Question about Nintendo Wii Console
How to update Wii System Software - Nintendo Wii Console
Can not perform wii system update
The last system update for the wii was the 4.3 system update and that was in September 7 2010. There should no be any other update If it is giving you an error code look it up in this website Error Code Lookup Wii and Wii mini Nintendo Support this might also help Unable to Perform System Update Nintendo Support
Mar 30, 2016 | Nintendo Wii Console
Cant find icon to connect to netflix
you must update you Wii software to get Netflix to do this , go into the Wii channel and log to options then select system update. select I Agree the Wii will connect to nintendo and will update the sofrware.you will then have Netflix.
wagpar
Jan 14, 2013 | Nintendo Wii Console
The Wii console light will turn green
Hi sharonkayh,
Try the following:
1) Completely power down your system by pressing the power button for 10 seconds. If that doesn't work, unplug the AC Adapter from the Wii for a moment, then plug it back in.
2) Make sure your Wii console has the most current Wii system menu. Download the latest update, and then test your Wii console to determine if the problem has been resolved.
This is done by:
  1. Make sure your Wii console is successfully connected online.
  2. Access the Wii System Settings.
  3. Click on the blue arrow twice to reach the Wii System Settings 3 menu options.
  4. Select "Wii System Update" and press the A Button.
  5. Select "Yes," and read any messaging regarding obtaining the update. If you agree to the messaging, select "I Accept."
  6. The Wii console will now search for the latest Wii System Update.
  7. If an update is available, it will be downloaded and installed automatically.
I hope this can help you - Source: Nintendo Website.
Kind Regards
JEDEMEYER1
* If this solution helped you, please accept it
Sep 05, 2011 | Nintendo Wii Console
Error code 32017 keeps coming up on my wii console. i can still connect to the internet on my wii and play games but whenever i put in super smash bros it requires a system update. it will begin but never...
Error Code: 32017 There appears to be an issue with updating your Wii console.
  1. Try and perform another Wii System Update on your Wii console (how to).
  2. If you attempt another Wii System Update and still receive this error code, please call 1-800-255-3700 so that we may assist you further.
Mar 03, 2010 | Nintendo Wii Console
Wii system - unable to read disc
Do a update to the system software, you must have internet for this. Or run the update on the game disk(turn on updates) in the system menu
Jan 01, 2010 | Nintendo Wii Console
Cant find my wii menu
You will need to remove all unauthorized software from you Wii console.
1. Press and hold the POWER button until the Wii shuts off and the power LED turns red.
2. Press the POWER button again to restart the Wii.
3. Go to Wii Settings and run Wii System Update.
The latest update will remove all unauthorized software for you and should return your Wii to normal operating status.
Dec 18, 2009 | Nintendo Wii Console
My wii fit disc will not work
What error number does the Wii give?
Anyway, you can troubleshoot a little to solve the problem:
Are you running the latest Wii firmware? (You can update system software somewhere in the options)
Is the Wii FIt disk an original and not a copy? If it's a copy, you'll need an original or homebrew software to run te game.
Have you tried cleaning the isk and the tray it needs to go in? (if possible?)
These should fix your problem!
Dec 04, 2009 | Video Game Consoles & Games
My wii unit does't work. There is nothing but a black screen.
Hi.If the power light is green or orange and your screen remains blank, follow these steps.
1. Completely power down your system by pressing the power button for 10 seconds. If that doesn't work, unplug the AC Adapter from the Wii for a moment, then plug it back in.
2. Make sure your Wii console has the most current Wii system menu. Download the latest update, and then test your Wii console to determine if the problem has been resolved. If you continue to experience this issue, there is a problem with the Wii console and it will need to be repaired by a certified Nintendo service tech.
SYSTEM UPDATE
If your Wii console is currently connected on-line, you can download the latest Wii System Update by selecting the "Wii System Update" button from Wii System Settings menu. Downloading the latest Wii System Update will add the most current features to your Wii console. If you already have the latest update, on-screen messaging will indicate so after the Wii console searches the available Wii System Updates.
Oct 23, 2009 | Nintendo Wii Console
I put in a game and the home screen says "system update".
hope this helps.
Aug 28, 2009 | Nintendo Wii Console
Console will only play Wii Sports
Perhaps you could try the system software update feature in the wii settings menu, since your wii is connected to the internet.
Btw, do you have a USB to wired ethernet adapter for your Wii? I do not have a wired network port on my wii.
Dec 01, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
148 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
