Question about Cell Phones
Everytime the screen lights comes nothing esle works
How do i log in to my notebook as i have no password
That's nothing serious. I have come across such issue a few days ago, and I tried to reset Windows password in safe mode but failed.Thanks to my friend David who introduced me to use Windows Password Reset , I solved my trouble in a few miniutes.Besides,he also taught me some methods esle as use reset disk, accessible administrator account ect.
In these methods always one could help you.
Mar 06, 2012 | Sony VAIO PCG-K27 Notebook
Hi, I have an Electrolux ESL 4115. It seems to be stuck on 50 degrees but wont start as usual when I close the door, the on/off button works and lights functioning as normal but that's all. Thanks
I had a similar problem - seemingly stuck or locked with a solid light showing (in my case on the 65 degree wash). Nothing seemed to unlock it. But when I closed it and went away to think about what to do next - some 5 minutes later - it made its end-of-cycle peeps. It now works fine. All I can think of is that I must have interrupted the previous wash cycle l was using before it had ended, and had left the door ajar. all it needed was the door closing for the cycle to finish. Does that help?
Sep 22, 2010 | Electrolux 24 in. ESI6220X Free-standing...
When i turn the phone on the screen lights up but nothing esle happens
Software in your mobile got affected. New software has to be installed in the mobile. Please visit your nearest mobile service center and ask them to flash the mobile.
Flashing is formatting and reinstalling the latest software that supports the mobile. Service providers will charge very less to flash the mobile and it will be done in less than 30 minutes. This will solve the issue.
Jun 26, 2010 | Lands Phones
Sanyo ces32wsd7-b set comes on with blue standby light and when you poer the tv up the standby light goes off but nothing esle happens
Favourite is the 1000uf/16Volt electrolytic capacitor (C806) in the middle of the PSU board. If the top of the can appears bulged then it has probably died. This can cause some thermal faults where it will operate when warm but not when cold, and accounts for some 'reluctant to start' faults. It is close to the heatsink, so use a high temperature rated replacement.
Jun 05, 2010 | Sanyo Televison & Video
My playstation has the light trun green yellow flashing red light
With your PS3 turned off, press and hold the Power button on the front of the PS3 for about 10 seconds (the system will beep as normal as it starts up but after 7-10 seconds it will beep again). The video settings should now be reverted. Doing this will also reset any theme settings. try this? seems to fix alot of issues.
Jan 22, 2010 | Sony PlayStation® 3 (80GB) Console
PC wont boot
The first thing to do would be to remove all non-essential hardware from the box, I mean everything. This will help isolate the problem.
Then remove all the RAM except the very basic amount. If it still doesn't work, swap out the installed RAM with the RAM you pulled possible and try it. This will isolate a RAM issue.
If that doesn't do it, you may also consider swapping out the video card. Before we go any further, try these things and report back.
Good Luck!
Jun 18, 2009 | ASUS P5AD2-E Premium Motherboard
Panasonic touchbook cf18
When I touch the touch pad my screen display goes off. it comes on sometimes by itself or when touch pad is touched. I have connected the toughbook to an external dispaly and can work no problems. help
Oct 22, 2008 | Panasonic TOUGHBOOK CF-18 Tablet PC
Tail light is out, brake and turn signal work
create your own earth wire off the original and screw/bolt to a good earth source.Nothing flash just a test if it works make a more permanant one
Oct 11, 2008 | 1998 Cadillac DeVille
I have windows vista and i can't find how to download software. Directions say to cancel out of found new software screen and nothing esle comes up.
you may want to check on Lexmark and Vista's compatibility list, if your printer is in the list you will be able to download and us ethe drivers, if not, my apologies but the pritner may not be compatible with Vista.
Lexmark and Vista Comatibility List.
Aug 18, 2008 | Lexmark Office Equipment & Supplies
Cell Phones Logo
18 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
