Question about EliteGroup NFORCE4M-A Motherboard
My motherboard's bios no longer sees my RAID setup
My motherboard's bios no longer sees my hard disks. The RAID driver DOES see them still. All I need is the name/part number for another motherboard that will see my raid disks properly. This motherboard is the ECS NForce4m-a v3.0, with MediaShield Rom bios 5.60. Thanks in advance.
  • noegoman100 Nov 14, 2009
    I need the replacement board to be an AM2 or AM2+ socket. Thanks.
    Champion:
  • 206 Answers
I believe that ASUS P5QL PRO would save you from any more trouble, and it isn't too expencive
Posted on Nov 14, 2009
Mother board masi km4am-l H.D.D. 1 TRA WES 64MB when installing win xp hard not detected by win setup. I updated bios but not worked. advance thanks
you should not update the bios...the issue is the hard disk is on sata ...and you need a raid driver installed to detect the hdd...so ...either get into BIOS and under advanced features..look the place where the drives are detected..and select the hdd and look for a feature called AHCI ..and disable it ..and leave sata like ide..and save with f10 and restart ...after that the hdd will be seen ..
another way is to make a floppy disk with the raid driver on it (the one from the mothermoard drivers disk ) ..and when it ask you to press f6 for 3rd party software ...press it ..and insert the floppy ...it will pick up the raid driver and will go like a charm ..
if you do not have a floppy ..install a second cd drive ..and use a cd ..and after pressing f6 for 3rd party ..browse and point to the raid driver on the mobo driver cd ..
Jul 15, 2011 | MSI KM4AM-L VIA KM400A CHIPSET ULTRA...
I have problem in asus A8V-vm motherboard in that hard disk is not detected in BIOS but Win-XP is working properly and when I tries to install new windows XP it shows an error that hard disk cannot be...
Asus A8V-VM Motherboard coming with SATA RAID option, thats why you could not see the detected HDD in system BIOS. But you can see the the detected HDD in RAID BIOS. You can enter to RAID BIOS that will pop up after system BIOS. If you are using old version of WinXP it will not detect the RAID controller of you motherboard. Thats why you cannot able to install WinXP. While you booting from WinXP CD press F6 key when the WinXP installer prompted for third party driver. Copy the RAID driver provider in driver CD to a Floppy Disk (INF file) and insert it, hit enter to continue the installation. If you are using WinXP Service pack 2 or higher you do not need this step it will automatically detect the HDD.
Nov 25, 2010 | ASUS A8V-VM Motherboard
Need raid pata driver for foxconn rc4107ma motherboard
Normally RAID setup on board, is handled in the BIOS settings.
Feb 21, 2010 | Computers & Internet
I an trying to set up raid 0 with two 500 gig wd hard drives on my abit awd9-max on a new install. I am running xp.raid is enabeled in bios. I hit f6 on windows setup installs dirvers but seems to be a...
In bios make sure the raid chipset is active. Ususally there's 2 one needs drivers one doesn't. I use the one that doesn't then in bios there should be a way to set up your array. Raid 0 is striping mode so you should only see one hard drive,the d drive should be the cd/dvd device. If this is right then you did it right.If it were raid 1 then you would see both hard drives,because one is mirroring the main drive for backup.
Dec 31, 2009 | Abit AW9D-MAX Motherboard
Replaced battery, now goes to POST & unable to create RAID
BIOS needs set up again. Look @ hard drive setup in particular. If you have SATA drives the put them in IDE mode.
