Question about Frigidaire 24" Built-In Single Gas Wall Oven - Black
Gas ignites after 15 minutes Takes too long - Frigidaire 24" Built-In Single Gas Wall Oven - Black
    President:
  • 1,462 Answers
THis is due to the issue with the ignitor..
The ignitor takes 15 minutes long to ignite beacuse the current drawn by the ignitor is less than the 3.2 Amps, THe ignitor current should be more than 3.2Amps to enable ignition quickly..
I would recomment to change the ignitor to solve your issue..
Please rate this solution
Thanks
Rnj VINODKUMAR
Posted on Nov 14, 2009
My gas oven won't ignite, takes several tries to ignite it.
All gas appliances have a thermal cut out this will shut the gas off if the flame goes out the down side is when the thermal cut out becomes faulty it can shut the gas of when you are using the cooker the only fix is to replace the thermal cut out
Jan 18, 2015 | Kenmore Ovens
How do I lite the oven pilot
If it's an older model with a true pilot light you turn on the gas at supply line valve, open oven door, remove bottom panel to access pilot and burner. Sometimes it's easier to remove broiler drawer on these models but regardless take a lighter and light pilot. Most models are electronic ignitions which if you have it probably needs replaced if it doesn't ignite the burner in under a minute or minute and 15 secs. It could also be a bad thermostat if the burner ignites within the time period described above
Sep 10, 2014 | Magic Chef Ovens
KENMORE GAS STOVE OVEN , how to check if power is coming to the ignitor
The oven burner igniter
commonly known as the hot surface igniter is used in modern gas oven burners to open the gas valve and to ignite the gas. As the igniter draws electric current it will heat to a high temperature and glow, as well as cause the bi-metal in the oven safety valve to warp and open the valve releasing the gas to be ignited. This sequence normally takes about a minute. Igniters come in both flat and round styles and are very fragile. If the burner does not light then you should check the igniter first. If the igniter does not glow at all, then check for power to the circuit. This is a live voltage check and should be performed by a qualified person. If power is present then the igniter may be open circuit and can be checked for continuity with a multi-meter. If the igniter is glowing, but the burner is not lighting, the igniter may be weak and still be at fault because it requires a certain amount of current draw to open the valve. This check requires the use of an amp meter and should be performed by a qualified person. If the igniter is defective then it must be replaced.
Sep 07, 2014 | Kenmore 24 in. Gas Self-Clean Single Wall...
Oven starts and stops
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
Apr 02, 2014 | Kenmore Ovens
Whirlpool465 gas oven takes about 2.5 minutes to light after pushing start........ignition problem? I just cleaned the oven and the problem still exists.
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. There is a video at www.appliancehelponline.com/servicemanual.html this will walk you thru the correct procedure for performing this test. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Apr 23, 2010 | Ovens
Kitchenaid gas range model# ykgsc308lso oven
If it takes more than 2 minutes to light then that ignitor is weak. It should be very bright. It has to draw 3.5 amps to open the valve. The valve is good because the ignitor is working the oven control is good, all it can be is a weak ignitor. It should draw 3.5 amps or have measure 37 ohms.
Jan 14, 2010 | Ovens
Oven takes 5 minutes to come on (ignite).
Replaced the igniter. The parts guy told me that the amperage changes with age and use; thus the igniter still glows, but it takes much longer to operate the gas valve with the reduced amperage. Cost - $70.14
Oct 18, 2009 | Tappan 30IN ELEC IGNa Oven
We have a Westinghouse oven model WHG 645 KNG serial 90911136. It takes so long to heat up. I leave it on for 10 minutes then put on the fan. It takes ages before the gas seems to ignite at the back of the...
This is a problem with the ignitor. We have had this replaced 3 times in 10 years and the service technician says each time that he'll be back within the next 3 to change it. They actually haven't charged us for the parts the last 2 times because Westinghouse obviously know that it is a piece of $&@# .
Aug 31, 2009 | Ovens
Crosley gas oven will not heat up
That's my mom!!! Go Sheila!!! Hehe.. -RET-
Aug 08, 2007 | Maytag CWG3100A Gas Single Oven
Frigidaire 24" Built-In Single Gas Wall Oven - Black Logo
121 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
