Question about AOC LM729 17" LCD Monitor
Problem inAOC LM725 monitor
Audio window pops up goes off automatically very often in my AOC LM725 monitor
    Renaissance:
    An user who is expert in 3 categories / brands.
  • AOC Master
  • 848 Answers
Problem inAOC LM725 monitor? This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:service@wisiny.com.thanks,we sincerely hope we can help you!
you can also check this boards whether suit you:
715L1103 AOC IDPC7425A3 Power Supply for TFT1780PSA LM729
Posted on Dec 23, 2014
Maybe one of the volume buttons on the front panel control is randomly shorting. Check it out...
Posted on Dec 02, 2009
AOC 2036S won't connect to laptop
Is the cable working? try reducing your laptop screen resolution and connect to your monitor. Your monitor may not support full hd resolutions....
Jan 09, 2014 | AOC 2036S 20 INCH BLK LCD MONITOR
Can't find AOC LM725 driver for XP
click here to download the latest drivers you required.
May 12, 2010 | AOC 917Sw 19" LCD Monitor
MY MONITOR AOC LM725 GOES ON & OFF REPETEADLY ?
No, all you need to do is reset the monitor to factory settings. I fixed mine that way.
If your monitor goes off every 3 seconds (like mine did) you have to be fast or siwtch it on/off few times between the steps to get it fixed.
- 1st. unlock the OSD if when you press 'menu' you get the message 'OSD Locked'. To do this switch off the monitor, and press 'menu' while you switch it on again.
- 2nd. Switch it on, press 'menu' and quickly 'press '<' (left) twice and 'menu' twice to get it reset.
- 3rd switch it off and on again and if still goes off after 3/4 secs, try to reset it again.
I reset mine and it is working find. Before it went blank after 3 secs.
I just tried this because I did not understand why if it was a hardware problem I could see the screen for 2/3 seconds and if pressed on/off it came back, it made no sense as a hardware problem.
Dec 03, 2009 | AOC LM729 17" LCD Monitor
AOC LM725 Color Cycle
AOC brand are disposable, now if your going repair its chips, its definitely work or not... i tell you this monitor is very deliquate to work normally.... buy a new one...
Jun 16, 2009 | AOC LM729 17" LCD Monitor
AOC 17" LM725 TFT - cannot get any sound from the screen speakers
Ok what I need to know is if with the screen cable that goes to the back of your computer if there is an additional cable colored green if so you need to plug that into the back of your computer and then you should have sound. If there is no sound then please click on the sound icon at the bottom right of the screen and open up the mixer and see what device you have selected for the sound to go out of. If you have the option to please select the playback device that would go to your screen. If that doesn't work then contact customer support for your screen and see what they can do for you. Let me know if this help.
Apr 08, 2009 | AOC LM729 17" LCD Monitor
AOC LM725 Monitor Problem
Change the monitor and check if the PC works. If it works then the problem is with the monitor, you will have to send it to repair. If not then, the problem should be with the power supply, check whether all the cables is kept intact.
Mar 21, 2009 | Rosewill R900J 19" Flat Panel LCD Monitor
AOC LCD LM725 monitor - Black Screen
OK WELL DID YOU UNPLUG IT FOR A LIL WHILE? IF NOT DO SO. IF PROBLEM STILL THERE HOOK IT TO A DIFFERENT CPU AFTER ALL IS DONE HIT ME BACK
AOC LM725 LCD Monitor
try looking for bloated caps, check all diodes... see if its not shorted/leaking and finally check the power regulator ic if its not shorted! note: some capacitors and diodes are very tiny, you should use a lens with good amount of light...
if it does not help..... well, what the hell? try pouring some gas, then light it up! that should solve the problem, at least it turned on right? hehehehe!
Mar 21, 2009 | AOC LM729 17" LCD Monitor
Aoc lm725 display off after few seconds
I've had a very similar issue on many Dell Monitors. Mine have been under warranty and they usually send me a new monitor, but I believe the issue lies with the power supply within the monitor.
Jul 10, 2008 | AOC LM729 17" LCD Monitor
Unlocking of OSD in AOC LM725 Monitor
Solution #1 above fixed my problem. Turn the monitor off, then hold the left button down while turning it on again. Works like a charm!
Nov 29, 2007 | AOC LM742 17" LCD Monitor
AOC LM729 17" LCD Monitor Logo
260 people viewed this question
Top AOC Computers & Internet Experts
Jerry Umali
Raj Patel
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
