SONY REMOTE RM-U303 not working
Sony remote RM-U303 for my sony reciever stopped working.
i bought unit(second hand ...no warranty :-) ) and took it home plugged it in and remote went fine.
sincehooking up entire system....dvd,cd,sat,tv ...(next day) remote stoppedworking. had a little trouble with my sky (sat/tv) remote at sametime.have replaced sat tv remote but wonder if the sony remote is maybedeprogrammed or something? help please
SOURCE: Universal remote
I found a perfect universal remote with the logitech harmony 525. usb / infrared / internet upgradeable. also loads keyfunctions directly from the old remote, but most of the keys came directly from the standards offered. the configuration is web-based and always up2date. service people are also very helpful. can fully recommend it!
Posted on Aug 02, 2007
  • 298 Answers
SOURCE: Onkyo TX DS575x reciever remote problem
You might try this replacement
http://www.remotes.com/remotes/servlet/rs?a=gmi&uid=11953114154530&smodel=TXDS575&brand_pn=ONKYO_TXDS575
Posted on Nov 17, 2007
fileset
SOURCE: remote
I have found a solution to the question. This remote will allow a user to control a SONY receiver by pressing the "Use Mode Key" at the top of the remote, and AV1 or AV2 button, in the first line of buttons toward the top of the remote, at the same time and this allows for control of an unlimited number of SONY receivers
Posted on Nov 22, 2007
minteker
  • 52 Answers
SOURCE: Remote code for Sony Home Theater
Here's a link to the user manual for the remote. There's a section with codes for programming your devices.. Also, it says, if code isn't listed, there is a "code search" function on the remote..
Posted on Mar 19, 2008
SOURCE: TRYING TO PROGRAM MY NEW SONY RM-YD024 REMOTE
Try these
For Direct TV:
00099, 00247, 00392, 00566, 00639, 00749, 00819, 01076, 01108, 01109, 01142, 01377, 01392, 01414, 01442, 01443, 01444, 01609, 01639, 01640, 01749, 01856, 20739
For Panasonic Satellite receiver:
00247, 00701
You can also look here:
http://esupport.sony.com/US/perl/model-remote.pl?mdl=RMYD024
Posted on Dec 23, 2008
I have a Sony theater reciever that I bought off eBay with no remote. So I looked around and Sears was selling a Sony Universal remote RM-VZ220 saying it was compatible with my Sony STR-K670P AM/FM...
1. Make sure you have good batteries in the remote and they are installed properly.
2. Press the DVD button on the second row of the remote, then check if the Power and other buttons on the remote work with your system (it probably won't since the factory setting is for a Sony DVD player, not a home theater system).
3. If it doesn't work you need to find the correct code number for your system and enter it into the remote. Press and hold the SET button for more than 3 seconds until the SET indicator lights up. Keep holding the SET button down and press the DVD button, then release both buttons. Then enter the code 31622. If you have done this correctly the SET indicator flashes 3 times, if not start over.
4. See if the remote now controls the theater system correctly. If not, repeat the above procedure #3 with the following codes one at a time until you find one that works: 31558, 31658, 31758, 31822, 31858, 32522.
May 23, 2014 | Audio Players & Recorders
I don't know if I can make it any clearer. My remote RM-PP411 suddenly stopped working. It has new battries and the use mode light lights up when any key is pressed. I turned the STR-D685 on by hand and...
Please take these actions before we try yet another universal programmable remote 1. Clean the IR screen on your tv set. It will often appear clear in view with a reflective window which often has a black, blue, or red tint to it 2. Clean the same window on the programmable remote 3. From tons of experience, I've noticed that Sony tends to provide the most compatible remote for replacements 4. Please confirm with me which codes your attempting to use when programming, and type /model number of the universal remote 5. Keep in mind that the remote that does not work as a replacment may very well be exchanged 6. Only use approved batteries for your remote and keep in mind that rechargeable batteries account for 50 percent of electronic errors 7. If your old remote simply stopped working for no reason at all, then we may have a communication problem with the tv combo set itself. 8. Ensure that the tv set is ready and able to receive a signal by setting it to the factory defaults within the settings menu 9. If we know why your older remote simply stopped transmitting the signal, we will acheive a must faster solution 10. Please attempt a fresh set of batteries in the older remote to determine the root cause behind the transmission problem 10. Check your power cord for crimping, dents, or pinched underneath unit. Each of these activities will cause power to stop transmitting to your unit 11. the digital display is not popular for having problems. 12. Ensure that you press the power on button on the digital display firmly at an attempt to power the unit on. 13. If you still have not recieved power, we will continue to troubleshoot the internal portions
Jan 26, 2011 | Sony RM-PP411 Remote Control
Alright, so is there any way I can get the Sony RM-V310 remote to work with a dish network reciever
probably not. you need the original dish network receiver remote. call your Dish provider for a replacement.
