Question about Axiom Audio Axiom 80GB for Dell Inspiron 9100 and XPS Series (AXD2080) Hard Drive
60 gb hdd does nor allow repartition - Axiom Audio Axiom 80GB for Dell Inspiron 9100 and XPS Series (AXD2080) Hard Drive
    Champion:
  • 206 Answers
If you are reinstalling your system, it is possible that you need to change something in the BIOS settings. If your HDD is SATA, it is very likely that you need to go to BIOS setup, HDD setup, and change it. There are several options of how it may look, so whatever it is, just switch it to an other option (there are only two options every time). Try then
Posted on Nov 14, 2009
SEAGATE hdd ST2000DL003. How do I get this HDD up and running?
Depending upon what kind of computer you are using, you might have to use an application which will allow you to partition this 2TB drive into smaller pieces. It is entirely possible that you have an older BIOS in your computer, or not enough RAM Memory, which will not allow you to deal with the new HDD in its full capacity, but will allow you to use it if repartitioned into smaller chunks, like 500 GB each. If so, making four 500 GB partitions in your 2 TB drive will be just as effective, but will give you four more drive labels, like G, H, I, and J to which you can write.
Good luck,
-a.
May 31, 2012 | Seagate HDD ST2000DL003 2TB SATA 6GbS...
Dear Sir, My HDD Details : - Model : HD161GJ HDD P/N : HD161GJ LBA 312,581,808 160.0GB S/N : S14DJ90Z446270 P/N : 61763-A71A-A63JX my problem is on this HDD any OS installed, this OS In...
You may have a bad sector where the OS resides on the drive. Download what is called a low-level formatter. This software is designed to lay down the actual tracks where data is stored. It is different that formatting with the OS. This will put the drive back to the original unformatted condition. After you do the low-level format, you will need to format the drive again with whatever version of OS you use.
Apr 16, 2017 | Computers & Internet
I recently inserted a second Harddisk into my desktop which has a capacity of 80 Gb but when go and check my disk size in windows it shows as 9.9 Gb.. anobody know how to fix this. I'm running on...
Hi Good day!! Maybe the HDD that you've been inserted was a cloned HDD, my solution to this was to format the HDD that you've been inserted..
Oct 08, 2010 | Computers & Internet
HELP.What Happened to 40 GB Space???
You may have to try to repartition the drive, you can do this while installing windows on the disk. If a partition table is corrupted it can make windows think there is more pr less space on a disk, Ive had tables corrupted so bad on dying drives they reported 999999999 gb on a 40 gb drive. you may want to look into getting a new hard drive as well if this is occurring.
Aug 02, 2010 | Fujitsu Siemens (MHV2060AH) 60 GB Hard...
How to remove write protect frm pen drive
You should be able to use partitioning software on the drive Just as you would on a failed HDD.
Do a Google search for Free Partitioning software, there are many avail out there.
Once your drive is repartitioned, You should be OK.
Jun 08, 2010 | Transcend 160Gb StoreJet 25 Unveils Rugged...
Hdd does not setup xp
You can use Partition Magic. By this software, you can repartition your HDD & Hide the partition that have BAD sector. Make a new partition without bad sector space & active it as a primary partition. That's ok. Now you can install XP.
Feb 11, 2009 | Quantum (SE21S011) 2.1 GB Hard Drive
Removed partitions. Now 'My Computer' doesn't see HDD.
You may want to use a program called Partition Magic to repartition your hard drive. You can try using the Disk Management Service built in to Windows 2000, XP, and Vista. This is available in "Computer Management" in Administrative Tools in the Control Panel.
Please note that after removing a partition, you need to create a new one then format it before the operating system can read it.
Hope this helps!
Oct 17, 2008 | Seagate Barracuda 7200.7 40 GB Hard Drive
Splitting a 80 gig hdd into 2 sections
Hello douglasc, You will have to repartition your hard drive. I would suggest the use of an application called partition magic. It will allow you to partition your hard drive even though the OS is present on the system. It does this by first defragmenting your hard drive and the putting the unused sectors together and the used sectors together this way it makes the division of the sections easier. Now once the hard drive is defragmented it allows you to section the drive into different logical hard drives. Follow the instructions from the documentation and you will have a successful repartitioning. Thank you, Shuttle83
Oct 08, 2007 | Audio Players & Recorders
Axiom Audio Axiom 80GB for Dell Inspiron 9100 and XPS Series (AXD2080) Hard Drive Logo
37 people viewed this question
Top Axiom Audio Computers & Internet Experts
David Payne
David Payne
Are you an Axiom Audio Computer and Internet Expert? Answer questions, earn points and help others
