Question about Nokia 5800 XpressMusic Smartphone
The pins to connect my battery in my nokia 5800 has snapped off is this a common problem
  • 31 Answers
No this problem is not common in the 5800,
my advice would be take it to a repair shop and have them look at it would be cheaper then sending it to nokia
Posted on Jan 05, 2010
My nokia 5800 is switching on. But after i switched on, the display shows "NOKIA" until I take the battery off. my phone should ask my PIN code, but it shows only "NOKIA".
Your phone has either suffered a bad flash or you've dropped or mishandled it in such a way to damage the internal boards.
Either way, You'll need to replace it.
May 16, 2011 | Nokia 5800 XpressMusic Smartphone
As soon as i go on to camera it says unexpected error occurred.restart phone.why?
Nigel,
It seems that the firmware of the phone has got corrupted. Do the following:
1. Fully charge the battery and connect to a computer via the USB cable.
2. Fire up the Nokia PC Suite.
3. From the PC Suite, backup the data.
4. From the PC Suite, update the firmware.
5. From the PC Suite, restore the data.
Live happily everafter.
Apr 03, 2011 | Nokia 5800 XpressMusic Smartphone
Hi, I have a Nokia 5800 (S60V5), I have being experiencing the following, 1. When the phone is in standby mode, 2. There is "no network" or sometimes "sim registration failed" 2....
Hi sir, 1) It asks the pin code since you or others set it in the settings-> security setting->PIN code request. If its ON state, You have to change to off mode. That time it will ask you the pin code. If you don't know the pin try with 1234 or 12345. Remember don't try more than tree times. It will get locked.Or Call the service provider for of your SIM from other mobile and get the PIN code from them.
2)If its restarting again then the problem is with the mobile OS(software). It can be solved only after changing the OS. For that you have to go to a Mobile Service Shop.
Mar 01, 2011 | Nokia 5800 XpressMusic Smartphone
Configuration settings PIN code
Try Hard Reset your Phone
or
Here's a hints on how to repair or fix Nokia 5800 XpressMusic Digi Mic Knopfler problem issues.
A guide picture below which I included an schematic diagram shows each every components and line paths for quick test and check up procedures.
Digi Mic Knopfler Pin configuration:
1. L/R - microphone's left and right audio signals groundings
2. CLK - Audio Clock data
3. Data - Digital Microphone data
4. VDD - Power supply voltage
http://2.bp.blogspot.com/_8JZhVVmpICU/TBnMEY2FYyI/AAAAAAAAAiI/KWb0ERKLIPE/s400/digi+mic+knopfler+schematic.jpg
Locate and trace each and every components, line paths and corresponding connection as shown on a picture. The red highlighted components and line paths is for the power supply voltage which came from Power management IC (AVILMAS) Vsim2- approximately 2-3 volts.
Test and check this components and track the supply voltage from C220 to C2170 then through the digi mic knopfler pin 4.
http://4.bp.blogspot.com/_8JZhVVmpICU/TBnNuXjiK5I/AAAAAAAAAiM/zRyjq5oSGEA/s400/nokia+5800+xpressmusic+digi+mic+knopfler.jpg
The pink highlighted components and line paths is for Audio Clock data signal, which is came from the Audio Codec IC (Avilmas) then flow across R2201 and R2170 (valued 100ohms each) then to the Digi mic knopfler pin number 2. Check also the C2173 valued 22p Clock filter capacitor for possible damaged.
I included step by step procedures on the images like as follows:
* Check each components and line paths.
* Replace if found open or shorted
* Jumper the line paths if found open or cut
* Check or replace the digi mic knopfler for a quickest step might as possible.
http://4.bp.blogspot.com/_8JZhVVmpICU/TBnUknz7xAI/AAAAAAAAAiQ/McXux--YsDc/s320/nokia+5800+xpressmusic+digi+mic+knopfler+repair+gu ides.jpg
The microphone's digital data signals has also a line paths connected to the front side of the Printed circuit board, check and trace also this line paths which is connected to digi mic knopfler's pin 4
Feb 17, 2011 | Nokia 5800 XpressMusic Smartphone
Firstly,the little gold pin that is the charging point on the fone where the charger is connected,broke off so i am unable to charge my fone so i have been temporarely taking my charger out my fone and...
No,
if your daughter's phone has a Bl-5j battery.
and yes if not.
Another thing switching off of the phone is a virus issue and please format your memory card for this
Sep 15, 2010 | Nokia 5800 XpressMusic Smartphone
Why does my nokia 5800 keep switching off when calling or recieving calls?
Hi s33ty23,
The problem (at least on my phone) is related to the connection between the battery and the phone pins. Apparently, the space where the battery is located is just a little bit bigger than what it’s supposed to be, and the battery slides just enough to break the connection to the pins.
Easily solvable by inserting a little something below the battery, to push it up a bit,,,,,,
good luck with your fix,,,
have a nice day,,
Regards
Arul
Mar 07, 2010 | Nokia 5800 XpressMusic Smartphone
Bloqued nokia 5800 at turnig it on
upgrade ur phones firmware and also format ur phone.. new upgraded firmware will surely help u
Aug 14, 2009 | Nokia 5800 XpressMusic Smartphone
My Nokia 5800 will not turn on. It only vibrates.
  1. With your 5800 turned off,
  2. Press and hold [Green] + [Red] + [Camera] Keys
  3. Turn phone ON, and keep pressing it until you see the Nokia Shaking Hands Logo.
The phone will be factory reset. If asked, default code is 12345. My phone did not ask- only the normal SIM PIN.
Jun 10, 2009 | Nokia 5800 XpressMusic Smartphone
Nokia 5800 XpressMusic Smartphone Logo
116 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
