Question about Whirlpool MH7135XE Microwave Oven
Stuck light bulb in micro wave hood.
Hello! The bulb in my Whirlpool microwave oven hood blew out. When I took the cover off to unsrew the bulb, all the bulb does is spin like the threads are stripped. But when I turn the other way, it tightens right back up. Am i trying to remove the bulb the wrong way, or did I mess up something? Thanks!
  • Anonymous Jan 08, 2008
    had the same problem they put silicone to stop the bulb from loosing. have to break off the glass part of the bulb and use needle nose pliers to unscrew
  • spierson Mar 05, 2008
    My husband went to change a light bulb and the other light blub blew, now my vent and lights don't work. What's wrong and what needs replacing?
  • Whirlpool Master
  • 9,098 Answers
Be sure the oven is unplugged from the wall first.
In many cases, you have to break out the glass from the bulb and then use small needlenose pliers to unscrew the bulb base.
Once you get the lamps replaced, if they won't turn on or turn off, then you also have a damaged circuit board, which we regularly repair nationwide for $39.95 postpaid.
Details are at our site, linked is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jan 14, 2008
How to replace light bulb in Model # wmh31017FW-0 Micro wave oven
http://www.appliancepartspros.com/parts-for-whirlpool-wmh31017fw0.html
Jul 04, 2018 | In Microwave Ovens
I have a GE micro ange hood Model# HVM1540DM1BB, bulbs blew,change them out, now the lights will not shut off. I have powered it down over night, pluged it back in next morning same thing. Any ideas
There is a possibility that the light relay is stuck on. Sometimes a sharp tap on the relay will fix it. If not the control board will need replacing.
Sep 26, 2014 | GE Microwave Ovens
Micro wave range light blew out when turned on. Removed old bulb and it had some white plastic melted on it. Replaced the bulb, and the light doesn't work.
Your going to need to disassemble the light fixture to perform electrical work. Its possible in the process that you may have accidently blown something else. If so, be prepared to peform
units soldered connections on the main projection board warm up as the system warms up. Thus, the loose capacitors, resisters, and diodes are causing the CHANGE when the system warms up. When metal contracts, it expands thus losing the connection needed for a solid connection. This process is normal after the units have reached their service life. Keep in mind that you can repair this but at the expense of time if you have never performed this type of work.
Jan 26, 2011 | Whirlpool MH7140XF Microwave Oven
Hello... i have a GH4184XSB-1 microwave/hood-oven combo. I was removing the light bulbs --- which were broken off from the glass to the metal bottom --- and the unit's electricity blew. Breaker is...
there are some other fuses on some circuit boards inside the oven.Try finding them,one is located on the control panel PCB.Perhaps that is blown!
Aug 23, 2010 | Whirlpool Microwave Ovens
Why would my microwave no longer heat or cook?
micro waves use a tube inside that generates micro waves and like a light bulb they eventually blow out. the tube is not considered replaceable and cheaper to just get new unit.
Apr 23, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
The range-top light blew and now replacement bulbs
My Whirlpool/Roper microwave/hood combo has the same problem. I replaced the bulb twice, checked the bulb and it works, but not in the microwave. I wrote to Whirlpool asking about the problem. Haven't heard from them yet.
Apr 02, 2010 | Whirlpool MH1150XMQ Microwave Oven
The microwave stopped heating the food. Power
The light inside the micro wave needs to be replaced most have a door on the back side that yo can remove the screw and unscrew the bulb and take to a applince shop and purchance a new one to replace.
Jul 16, 2009 | Whirlpool GH4155XP Microwave Oven
Kenmore 363.6367 internal light doesn't go on
I had the same problem! I was soooo frustrated! But, when my brother came to town, he took off the grill on the top of the micro hood, took out a few more screws, a plastic screen, another screw in the metal cover for the light and then reached in with his fingers to pull out the light bulb, we replaced it, then re-assembled it. It did take us about 30 minutes to do the job and you will need a phillips screwdriver, and a phillips screwdriver drill bit thing, but we were able to do it. I love having the light in the microhood again.
Dec 09, 2008 | Kenmore 63672 Convection/Microwave Oven
Whirlpool Accubake Microwave Oven 2001 vintage.
Hello jparks739,
Please find a link to an exploded view of you micro as well as details on how it goes together. Note the two screws ( item 31) that hold the cover and lens over the bulb in this document.
Hope this helps you..
http://www.pcappliancerepair.com/model-display.php
Regards,
Rick
Dec 03, 2008 | Whirlpool GH5176XPT microwave Oven
Whirlpool MH7135XE Microwave Oven Logo
139 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
