Question about Proview PL913B 19" Flat Panel LCD Monitor
My cpu is running nice but monitor does not start. power is seen in monitor but it does not start
  • Rohit Deshmukh May 11, 2010
    remove Ram clean your Ram slot and plug Ram again it gets the display
    Problem Solver:
  • 11 Answers
There is chance that your monitor is having some problem or the case is that your RAM is not working. I guess you should once clean your RAM or change your RAM to see if its working then. Or you might have to check your monitor with some another pc to make sure that your monitor is really working or not. I hope this tip helps.
Posted on Nov 14, 2009
    President:
  • 1,566 Answers
Hi!
Here's what you need to do. Connect the computer to another monitor and adjust the resolution. It could be that the current resolution of your PC is not supported by the monitor. Try adjusting it first and then test again.
Hp pavilion modelp6510f press power switch on top of pc does not light computer fans blow but compute does not turn on
ok th p6000. complete range when they were made had to be recalled as they put the copper expansion pipes ran across the gpu & cpu hence a massive overheat problem. they put copper shims over the cpu & gpu but this worked for a short time but it was inevitable and both units ended up being cooked i had this problem with mine. so if you have tried external monitor with no images it would sound or more likely to be the gpu cooked sorry for the bad news.
Jan 28, 2014 | Computers & Internet
The cpu is running,the motherboard is with green light inside,but the monitor blanck
what king of monitor you have., crt or LCD, does the monitor led indicator has a green light, is there any beep when starting the cpu? how many beeps you have heard when the cpu was starting?.
if there is no led indicator light in you monitor the posibilities of that is the monitor was the problem.
solution: try to check your plug in monitor if it is properly inserted in the power plug or in the vga plug correctly.
if when you power the cpu and your monitor led indicator, turn green and back in the standby mode. listen to the beep sound of cpu if theres any.
solution: try eject the mem card. in the slot and clean the contact with the eraser. and put it back into the slot again after you clean it.
Mar 28, 2011 | Computers & Internet
THE STARTING WINDOWS IS NOT VISIBLE ON THE MONITOR BUT THERE IS SHADOWS CAN BE SEEN. THE POWER IS FUNCTIONING ALSO THE CPU.
LCD monitors have backlight (NEON / LED backlight), the screen will go dark if the backlight circuit / electronics or the backlight itself fails. Get it to a tech who will have spares for your LCD to get it replaced.
Mar 08, 2011 | Samsung T220HD LCD Monitor
With asus m4a785-m motherboard and amd phenom x4 9600b quad core cpu why does monitor displays a cpu fan error when fan is running full speed.
Hmm, I've never seen a computer give a CPU fan error. Maybe if the fan is really dusty it's clogging it up, try getting some canned air and spraying it out.
Dec 17, 2010 | ASUS M4A785M Motherboard
The power led is flashing and the monitor will not turn on
Hi
usually for these kind of issues., here are some common steps that helps at times.
1. Check the VGA Cable that connects the Monitor to the Tower (CPU).
2. Reseat the Cable once.
3. Remove the VGA Cable & turn on the Monitor Alone. See if you get any display saying "No Signal" or anything similar. If there is some display, then it means that the problem is with the Tower (CPU) & not with the monitor.
Hope this small sugession helps.
Cheers!!! Have a nice day!!!
Sep 14, 2010 | BenQ FP567s 15" LCD Monitor
Initially, my fan would run fast and then slow. Then, it began to shut off frequently by itself; the monitor would state "monitor sleeping." Now, the CPU will not power on at all. Even after having a...
Fixing the problem would have been to change the fan when it started to fail. The bearings were probably going out and causing it to labor and slow down. When the fan quit altogether that was the big flashing warning sign "Do not run till you fix me" type of warning. CPU's develope tremendous amounts of heat. Without a fan there to cool it, it could have damaged something.
1. Get a new fan
2. Unplug all add on cards
3. Unplug hard drives, floppys and cdrom
The only thing that should be plugged into motherboard is the video and ram and keyboard. Unplug power supply for 1 minute. Make sure the power supply master switch on the back is on. Try to start the computer. If it starts then start connecting your drives back one at a time and any addon cards. If it doesn't start you may be looking at replacing motherboard or CPU. I've never seen an Intel CPU fail even from heat but there is a first for everything.
Dec 07, 2009 | HP Pavilion a1120n (PX759AA) PC Desktop
How do I find out what my CPU usage is on my MAC laptop
hi dv4242
Here is how to do it :
  1. First open the Activity Monitor
  2. Right Click (or click and hold, or CTRL click) on the Activity Monitor icon in the dock and select ‘Keep in Dock’ (if it’s not already there)
  3. Right click on the Activity Monitor icon again and select the ‘dock icons’ menu
  4. From the ‘dock icons’ menu select the ‘Show CPU Usage’ item
  5. There you have it, a nice little visual representation of your CPU usage, it is even separated by cores (if applicable)
Hope that helps
Have a nice weekend
Please rate my answer
Sep 25, 2009 | Apple Mac OS X 10.4 Tiger for Mac
When I start the machine, only CPU is running
I think you have a problem with power supply. Try to replace it
Jul 18, 2009 | Computers & Internet
LCD monitor signs "no signal" on eMachines t3418
E-machines had had a long history of bad power supplies. I've seen many of these machines go bad and when they do they take out the video chip (Nvidea) with it, usually shutting down the whole machine. I've never seen one operable. You might be able to insert a video card.
Mar 23, 2009 | E-Machines eMachines Monitor E15T4
No display on monitor.
More than likely you have a bad CPU. I've seen this several times.
Nov 07, 2007 | AOpen MX36LE-UN (91.89Q10.101) Motherboard
Proview PL913B 19" Flat Panel LCD Monitor Logo
Top Proview Computers & Internet Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
ka4iup
ka4iup
Are you a Proview Computer and Internet Expert? Answer questions, earn points and help others
