I have Bose 701 II speakers with an active subwoofer built in the left speaker. Very recently (after 6 years if use), it stopped working. 1- I tested the power cable connected and it works. 2- Even if I am sure that electric power is reaching, there is no sign that subwoofer gets it. Looks like a fuse went off. Nothing happens when I turn on or off the power switch on the unit. It may be a fuse went off but do not know where to check... I am a good handyman and can get it fixed if I know where to look at.
  • 1 more comment
  • cenktukel Nov 20, 2009
    Thank you for your reply...
    Can you pls help with some more questions:
    1) Is this a generic answer or a well studied answer for the Bose 701 II speakers?
    2) If this is specific to Bose 701 II speakers (which has the subwoofer built in the left speaker box), how can I remove the speaker out of the box?
    Thank you,
    Cenk
  • cenktukel Nov 23, 2009
    Yes, they do have a separate power supply and as I said before; the subwoofer was working until recently (for the last 5 years) and stopped working couple of weeks ago all of a sudden.
  • cenktukel Nov 26, 2009
    Thank you... The fuse was the issue and replacing it solved the problem. I just did not know how to get to the fuse and you helped me. Thank you :-)
  • 566 Answers
If there is no fuseholder at the back then you will have to remove they power amp unit along with the power supply ***`y. You`ll find the fuse inside by following the power cord, usually on a fuse holder, that is the primary side of your power supply. On the secondary side of that transformer and mounted on the p.supply board you may also find two or more d.c line fuses. Try and replace them with the same value but if they blow right back then you have a power amp problem or a short in the power supply. Don`t forget to unplug before getting your fingers in there.
Hope this will help. Good luck
Posted on Nov 24, 2009
  • Jacques Marin
    Jacques Marin Nov 26, 2009
    Hi cenktukel
    I`m glad that it fixed your problem.
    Would have but surprised that it would be otherwise because of your speakers protection circuit.
    To answer your first question , lets say that it can be generic to all powered subs, and although i know the design of your system i never had the chance to work on them(too good a design i guess).
    For your second question; All i can tell you is that you have an 8" sub in each of the boxes and unless you have a problem with them , it might be a good idea not to break the seal or loosen them up.
  • Jacques Marin
    About the sub.
    We talking about high pressure sound level where even the type of glue used to mount the cabinet will affect the sound, so any loosening may end up in a rattle later on.
  • 244 Answers
Do the speakers have a separate power supply? Check to see if you have the proper voltage comming from the P/S.
Posted on Nov 21, 2009
  • 3,741 Answers
Check all of your speaker wiring connections, even take the speaker out of it's box and make sure all of the connections are solid. make sure your amp is turning on and your rca cable is plugged into the radio head unit and the amp. if all else fails, remove the speaker from the box, and to check if the speaker is actually dead, take a 9v battery and connect the + terminal to the + terminal on the sub and do the same for the -. the sub will make a popping noise every time you touch them together.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Posted on Nov 14, 2009
  • charlymonty Nov 24, 2009
    check out for the fuse on the power supply board of the speaker/woofer as there is a safety fuse located on the power supply board to save the board if any short circuit occurs.if the fuse blows the power supply stops working and replacing the fuse solves the issue.but if the fuse is ok then it can be problem of amp IC on the board.the ic needs replacement.but for amp ic replacement the board needs to be checked by meter to locate the short on the board.other if you directly replace the ic it will again get blown out due to short in the board.
    if you are not familiar
    with doing this you can get it done by local electronics repair technician familiar with
    this model.
    you for using fixya
  • charlymonty Nov 26, 2009
    thanks for keeping updated.good to hear that it worked.
