Question about Cell Phones
Can't get my motorola nextel i856 back to where it threads people by their name in my text messaging can you help me set the phone
I want to unlock my motorola i856, what is the procedure
You can Unlock it simply using the Unlock code,You can get the Unlock code from the site
www.mobile-unlocker.com
and Follow the instructions and unlock it step by step.
Motorola I856 Select your current network to see a list of available unlocking services noimage.gif Network Provider Select your Current Service Provider
Motorola I856 Unlocking Instructions Warning : Do not enter any wrong unlock codes on your Motorola I856 mobile phones. If you enter over a certain amount of wrong unlock codes on your Motorola I856 mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch ON your Motorola I856 with a NOT ACCEPTED SIM Card,
2 - Phone will display "Enter Special Code",
3 - You can now enter the Unlock Code.
NOT ACCEPTED: We mean, to use a sim card from a network other than the network your Motorola I856 is locked to.
WARNING: If one of theses messages appear :
- "Contact Service Provider"
- "Tampert Alter"
- "Wait before enter special Code"
- "Contact Service'
It's because you or somebody already entered too many wrong codes, you just have to leave the Motorola I856 ON with the errors message and after 40 minutes to 2 hours the message "Enter Code Special" will appear again!
Oct 22, 2011 | Cell Phones
I had an old nextel phone it was a i730 and i had to go on the internet on the phone every time i got a text message and i just got a i290 and i still have to go on the internet to send and receive text....
The Text messaging on the I290 is based on Java technology the requires you to go use the web portal..
Newer phones like the i776, i465,i410,i9,i856 no longer require that...
May 20, 2010 | Motorola Mobility Boost i415 Cellular...
Need a special code to unlock a Motorola i856
unfortunately these are not compatible. nextel is an iden carrier, while att is a gsm carrier. it's like apples and oranges. If you need to transfer contacts then you can get that done at any best buy. they will usually do it for free or for a minimal cost.. good luck
May 04, 2010 | Motorola Cell Phones
UNLOCK I856 TO T-MOBILE
The i856 is an iDEN phone.  iDen runson BOOST Mobile/Nextel ONLY.  It cannot run on t-mobile, which is a GSM system.  It is not possible, even if you unlock the phone, they are completely different radios and networks.
Mar 10, 2010 | Cell Phones
I836 motorola nextel that is lock and I dont know how to unlocked
hit menu then the contacts button up message and hold it should say security and enter 0000000 then its going to un lock
Jul 27, 2009 | Nextel i836
Text messages
go to your messages on your phone and go to sned then click on what you sent and there will be what you said than underneath is that persons text. hoped this help
Jun 08, 2008 | Motorola Mobility i880 Cellular Phone
GSM mode
First of all, what service do you use? I'd assume you are using Nextel, which is iden. For this reason, setting it to gsm doesn't work. iden was apparently the last setting used, so "last active" also works. Motorola, for some unknown reason, decided not to allow Nextel users to text message.
There are two ways around this.
1. One is to send a multimedia message with only text (no pictures, sounds, etc). This should be treated as a text message.
2. The other way is to follow this guide, which should allow you to change the registry on your phone and get rid of the message. Note that the first posters made the guide for telus users, so be sure to use the nextel sms number (found later in the thread, I believe).
Jan 01, 2008 | Motorola Mobility i930 Cellular Phone
I530 text messaging issue
To be able to send and reply to text messages you must have NOL net access. Press menu(left of the left arrow key), scroll to net, press ok(if an error message appears contact nextel for internet service), scroll to text messaging, press ok. From there you can write, read and reply to text messages. The reason for having to do it this way is because this phone as well as others with nextel were being produce when text was first being introduced to nextel, at that time motorola wasn't making nextel phones with the option of text, so it was up to the provider to give text access(via. net).
Sep 25, 2007 | Motorola Mobility i530 Cellular Phone
Cell Phones Logo
125 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
