I need help
When I turn it on it tells me to insert usb line and press the up key to use usbdisk and press down key to low formatting!!!! press other key to bios. What does all this mean? I really need help with this matter. Thanks
  • 36 Answers
Go into your bios, with whatever button it tells you to push. In there, look for anything that resembles Startup... Theres alot of menus I know, just use the arrow key to look through.... Once u see the start up menu, make sure the Harddisk is 1st (or in some bios, it has to be at the top of the list). To do this, there is a legend at the bottom (or top) of the screen that tells you which each computer key does for these menus. Use this, then, once its 1st (or at the top) of the other options, (other options being cd/dvd, usb, floppy, etc, varies computer to computer), push the save and close key (which again, is on the legend). Tell me if this works please>.<
Posted on Jan 09, 2008
FORMAT NEW HD
You have to format a hard drive with a third party disk unless its a usb data drive
Restart your computer
During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key this will vary depending on your operating system
Press and hold that key during the boot up process to enter BIOS then using the arrow keys navigate to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos restart
or if you are using a USB
insert your usb drive
click start right click on my computer select open you should see your USB drive
right click then select format
another way is to control panel administrive tools,computer management disk management right click on your drive select format
hope this helps
Jul 03, 2012 | Computers & Internet
Installation CD & Quick Guide
Follow this link for your manual, driver, and FAQ's http://www.megxon.com/techsupp/download/X3/X3_supp.htm Driver install 1. Download driver file "X3_Driver.exe" and save it to PC hard disk. 2. This driver file is a self-extracting archive, run it and it will extract automatic. 3. Run "X3 Driver.exe" and will show "WinRAR self-extracting archive" dialog. Press "Install" start extracting. 4. After, in hard disk will create a "X3 Driver" folder. 5. Enter "X3 Driver" folder and find "Install" folder. 6. Enter "Install" folder, find "SETUP.EXE" and run it. The installation wizard will guide you through the installation. -------------------------------------------------------------------------------- How to set the USB function to PC Camera or Storage mode (Regarding how to set the USB function to PC Camera or Storage mode, please reference user manual in page 42.) When connect DSC to PC, it will become a storage device or PC camera depend on the setting of USB in the setup mode. 1. Press the "Manu" button (in the back, left-up side of 5 ways switch) into Menu section. 2. Then press right key to "Setup". 3. Press down key to "USB" then press right key. 4. Press up or down key and change it to "PC camera" or "Storage". 5. Press "OK" key to confirm. -------------------------------------------------------------------------------- How to Format internal memory or memory card (Regarding how to format, please reference user manual page 27. ) > Formatting SD Card Prior to its initial usage, format the SD card. To format the SD card, please insert your compatible SD card into SD slot. Then proceed with the following steps: 1. In "Capture" mode, press "MENU" button into the setting mode. 2. You can see "Capture" and "Setup" in the screen. 3. Press right key to "Setup" then press down key to "Format". 4. Press right key to next step. 5. Press down key to "Confirm". 6. Press "OK" button to confirm. The SD card will be formatted. > Formatting the Internal Memory Take out SD card from the slot and format the Internal Memory by following the above mentioned steps . NOTICE 1. Prior to formatting the SD card, deactivate the ¡§Protect SD card¡¨ function. 2. The internal memory cannot be formatted when the SD card is in the camera.
Oct 03, 2007 | Megxon X33 Digital Camera
Sandisk ultra sdhc card won't record in my canon digital camera. i get a memory card error
All you have to do is
Step One
To save data, use EASEUS Data Recovery software (free version - 1GB of data recovery). how:
1. Download and install EASEUS Data Recovery
2. Insert micro SD
3. Open EASEUS Data Recovery, choose Complete Recovery - Next
4. Select the drive micro SD - Next
5. Save the data to the hard disk (max. 1GB)
6. Because of your micro SD 2GB, repeat the process of recovery (repeat step 2, 3, 4, 5)
After all data is secure, do the process repair micro SD
Step Two
The first alternative - use the software HP Drive Key Boot Utility
Using the HP Drive Key Boot Utility, for Win XP
1. Download and install the software HP Drive Key Boot Utility
2. Then, double click the file cp006049.exe - select Install.
3. Insert micro SD
4. Then, open the program "HP Drive Key Boot Utility" - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Create firmware flash package - Next - Finish.