I have a Bose Acoustimass 6 Series III the receiver is Yamaha 3066, this system is a 5.1 surround sound. Then I bought a pair of Bose 901 Series VI Direct/Reflective speaker system with active equaliz
The setup is possible, but with several compromises. First off, to use the active equalizer, you'll need to insert this into one of the 2 channel AV channels limiting your listening with the equalizer to stereo only. The acoustimass subwoofer acts a driver/power regulator for the little cube speakers. It probably will not be able to drive the 901s at the correct level when attached to the Acoustimass unit as front left/right speakers. You could try running a dedicated set of speaker leads to the 901s which may work and still allow surround sound, but you'll lose the equalization capability on the 901s.
Jan 21, 2015 | Bose Audio Players & Recorders
Does bose 701 series ii have a fuse for power subwoofer?
Fuses are used to control the inflow and outflow of electrical current. They are mainly used in speakers in order to protect them from being blown out. This is why there is a specific number of ohms on the instructions that it can handle. I'm sure there is somewhere. There are fuses in all high quality speaker systems. You'd just have to open the back up in order to find it.
Jun 18, 2011 | Bose 701 Main / Stereo Speaker
Bose 901 series 6 equlaizer problem
Only a careful experiment with steadily increasing volume would reveal the answer. Or measure the resistance of your cobbled work to see if it sufficiently high to avoid amplifier stress.
Original Bose 901 drivers in many series' are available on eBay and other places. I would NOT mix drivers within an enclosure. They should all match in every respect. Bose typically uses some very low impedance that totals to 8-ohms as wired inside.
There are many 'golden ears' who have used 901's without the Active EQ at all or improperly configured and they have been happy with the sound. Sonic beauty is in the ear of the beholder.
I would NOT forgo the EQ.
Jul 11, 2010 | Bose 901 VI Main / Stereo Speaker
My audio plugs had broke off, is there replacement parts and how much, mod# dv 7010
i lost speaker plug for bose 701 series ii so where do i find it
Aug 12, 2009 | Audio Players & Recorders
Can I hook the reciever to mm bose subwoofer and 5
if bose unit has built in amplifier .Then your sherwood would have to have a variable RCA output jacks in order to work with sub.Then bose audio input RCA cable would connect there.If bose unit does not have built in amp .Then you would connect sherwood left/right speaker outputs into bose left/right inputs .Then other bose speakers will connect to bose unit
Jul 30, 2009 | Sherwood RX-4105 Receiver
I have Harmon Kardon AVR 25 ii receivers and I have attached it to Bose 701 front speakers and three other Bose surround speakers and an subwoofer. All the speakers work except for right speaker, I need...
To locate the problem...a) Cable
Test if right cable is ok, by interchanging the rt/left cables.
b) Test Bose right speaker
Connect the Bose right speaker to HK's left channel. Works? Then Bose right speaker is ok.
c) Test HK's right output by connecting the left Bose speaker to HK's right output.
Does not work?
Jun 16, 2009 | Audio Players & Recorders
Sound comes only fron one rear speaker
Did you try switching Speakers A and Speakers B button on the AV receiver?
Jan 10, 2009 | Bose Acoustimass 10 III System
5.1 Home Theatre - PC
Its due to 2.1 channel sound input from your PC. Your Laptop supports only 2.1 channel sound so all the 5 speakers cant be played at a time! You need 5.1 channel input to work all 5 speakers
Dec 07, 2007 | Bose 701 Main / Stereo Speaker
Bose 901 speakers the wiring inside
- Bose 901 Series I and II speakers have 8 Ohm impedance each.
- A row of 3 speakers in series gives you 24 Ohm.
- 3 parallel rows gives you finally 8 Ohm.
Front with 8 speakers (view from the rear):
(1) (3) (5) (7)
(2) (4) (6) (8)
Rear speaker is number (9)
Row 1: -(1)+ -(3)+ -(7)+
Row 2: -(5)+ -(9)+ -(2)+
Row 3: -(8)+ -(6)+ -(4)+
Oct 30, 2007 | Bose 901 VI Main / Stereo Speaker
197 people viewed this question
 Grubhead
Grubhead
