thing to do is call your cable operator and tell them you want a newer receiver that outputs standard composite (one yellow one red one white) or component (green, blue, yellow and white and red) - if your TV has the later.
Hope this helps. If it does please rate accordingly.
Cheers,
www.coppelltvrepair.com
Oct 18, 2010 | Sylvania 6842PF 42 in. EDTV-Ready Plasma...
Plugged in, cable connected, turned on, says "No Signal"
OTA signal? Check your antenna orientation and if there are any tall objects that would interfere with the signal. (See antennaweb.org or tvfool.com for signal directions and distance to the station. antennaweb assumes an external antenna and is very conservative with station information.) Scan for channels with Menu > > (right arrow twice) up or down to AutoScan and hit enter. Use add channels to include stations with the antenna in a new direction.
If you are using the built-in antenna, you may not get digital signals. Try an external antenna (see above sites). Digital signals are enough or zero.
This TV doesn't have a cable tuner so a set top box would be needed for cable stations, check the box directions for the station you need to tune the TV to access the signal.
I hope this helps.
Aug 05, 2010 | Axion AXN-8701 7 in. Portable TV
Do we need to buy an antenna to get this TV ready for Digital TV?
LCD TV refers to the substance that creates the picture quality (it would be either LCD or Plasma or Tube) and HD refers to a crisp clear picture that can be attained. So your TV is an LCD (Liquid Crystal Display) TV that is capable of receiving and displaying HD (High Definition) Picture.
What you need to check for is whether the TV has a built-in Tuner. This will either be SD (standard definition) TV Tuner or an HD TV Tuner. The box it came in will tell you or you may still have stickers on your TV.
If it has a built-in SD tuner you will be able to pick up HD channels but in a lower quality. In this case you will only need to plug the TV into a Wall-socket antenna or rabbit-ear antenna.
If it has a built-in HD Tuner you will be able to pick up HD Channels in full HD quaility picture. Simply by plugging the TV into a Wall-socket antenna or rabbit-ear antenna.
If your TV does NOT have a built-in TV-Tuner then this TV is clasified as "HD Ready". Which means that you have to purchase a Set Top Box (STB). you can get either HD or SD set top boxes. In this instance you will plug the cable from the wall socket into the STB then from the STB into the TV using either an HDMI cable (as long as your TV has an HDMI input) or through RCA cables which will be coloured Green, Blue and Red (i think red)
By the Way - best picture quality is from a wall-socket antenna.
HDMI = High Definition Multimedia Interface
STB = Set Top Box
High Definiton RCA cables will also be refered to as YPbPr/YCbCr (depending on equipment)
LCD = Liquid Crystal Display (the method used to make the picture on your TV screen)
If you have anymore questions, ask away.
May 26, 2009 | Philips Televison & Video
PROBLEM WITH GETTING LOCAL hd CHANNELS
You need to have a set top box.
By law, as of March 1, 2007, almost all televisions should include a built-in tuner (called HDTV, digital, or ATSC tuners) that can receive high-definition programs over the air by simply connecting an antenna. Your HDTV doesn't have such a tuner, you'll need to connect an external tuner (or cable or satellite box) to watch high-definition programming. External over-the-air HDTV tuners currently cost at least $150.
Nov 14, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Computers & Internet Logo
169 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