Jul 22, 2010 | Sony RM-V310 Remote Control
Trying to program a tv with a new remote control
I bought a second hand Durabrand BH2004D. Then the problem started on finding a universal remote that could work on this tv. It was very fustrating the first day. Then I went to K-mart and bought the Sony RM-EZ4 universal remote. My god it worked, and it was only around ten bucks. The code that worked was 8081. Hopefully ill save someone the fustration that i went through.
May 17, 2010 | Televison & Video
Program sony remote to operate dish vip722
The Sony RM-YD029 Remote control will work with the Dish Network VIP722 DVR HD Satellite Receiver, but the Dish Network VIP722's Primary remote address must be set to 1.
The procedure below will allow Sony RM-YD029 remote control to operate Dish VIP722.
Using the Dish Network Remote Control -
1. Press menu 2 times to get to system info page
2. In the system info page the primary remote address is in a white box (bubble) followed by a Green TV (1)symbol that says IR and indicates you the channel your remote control one is configured. The Sony RM-YD029 will work when this primary remote address number (in the white box) is set to 1.
If the Primary Remote Address of your VIP722 Remote control 1 is not set to channel 1, here is how to change it:
1. While displaying the system info page, press and hold the SAT button on your dish network remote until all other modes are flashing, about 3 seconds.
2. then press the '1' button on the numeric pad of your dish remote
3. then press the '#' button on the numeric pad of the dish remote
4. then press the 'record' button (red dot button - stores setting)
5. At this point you should see a number 1 in front of the primary remote address on the dish system info page
Ensure you enter the corresponding IR code into your Sony remote control per the instructions in the manual or Sony's web site. My 722 works with Sony IR code - 01775.
Sep 08, 2009 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
Sony RM-VL1000 stopped working
Dump the Sony "Integrated Remote Commander RM-VL1000" and go to WalMart (or wherever) and purchase any other brand and model for under $15.00.
You'll be so much better off!
Mar 21, 2009 | Sony RM-VL1000 LCD Remote Control
Can't surf chanels with the channel switch (+,-)
If this remote is brand new, I would say it is defective. I would return it to the store where you bought it. If it's past the 30 days mark. I would contact Sony they have a 1 year warranty.
1-800-222-7669 (SONY) International (Calling from outside the US or Canada): 1-239-768-7669
Jan 22, 2009 | Sony RM-V310 Remote Control
Need help on using a sony RMT-833 remote control unit
The Sony RMT-833 remote is for a Sony Camcorder - see http://www.replacementremotes.com/store/images/RMT833.jpg
I think you mean the RM 833 remote - if so try eBay as listings there suggest it works with Number: RM-833 Compatible with TV Models: KVX250, KVX2501D
Hope this helps
Sep 25, 2008 | Sony RMT-833 Remote Control
Sony STR-VX550 does not obey remote commands from "optional" Sony RM-S750 remote commander. RM-S750 is working properly and communicates all commands to my other STR-VX550. Receiver appears to be...
You appear to have reprogrammed your remote. Remotes can work with other units made by the same company. But the keys will pass out different signals to each unit. You need to find the correct code for your unit.
This could involve selecting a combination of keys on the remote and possibly some controls on the unit. Then entering a numbers on the remote.
It could be that the unit has the option of selecting a remote mode 2 also. So you will need to select it back to one or whatever it is supposed to be.
Jul 09, 2017 | Sony Audio Players & Recorders
344 people viewed this question
 Grubhead
Grubhead
