Question about Magellan Maestro 3140 GPS Devices
Battery does not keep a charge. Can the battery
The battery in my Magellan Maestro 3140 does not keep a charge. Can the battery be replaced?
    President:
  • 1,111 Answers
Yes, the batter can be re placed, but i would verify its charging before buying a battery.
make sure green light is on the car charger (or a known good charger0 and let it plugged in for awhile, then hold the power button (up to ten seconds) until it starts..
after its started, go to the system setting. the battery meter should be moving left to right. if its all green and turns off when unplugged, the battery needs replaced.
your part # for your battery should be 37-00030-001you can get a battery HERE but verify your unit with the seller.
if it only has a few bars and is not moving while plugged it, it is not charging.
this is a very common problem for the models listed below.
the following magellan 2000, 2200t, 2500, 3000, 3100, 3140, 4000, 4040, 4050 and the 6000 are known to have faulty dc connectors...if your magellan gps is not charging or will not power up, its most likely the dc power port...
you can get help to repaired it, here
or buy the port here
if you need further help, just let me know.
Posted on Nov 14, 2009
Magellan Maestro GPS #MM3225. Screen display this
The unit is now connected to your computer, and you can actually access its filesystem through windows. It is also charging the battery in the unit. I wouldn't want to mess around with the files, though, unless you know absolutely what you are doing. Plus, it's also a good idea to turn the unit off before removing it from the computer.
Apr 18, 2010 | Magellan Maestro 3140 GPS Devices
Magellan Maestro 3140 touch screen alignment
I have the same problem. It seems the only answer is to purchase another GPS. I am looking at the Garmin 765T
Jan 05, 2010 | Magellan Maestro 3140 GPS Devices
Magellan maestro 3140 wont power up/start anymore??? Is it dead?
hi ohh_bambino plug it in and let it charge for awhile using a know good charger, like the car charger. it has a indicator light to let you know its charging.
now press and hold the power button for up to ten seconds until it starts. if that fails
bill
Nov 19, 2009 | Magellan Maestro 3140 GPS Devices
I can't tell if my magellan maestro 4000 gps is charging.
this could be happening for a few reasons but the most common is that its probably not charging.
before checking anything else, plug your 4000 in to a known good charger, then press and hold the power button for up to ten seconds till it starts.
if that fails, its likely not charging
this is very common problem with this and many model magellans.
Nov 09, 2009 | Magellan Maestro 4000 GPS
Magellan 3140 wants to shut down even when plugged in
this is a very common problem with these magellan 3140 and als the 3100,2000,2200t,2500,4000,4040 and the 4050
most likely the power port is damaged and needs replaced.i have these power ports but often they just need resoldered..i can repair thesemagellan gps if you need help. if i cant fix it there is no charge.wmetz@comcast.net ...
to open the case on a 4040 you must start on the powerbutton side, otherwise youll break the unit
May 29, 2009 | Magellan Maestro 3140 GPS Devices
Wants to shut down even when plugged in
this is a very common problem with these magellan 3140 and also the 3100,2000,2200t,2500,4000,4040 and the 4050 most likely the power port is damaged and needs replaced.i have these power ports but often they just need re soldered..i can repair these magellan gps if you need help. if i cant fix it there is no charge.wmetz@comcast.net ... to open the case on a 4040 you must start on the power button side, otherwise you'll break the unit
May 24, 2009 | Magellan Maestro 3140 GPS Devices
Magellan maestro screen not coming on
if you have a 3100 or 3140 as you have pictured..they cant be charged via USB..you need a home or car charger
May 10, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
Magellan Maestro 3140 blanks out
There seems to be issues with magellan batterys, being subjected to the cold has also been proven to effect the battery life, magellan offers a 1 year service on all units. I hope this has answered your question.
Jan 14, 2009 | Magellan Maestro 3200 GPS
Magellan Maestro 3140 GPS Devices Logo
198 people viewed this question
Top Magellan GPS Experts
Jungle Ghost
Jungle Ghost
Are you a Magellan GPS Expert? Answer questions, earn points and help others