5. Remove the micro SD from the USB port, then insert it again.
6. Quick format micro SD (FAT file system)
7. Restore all data, to the micro SD.
Using the HP Drive Key Boot Utility, for Win Vista or Seven
2. Then, double click the file cp006049.exe - select Extract
3. Insert micro SD
4. Then, double click file hpdkbu.exe - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Create firmware flash package - Next - Finish.
The second alternative - use software HDD Low Level Format Tool
1. Download and install HDD Low Level Format Tool
2. Insert micro SD
3. Open program HDD Low Level Format Tool, select micro SD - continue
4. Click S.M.A.R.T - click Get Smart Attributes
5. Click LOW LEVEL FORMAT - click Format this device
6. Wait until the process is complete - press OK
7. Remove the micro SD from the USB port, then insert it again.
8. Quick format micro SD (FAT file system)
9. Restore all data, to the micro SD.
I hope this information helps.
Oct 15, 2011 | SanDisk 2GB microSD Memory Card
I got Kingston DTI/64GB, when I insert in my PC - having windows XP- message occurs for FORMAT - I click on OK button, Format window open - Capacity shows 62.4GB, System= Nill, I select Quick format option...
first try to format in command line
Start
go to RUN
Type CMD and press enter key
in command window type format H:/fs:FAT (H: stand for my Pen Drive name change it if you have different)
press enter key
yes to all message appear
now you formatting start
if not so try this: 1000% work
download any low level formatting system and format from that or you need 3rd party formating tools like HP format tool to format RAW to FAT,
if still not work it mean your PEN Drive got Damaged and you have to purchase a new one.
Do vote me if this help you.
Jul 27, 2011 | Computers & Internet
Whenever i insert my pen drive and try to open it it says insert drive.its a 8gb transcend pendrive unable to open or format it. It says insert disk.
Do one thing download the transsend s/w from website and try to formate the pendrive
Otherwise instal the USBDISK andi virus and delete the some file from that pendrive.
Nov 17, 2010 | Computers & Internet
All the replacement burners I see are the H pattern,mine is straight and I don't see one listed.where do I find the right burner for my magnum 240 grill
i have one digital media player make blu sens he is show the message on screen insert usb line and press ok key to use usbdisk, press other key to cancel usbdisk. I am how to slove this
Mar 17, 2010 | Fiesta 240 Grill
Pen drive insert disk problem
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Jan 21, 2010 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
Mp4
I dont how to download music to my MP4 from the Internet and also from the media center.
May 20, 2008 | Apple iPod MP3 Player
ANKO MP3/4 Player Supposed to Show MPEGS, but Doesn't
When i turn off and turn on player it is saying "insert usb line to use usbdisk press any key to restart. then this is display on the screen "usb disk".
Problem is it is not loading u
Apr 04, 2008 | American Anko MP-2GD MP3 Player
Low level format
You need to punch in sequence of buttons: left+left, right+right, up, center, down This will make you to format the device completely. Once the format is done, you need to reset the player by pressing Record and Menu, both at the same time. Then turn the player ON, it will display message "USB device", that means, player has nothing on it and it is working as mass storage device only. Now you need to download the firmware from www.samsung.com and transfer two files MUON.ROM and SYSDATA.bin to root. Again reset the player by above mentioned sequence. turn the player on, and now you are back in business. Have a wonderful day. Enjoy Samsung player. Samsung rocks. - CHAMP
Jul 22, 2007 | Samsung Yepp YP-T9 Digital Media Player
Computers & Internet Logo
191 people viewed this question
Alun Cox
David Payne
David Payne
