Question about Garden
I have an LTX 1050 and the caster on the front tires causes the tires to literally cut furrows in my turf now that it's wet. The front tires appear to almost ''roll to the sidewalls'' during left or right turns. My retailer has been absolutely no help at all. Is there any chance that there may be a new front axle assembly that would eliminate this short turn ''roll over'' issue that is totally unacceptable?
  • 437 Answers
It sounds like the bearings in the wheels or frame have worn out due to lack of lubrication. Go to www.cubcadet.com.
You put in your model number in the unknown part search. It will show your model and the parts with diagrams. The bearings are plastic. You may be able to find some ball bearing but the manufacturer does not make them for this unit.
Good Day.
Posted on Nov 14, 2009
When pushing on drive pedal, it doesn't move.
trans disengaged, bad belt, low trans fluid, linkage came off, brake is stuck. take your pick
May 19, 2016 | Cub Cadet 2011 - LTX 1050 - 22 HP Kawasaki...
How do I remove the fuse?
I pull them with a regular pair of pliers.
George
Aug 03, 2015 | Cub Cadet 2011 - LTX 1050 - 22 HP Kawasaki...
Will a wiring harness from a ltx 1045 fit a ltx 1050
Since the LTX1050 has an electric PTO and the LTX 1045 has a manual PTO then I would say no.
May 10, 2015 | Cub Cadet LTX 1050 KW 50" 23HP Kawasaki...
After cutting the grass with a Cub Cadet 1050 after it set for hours the engine
check for water in gas espeially if you leave outside in rain try shooting some starting fluid in it see if it starts up drain gas and fuel lines install new gas fresh not same gas
Sep 02, 2014 | Cub Cadet LTX 1050 KW 50" 23HP Kawasaki...
What causes front tire wear on inside & outside edges
Under inflation. When the tire doesn't have enough air pressure, the center tends to be pushed up from the road. Thus causing outer wear on both sides. alignment problems cause wear on one side or the other. Over inflation causes the center of the tire to wear .
Aug 31, 2014 | Cars & Trucks
Oil light on ltx 1050 cmes on after starting engine but it's full of oil
oil light indicate oil PRESSURE not volume... replace the filter which may be blocking oil flow, and then see about replacing the oil pump
Jul 04, 2014 | Cub Cadet 2011 - LTX 1050 - 22 HP Kawasaki...
Cub cadet ltx 1050 extension spring where does it go
In case anyone has a 2014 Cub Cadet LTX 1050 KW and needs to know where the damned spring goes when it falls off when removing the belt keeper, here's a photo.
Jul 15, 2012 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
I have a 2002 daewoo nubira cdx
Well without seeing it I don't know whats bent or not but your caster angle causes a pull since it is pulling right you need to add more caster to the right side or make the left side caster less.If it is the tires rotate left front to the right front and the right front to the left if it goes straight or pulls left its in the tires if it still goes right its in the alignment.
Jun 15, 2009 | 2002 Daewoo Nubira
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
