Question about Microsoft Windows Vista Ultimate Edition
Vista30.loc When i boot the computer i get a message localization string not found. I am unable to use my scanner which is compaq 5200. Could somebody help me.
    Genius:
  • 1,601 Answers
Uninstall and then reinstall your scanner.
Posted on Jan 09, 2008
No Boot Disk/Hard Drive Not Found
The battery could be. However, the error seems to point to a bad hard drive, and the hard drive will need to be replaced.
If you do not have a backup of important files, I recommend that you go to a local PC repair shop to attempt recovery.
Aug 05, 2013 | Compaq Computers & Internet
Compaq presario 2594 us laptop , after boot-up get message ( operating system not found) tried recovery disc, will not formate hdd , will get this message in windows set-up , SET-UP...
I've gist had the same problem after flashing bios ...
go to BIOS and change the SATA mode to IDE. it worked for me.
original instructions:
also You have to turn OFF (disable) the boot from network. The error your seeing is result of the network boot rom not finding PXE server to boot from. Again, be sure to disable boot from network.
PLUS it seems if only 128 MB is showing as memory then the memory sticks might be damaged and not able to retain information/data to complete the installation process. Best take them out clean it properly & replace & try again. Nothing to do with BIOS!
Jun 11, 2011 | Compaq Presario 2594us Notebook PC...
My homelite (the shrub sharper 21) pull string broke. I want to replace string. How do I replace new string.
Replacing a pull string on anything is a tricky operation, taking it apart is easy, but getting the springs back in place and everything wound up is not easy. I would suggest finding a local hardware store or equipment rental location, and find somebody to do it for you. I made the mistake of attempting to do it, and 3 hours later and a lifetimes worth of frustration later I got it. Save yourself the trouble and pass it off to somebody else.
May 17, 2011 | Garden
Trying to use PrimeFilm 1800U scanner on my Dell PC (with Vista), but when running supplied Presto ImageFolio (Mr. Photo) CD, the following message appears: 'String MSG_OS was not found in string table'....
Uninstall Presto Mr Photo, image folio & Cyberview, all of which are not Vista compatible. Obtain new scanner drivers from http://www.scanace.com/en/download.php. Also, can use any image editor once scanning complete. Google provide free application called Picasa at www.picasa.google.com.
Sep 09, 2009 | Pacific Image PrimeFilm 1800u Film Scanner...
I want to read text file which is located in c drive using java code can anybody help me out
import java.io.*;
import java.util.Scanner;
public final class ReadWithScanner { public static void main(String... aArgs) throws FileNotFoundException {
ReadWithScanner parser = new ReadWithScanner("C:\\Temp\\test.txt");
parser.processLineByLine();
log("Done.");
* @param aFileName full name of an existing, readable file.
public ReadWithScanner(String aFileName){
fFile = new File(aFileName);
/** Template method that calls {@link #processLine(String)}. */
public final void processLineByLine() throws FileNotFoundException {
Scanner scanner = new Scanner(fFile);
try {
//first use a Scanner to get each line
while ( scanner.hasNextLine() ){
processLine( scanner.nextLine() );
finally {
//ensure the underlying stream is always closed
scanner.close();
* Overridable method for processing lines in different ways.
* <P>This simple default implementation expects simple name-value pairs, separated by an
* '=' sign. Examples of valid input :
* <tt>height = 167cm</tt>
* <tt>mass = 65kg</tt>
* <tt>disposition = "grumpy"</tt>
* <tt>this is the name = this is the value</tt>
protected void processLine(String aLine){
//use a second Scanner to parse the content of each line
Scanner scanner = new Scanner(aLine);
scanner.useDelimiter("=");
if ( scanner.hasNext() ){
String name = scanner.next();
String value = scanner.next();
log("Name is : " + quote(name.trim()) + ", and Value is : " + quote(value.trim()) );
else {
log("Empty or invalid line. Unable to process.");
//(no need for finally here, since String is source)
scanner.close();
// PRIVATE //
private final File fFile;
private static void log(Object aObject){
System.out.println(String.valueOf(aObject));
private String quote(String aText){
String QUOTE = "'";
return QUOTE + aText + QUOTE;
Jun 22, 2009 | Sun Java Programming Language (cdj-275)
It will boot up to the windows screen and freezes.
If your computer was able to boot up but unable to load the Windows, the most common cause would be the recently intstalled software or Windows update.
To remove this, follow these steps. Skip Step 1 if it is not relevant.
Step 1: Removing recently added hardware
Use the steps in this section to disconnect any recently added hardware and test for the error.
NOTE: If a new internal device (sound card, hard drive, or other) was added to the computer before the error message started to occur, you have to remove it before continuing.
  1. Turn off the PC and unplug the power cord.
  2. Disconnect the mouse, and any other peripherals attached (Printer, scanner, webcam, zip drive, phone cord, network cable and other devices). Leave only the keyboard and monitor cable attached.
  3. Press and hold the power button on the front of the PC. Release after 10 seconds.
  4. Plug the power cord back in.
  5. Turn on the computer.
  6. The computer displays the We apologize for the inconvenience... message. Allow the timer to count down from 30 to 0.
  7. If the computer successfully starts to the Windows desktop and does not restart to the error message, connect one device and wait until Windows recognizes it.
  8. To find if a device is causing the error, continue connecting the devices, one at a time, restarting the computer each time, until the device that is causing the error is found.
NOTE: If this does not solve the issue try to do a system restore BUT it will delete all your files and programs you install by yourself after the system. You will be able to use the pc as a new pc.
Jan 25, 2009 | HP Compaq Presario SR2011WM PC Desktop
Programming error BCT8 Uniden
Hello.
Back to answer my own question.
I just found the problem. If you try to program one of these scanners (Uniden BCT8) and you keep getting a "pr9-loc" message every time you try to enter a frequency and "M-LOCK" is showing in the upper right corner of the display press and hold the M-Lock (E) key until it beeps twice and "M-LOCK" disappears from the display. You're now set to program.
Keith.
Dec 30, 2008 | Uniden BCT8 Base Scanner
Problem: Cannot Load Windows/Windows Setup Does Not Detect Hardrive
My Hp Compaq tc4400 Does not load Windows and when i try to install a new one and error Message apears saying that it cannot detect any hardrive, but when i press F9 for boot selection Notebook Hardrive is dected and availble, i tried removing the hardrive and re-insert it also it dint work could somebody help plssss
Feb 01, 2008 | Compaq tc4400 Tablet PC (RL875AW#ABA)
Harddrive is most likely bad get another and install windiws... if you found the right place they could "ghost" your information onto the new one!
HP ScanJet 2100C
I had a similar problem when I upgraded to Vista. Try running setup.exe from within the software CD ( in the english folder I think) rather than using the autorun.
Oct 30, 2007 | HP ScanJet 2100C Flatbed Scanner
Microsoft Windows Vista Ultimate Edition Logo
112 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
