Question about Samsung SGH-U700 Cellular Phone
Sensor is not working,i replaced the ribon alredy but no luck
Warning ribbon in V53.16.7Z
The "ribon in" warning is because you set the printer to print DIRECT THERMAL insted THERMAL TRANSFER. The first mode is for printing directly on the thermal labels, not for using a ribon. The ribon sensor detects that a ribon is pressent and you get this message. You need to change the printing mode to Thermal Transfer from the printer Setup Menu, or from the Print Driver instaled on PC.
Jan 19, 2015 | Zebra Office Equipment & Supplies
Anytime she goes to print a badge the ribbon breaks. It's the correct ribon. She's put in a new ribon and the same thing happens.
When the ribbon keeps breaking on fargo DTC300 or any similar models (the ones that share similar mechanics) three steps are to be taken.
1- Verify, clean, calibrate or replace the ribbon sensor (maybe you'll see an error like "Panel Searching" that means " the ribbon sensor can't read the ribbon panels normally).
2- Clean the "card path" (the feed and platen rollers) for dust dirt and debris using the manufacturer's cleaning kit (or a clean
lint-free cloth with isopropyl alcohol) and the "clean printer" option.
3- Clean the inside and outside of the printer (pay attention to the printhead) with dust-off, lint-free cloth, isipropyl alcohol and enjoy.
Or, for more advanced ts take it to a certified tech!
Mar 02, 2011 | Fargo DTC-300 Thermal Card Printer
Hi I have a new sanyo xacti vpc-ca9. It will not boot up - just a blinking red light on the top. The battery is charged and there is a 16GB SD card installed. Any ideas? Garth gartht@mac.com
I have the sam camcorder. It has the same problem. When you press the on/off button, it does not do any thing just red light blinking on the top. After wandering with buttons without really knowing what I am doing, I took it to Sanyo service center. They found the ribon connecting the LCD to main body being damaged. They replaced it and charged me $75 for that. After that the camcorder works good. I saw the ribon is very vulnerable. If you twist the camcorder just a little hard, that ribon may get shocked.
Aug 04, 2010 | Sanyo Xacti VPC-CA 9 Flash Media Camcorder
Out of ribbon p330i Zebra
possible need to recalibrate the sensors, go to driver, and send the command !SA.
May 06, 2010 | Zebra P330i Thermal Card Printer
My 1200p fax machine only prints half a page
This is a ribon transfer problem. Open the machine and see if the ribon has been mouving properly or fixi it inside the cartridge. GOOD LUCK.
Nov 21, 2008 | Brother Office Equipment & Supplies
Dont want that cold cuz iam already ther
The heater element sensor are open or fuse/ motor ok /flow of air ok heater is the problem.replace fuse or heat sensor if open.
Jan 08, 2008 | Heating & Cooling
The external screen stays blank
that happend to my phone and my friends phone. one thing to try is to replace the ribon. i dont know how to do it my self, but some people at phone stores might know how. my friends dad works at cingular and he said that replacing the ribon should fix the problem. and it cost about 40$
Nov 07, 2006 | Motorola Mobility RAZR V3
Samsung SGH-U700 Cellular Phone Logo
96 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
