Question about Ruud Matching Split Air Conditioner
I have no hot water or central heating but all lights are on just doesnt fire up
  • 36 Answers
Check your sequence.
first pump,fan,pressure switch,ignition spark,gas valve.
ifone is not wrking then you wont get nothing,
but it sounds like the pump
Posted on Jan 31, 2010
My central heating turns off when i turn the hot water tap on. when i turn it off the central heating doesn't come back back on until i turn the power off and on.
Combi-boiler-turn hot water tap on/off and the heating stops for ...
singletrackworld.com/.../combi-boiler-turn-hot-water-tap-onoff-and-the-...
Combi-boiler-turn hot water tap on/off and the heating stops for 20secs ... hot watertakes priority over central heating so when you run the hot tap, heating is ... Yeah onmy worcester combi there is a diverter valve - it feeds either the heating or ...
My central heating works but I have no hot water - 24'7 ...
https://www.247homerescue.co.uk/my-central-heating-works-but-i-have-...
Diverter valves switch heat between the hot water and the central heating. When youturn your hot tap on, the diverter valve temporarily shuts off the water supply ...
Does your boiler keep switching itself off? Here's why ...
www.dhs-uk.com/does-your-boiler-keep-switching-itself-off-heres-why/
Jul 7, 2015 - ... Bathroom Suites, - Showers, - Wet Rooms, - Taps and Accessories, Information and ... Low water pressure can cause your boiler to turn itself off. ... boiler is not turning off, you aren't getting the amount of hot water you require. ... If there is air in your central heating system, then your boiler may shut down.
Feb 09, 2016 | Water Water Heaters
Boiler won't ignite for hot water unless heating is on.
If this is in a RV the propane monitoring valve may require more gas flow to turn on than the water heater requires. A central heating system requires substantial gas flow so when the monitoring valve opens to fire the central heating, there is enough gas flow to also fire the water heater.
Jan 26, 2016 | Water Water Heaters
Hi, I've a fagor feb20e Eco plus combi boiler in
There is a flow sensor in the circuit and it is not sensing the lower flow from just the hot water. When you put it on heat though it does.
May 31, 2013 | Water Heaters
The boiler does not fire when hot water is selected although the red light is on. However the boiler fires ok when central heating is switched on and this does then heat the water. Is the problem in the...
Hi. and you are correct, if the boiler fires when the controller is set for central heating to come on, but does not fire when calling for hot water, the controller is either faulty, or not programmed properly. This is what tells the boiler to do on command, so, this is all that it could be.If you no anything about this controller as far as how it is set up, is it a programmable one, voltage on it, does it have wiring terminals on it that are labeled and can you get to them? If you can, and the wires are labeled, you can jumper them out to see if you can bypass the circuitry and get it to fire up on a call for hot water. This is the way to test it, very easy. You have to look at the wiring schematics to find the wires that are 1-hot and 2- hot water control. Jump across the 2 wires and if it fires, the controller is faulty. Careful if this is a high voltage controller as 120/208/230 volt. Check this out first. It can still be done, you just have to be careful not to ground yourself out. It maybe 24 volts. If it is higher voltage, you can kill power and get a insulated lead/jumper wire with clips on each end. Clip them to the terminals you want to jump out and turn on power. This way you are not touching anything. Please let me know the outcome on this and please when rating me as being helpful to you, be kind. I thank you. I will be here if you have more questions or need my help.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor
Jun 17, 2010 | Heating & Cooling
MY VOKERA BOILER IS NOT WORKING I HAVE NO HOT WATER AND NO HEATING
try check in the water pressure on the boiler should be on 1.5 bar
Jun 01, 2010 | Heating & Cooling
Honeywell ST6400C programmer
Hi yes sound like it not working on hot water only it would check ou the wiring on this side
Jul 25, 2008 | Honeywell Programmable Thermostat Heater
Ruud Matching Split Air Conditioner Logo
73 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