Aug 15, 2009 | Computers & Internet
ABit-Th7 raid Drivers
This problem is very simple.... Using RAID in booting in cd/dvd cannot be done in this kind of processing. you have to change the setting of Hard Disk and CD/DVD to IDE in BIOS . To change the setting in the BIOS you need to press the Delete After you power on the computer.. In Main menu in the bios you will find the hard disk or cd/dvd settings to IDE, SATA, and RAID. change both hard disk and cd/dvd to IDE configuration. make sure the first boot in the Boot menu is the cd/dvd, where your windows cd installer is inserted. Save the settings by pressing F10 key in the keyboard.. I have the same problem as of you because i try it to change SATA, RAID but cannot boot to cd and cannot detect the hard disk when installing OS, but in IDE settings its okay.. and it works perfect.. after you installed the windows properly, you can change the Hard Disk or cd/dvd configuration to SATA or RAID. TY
HOPE I CAN HELP
Dec 08, 2008 | Abit KT7A-RAID Motherboard
Abit th7raid motherboard-160GB HD cannot recognize-needs flashing-out of my depth!
Hi coonster,
Abit TH7 Raid driver.
Windows inability to see all of your hard disk drive is not a motherboard issue.
It’s a windows issue. ( I suggest you use the hard disk drive software from the manufacture’s web site). Most allow you to download software that allows you to create a bootable floppy disk. Boot to this disk & setup the drive in a dos like window.
Once completed you can now boot to the windows CD. Do not allow windows to format
the drive.
That is what the manufactures disk will do for you. Install windows & please update it fully. Windows should see all of the 160GB after updating.
If you feel you need to update the bios, feel free to do so.
Follow Abit’s instructions on how to update the bios from this link;
http://fae.abit.com.tw/eng/download/bios/index_old.htm#486
If you have never downloaded a bios file or drivers from this site it can be a bit confusing. You’ll need to high-light the entire link below, than right click once to open the pop-up window. Than left click copy. Open internet explorer. Right click once in the address window & left click past. Than press the enter key on your keyboard. The site has a timer on the left side of the page. You’ll have to wait for it to reach zero.
Than a yellow bar will open across the top of the page that says, (To help protect your security, Internet Explorer blocked this site from downloading files to your computer. Click here for options...). Right click once on the yellow bar & left click download file. Create a folder on your desktop & name the folder " Drivers". Download the file named " infinst_enu.zip" into the driver folder. Us any uncompressing program & uncompress the file keeping the files within the driver folder. The action of uncompressing the *.zip file will create another folder named " Disk1".
http://www.nodevice.com/driver/download.html
To download the Abit TH7 Raid bios is done like the instructions above. For this bios file you’ll need to do the same with the link below;
Abit TH7 Raid bios file name " th736.exe ".
http://www.updrivers.com/getbios/Motherboard/Abit/TH7-Raid-BIOS/6187.html
Please retype verification code: "enter code listed on site".
Press enter.
Again create a folder on your desktop & name it Abit bios.
You will not find any drivers, bios or manuals directly from Abit. They no longer support this motherboard.
Mike
Nov 07, 2008 | Abit KT7A-RAID Motherboard
Installing windows on SATA HDD
That happens because the BIOS uses a SATA controller that is not included in Windows XP install disk.
Usually you can solve the problem going to BIOS settings and changing SATA/RAID settings.Check your BIOS settings, and disable SATA RAID mode.This is done in different ways depending on the BIOS.
On HP/Compaq computers for example you press F2 on startup to enter BIOS, then disable SATA mode on bios settings.
On other makes the procedure can be slightly different.
Another way to fix the problem, is by creating your own XP setup disk with SATA drivers included, see:
Resolving "Setup did not find any hard disk drives" during Windows .
Sep 08, 2008 | Soltek SL-75FRN2-RL Motherboard
Bios setup raid
upon setting raid... u must have a raid driver that is in a floppy disk..
go to windows setup.. look at the dialog below.. u should see a message there that says "press F6 to setup raid .. .. .."
something like that.. and ul be able to setup raid..
May 09, 2008 | Intel Motherboard
Motherboard does not have a SATA configuration on bios setup
use third party raid driver.use floppy drive for installation third party raid driver.
Sep 08, 2007 | Asrock P4VM8 Motherboard
EliteGroup NFORCE4M-A Motherboard Logo
119 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
