Question about Nokia N73 Cellular Phone
My n73 suddenly cant read my mmc - Nokia N73 Cellular Phone
When i insert a memory card into my n73 phone it does not read and it shows "memory card not inserted" when i open in a file manager. pliz help
Hello. Generally in N 73 this problem cause due to damages of the main strip (Main Pata).So,first of all I want to say is to insert other mmc if you have or borrow it from your friends or relatives.If the problem still persist change the strip.This particular spares is available in the mobile shop.Or you can contact mobile repairing shop.Good luck.Thanks for visiting fixya
Sep 26, 2011 | Nokia N73 Cellular Phone
My phone is always in offline mode though i changed the profile settings many times. also, my phone always says "memory full. delete data first" though i tried doing *#7370#..it only restored the original...
memory full , remove ur mmc 1st then *#7370# format again, test the phone with out mmc, post result
offline mode mean no sim card detect, try other sim card post result
if cant u need flash the phone with new firmware
Jun 08, 2010 | Nokia N73 Cellular Phone
Lose the mmc password
you need to get it reset, check the product Manuel , for the reset procedure or get reset by your nearest Nokia authorized reseller
Sep 19, 2009 | Nokia 7210
I cant able to remember mypassword for memory card. i use n73
HI
You have to choose the simple way to remove the password in your , Follow the steps below...
Insert the memory card into the card reader or any mass storage device into your computer
  • go to the file <memorycard>:/system then find the file "mmc store".and rename the file to "mmcstore.txt" (Hidden file should be made as shown from tools->Folder option->Show hidden files)
  • Now open the file in notepad ,
  • No you will see the password.
ENJOY! RATE THIS SOLUTION
RNJ VINOD KUMAR
Aug 29, 2009 | Nokia N73 Cellular Phone
My nokia n73 switched off itself andi dont know how to start it. if the window is corrupted how to update it how to connect it to my laptop if it doenot switch on
your phone may be infected with a virus so remove a MMC card out . and by putting simcard on the set and type the code *#7370# . the phone will start working after that and then you need to scan ur mmc card putting in some pc which has antivirus.
Aug 27, 2009 | Nokia N73 Cellular Phone
Virus on my n73 mem card
ok , iris, if you have antivirus program .sis you can intall to your mobile phone, if you don't have , release your mmc , go to your pc insert to mmc reader , scan with your antivirus program on pc, kill your virus. or format u mmc. ok good try, don't forger to vote me , Fix Ya
Nov 01, 2008 | Nokia N73 Cellular Phone
N73 low memory
if u have prob low memmory just delet unnessery data in u r phone memory
& change u r massage can store in mmc
to do this follow the steps
  1. go to massages
  2. press options
  3. go to settings in options
  4. go in other
  5. u will see memory in use
  6. change it ti MMC
  7. IT WILL ASK U COPY U R MASSAGES CKICK ON YES
  8. then ask keep orignel click on no.
  9. after moving all massages in MMC U DONT GET LOW MEMORY ERROR
Jul 27, 2008 | Nokia N73 Cellular Phone
Nokia n73
Good day sir! the most common solution to your n73 is to format because it might have virus, formatting should be made also to your mmc so that not only your unit will be clean but also your mmc because if not the virus from your mmc might infect again your unit..
If this solution doesn't work your try to full format your unit with the use of box that can put program to it...manual formatting is *#7370# or *#7780#
Jul 17, 2008 | Nokia N73 Cellular Phone
Phone not working properly
try to remove your memory card'
and resset your phone,
and after you resset your phone'
don't yet put your MMC try it if the slowly is fix'
and turn off your phone and put your MMC,
if your phone is slowly again
you should have to Resset your phone again and format your MMC in PC and turn it off again your phone'
insert your MMC and turn it on and format your MMC in your N73 mobile... i hope thix procedure will help your prob.
fixyah......
Jan 21, 2008 | Nokia N73 Cellular Phone
Nokia N73 Cellular Phone Logo
Top Nokia Cell Phones Experts
270rexton
270rexton
