Question about Amana Refrigerators
Freezer fan now working - Amana Refrigerators
  • Amana Master
  • 4,654 Answers
OK then you make sure it's unpluged so the compressor will not overcooled and damage will happen to compressor. If you can tell me the model number I could help you. We will call this a solution if you can get the model number and even if you don;t you may need to find out whuy the fan does not work. Sometimes they are bad and sometimes part of a control system is not letting the fan run. What I mean about the compressor getting too cold is true. The fan takes the heat from inside the refrigerator out if the fan inside does not work the freon returning to the compressor is abot minus 20 degrees and too difficult for the compressor pump.
Posted on Nov 14, 2009
  • John Tripp
    John Tripp Nov 14, 2009
    Here is a photo of the places to look for the Amana number.
    I will look soon for a reply, Thanks, Sea Breeze
Upper part of freezer not freezing
  • When the top half of a freezer is not working properly it is a sign that the air circulation within the freezer is not functioning. In other words, the freezer refrigerant is still working properly, but the cold air it produces isn't going anywhere: Instead, it is sinking to the bottom of the freezer (heat rises) where it does an excellent job of keeping that half of the freezer cold while missing the top section entirely.
  • The air circulation problem is usually caused by a fan issue. Find where your fan connects to the refrigerant system and pumps the air out into the freezer. If the fan blades are stuck or frozen, you may be able to loosen them or replace the fan. If the fan works mechanically but does not turn on the problem lies with the motor instead. In this case, you can replace the motor or call a professional it may also be fan or evaporator
Dec 07, 2013 | GE 13.7 cu. ft. General Electric Upright...
My refrigerator is not getting cold
Is the freezer freezing? Do you hear a fan motor running inside the freezer? If the freezer fan is working and the freezer is still getting cold, do you see allot of frost on the back wall of the freezer?
Freezer not cooling at all - t-stat or compressor would be where to check next
No fan running in freezer and freezer is cold - bad evaporator fan motor.
If fan is running and you have heavy frost on the back wall of freezer - unit is not defrosting. could be defrost timer or defrost t-stat
Mar 12, 2013 | Amana Refrigerators
Good morning: I used you trouble shooting web page. Went home and de-iced my fridge freezer. The bottom fan (at the bottom in the back) is working but the fan in the freezer is not going. Does this fan...
HI,
It is possible your fan motor in the freezer has failed and by not moving air into the upper chamber can cause frosting on the back wall of the freezer. Also lack of air movement can cause your air returns to seal shut with ice and still not work if your fan is replaced. The part number your will need is 63001057 for the fan motor itself. I would verify all air ports are open when you replace the fan motor. It not a difficult job, access would take a bit to get into the back wall of the freezer to replace the motor. Amana has been known to use fan delays to pre-chill evaporator before allowing the fan to run, if our model does this, the thermostat in the freezer would need to be checked also. When the thermostat closes, it sends power to the fan motor to run, if it fails, fan does not work. I would check this prior to ordering of replacing the fan.
Kidlmo
Jul 26, 2011 | Amana ATB1832AR Top Freezer Refrigerator
The freezer works the frig doesnt get cold but its not warm just mild
open the freezer and at the back is a fan with a cover check the fan operation and housing if fan iced over or ice or debris blocking [food bag ]clear and check operation if fan doesnt work at all check power if power good replace fan if fan good check in fridge side for operation of flapper where air from freezer enters may be stuck or blocked air from freezer controls ur fridge side --if freezer side works than one of above problems which are the most common should get u back on line
Jan 19, 2011 | Admiral Refrigerators
Refrigerator warm, freezer fine, condensor fan not working.
yes and it is the evaporator fan inside the freezer, and condenser fan near compressor
Mar 25, 2010 | Refrigerators
Freezer working but fan not on in fridge - where to locate fan?
May be ice build up - happened with mine. Had to defrost completely (unplug for 24+ hours) then it worked fine on restarting.
Aug 15, 2009 | Amana ABB1927DE Bottom Freezer...
Freezer working,refrigerator not
the Freezer Fan supplies air for the frig as well as the freezer. If the fan is not spining fast enough the freezer will work but not the frig. Replace the Fan
Jul 25, 2009 | KitchenAid KBFA25ER Bottom Freezer French...
Refrigerator compartment cools correctly for a few days then no longer receives cold air from freezer. The freezer continues to operate and gets much colder than it should.
does your fan blow? freezers have a fan that pushes cold air to the fridge side if fan is bad freezer will run extremely cold and fridge won't cool down and since frige won't cool down thermostat in fridge doesn't tell compressor to stop
Feb 26, 2009 | Refrigerators
Refrigerators Logo
74 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
