Question about Vacuums
How do I replace the Powercord on a Fantom XT64K Vacuum. The powercord shorted where is comes out of teh housing. I need to open up the unit & replace but need a service manual of instructions. Thanks Father Lenny
  • 36 Answers
I have done this several times, it's some what simple just take the unit apart and use the old diogram to replace the new one. Or take a digital photo of it opened so you have your own scematic. You should be able to purchess the cord at your local hardware store "be sure you get the same insulated cord" the numbers will be located all down the old cord. Also very important. If you have never done this before I recomend you have someone with this type of knowledge. For safty reasons. good luck and hope you save some $$$$$
Posted on Nov 14, 2009
Eureka 4870 upright vacuum cleaner needs powercord replacement
If it's not too badly damage you can wrap it with black electrical tape
Oct 20, 2014 | Eureka Boss SmartVac Pet Lover Bagged...
How to replace a switch in a kirby sentria vacuum
you need to find your nearest Kirby service dealer as its got a lifetime guarantee and when they fix it for a fee they will go over it to make sure there is nothing else wrong with it.
Jun 26, 2014 | Kirby G5 Bagged Upright Vacuum
Replace belt on fantom cyclone vacuum? the manual does not decribe replacing the roller belt - i can't get it open to expose the belt
On my 10-year-old model, the two screws securing the cover are under the two llight bulbs. Pry off the clear plastic covers, take out the bulbs and screws, and the cover lifts off.
Dec 01, 2009 | Fantom Vacums Cyclone XT Upright Vacuum
Stopped running. won't turn on
check power cord or replaced Powercord Assy part no : 905449-04
check power switch or replaced power switch part no : 910971-01
Oct 01, 2009 | Dyson DC07 Allergy Blue/Turquoise Bagless...
How do I take my Miele S251i apart to be able to chenge the powercord?
HOW TO OPEN MIELE 251 VACCUUM: 1-Unplug from wall and disconnect power cord 2-Remove black switch panel at back of top panel: A-Use Phillips screwdriver, remove two silver screws visible between back of hinged top door and front of black switch panel
B-Push back of the panel down while pushing it forward (towards front of machine). There are two plastic notches and clips which are tightly fit together that you need to separate.
Once it releases, push it a bit more towards the front of the machine and lift off panel. It has wires connecting it to the main body so it will not remove completely.
C-Be careful not to lose the springs that simply sit inside of two plastic channels, one under each of the two switches. These are required for your witches to operate properly.
3-Locate screw at bottom of deep rectangular hole now revealed (under former location of black switch panels). Unscrew using Phillips screwdriver. 4-Open hinged top panel. Locate two silver screws, one on each side of main housing. Unscrew using Phillips screwdriver. 5-This will let you lift off the whole top assembly, door and main housing, revealing the plastic chassis and the motor unit within.
You now have access to the motor, wiring connector harnesses, circuit board and the cord reel.
Sep 13, 2008 | Miele S251i Plus Bagged Canister Vacuum
Believe the fuse is blown in my fantom fm760 vacuum. put the wrong kind of headlight in and when i turned it on it blew the breaker as well. took apart and the fuse is part of the powercord.
Unfortunately Fantom has been out of business since about 2001, so parts are very difficult to obtain. Your best bet would be to try to find the parts online or possibly at a vacuum store, but I would be very doubtful that you will be able to find the parts.
Good luck,
-R
Aug 04, 2008 | Vacuums
Replace Powercord
It has a cord relief to hold the cord in near the bottom, you will have to pull that out, the cord goes in there and comes out by the motor where the the wires connect. So you will have to pull the motor cover off to get to where they hook up to.
Apr 15, 2008 | Hoover Company Wind Tunnel U53019 Upright...
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
