File Name: vwin32(05) + 000012D0 Error: 0E: 0028:C029A258 Windows ME Error
  • 40 Answers
Reformat your computer..
Posted on Nov 28, 2009
  • 981 Answers
Get a real OS.  Get a real problem, category, and description.  Get a flat in London and an espresso machine.  Get natty suits and a thin girlfriend.
Posted on Nov 14, 2009
I get exception OE at 0028:FF045A63 in VxD called from 0028:C1C77C57 in VxD
It looks like your hardisk or memory problem.. probably there is bad sector.. try to do 'Check Disk' (usually it called 'scandisk') first.
Oct 09, 2011 | Microsoft Windows 98 for PC
This copy of windows did not pass genuine windows validation pls help me
Hello !
to fix problem
1- go to Notepade or blocknote
2- copy and paste this code
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\WPAEvents]
"OOBETimer"=hex:ff,d5,71,d6,8b,6a,8d,6f,d5,33,93,fd
"LastWPAEventLogged"=hex:d5,07,05,00,06,00,07,00,0f,00,38,00,24,00,fd,02
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion]
"CurrentBuild"="1.511.1 () (Obsolete data - do not use)"
"InstallDate"=dword:427cdd95
"ProductId"="69831-640-1780577-45389"
"DigitalProductId"=hex:a4,00,00,00,03,00,00,00,36,39,38,33,31,2d,36,34,30,2d,\
31,37,38,30,35,37,37,2d,34,35,33,38,39,00,5a,00,00,00,41,32,32,2d,30,30,30,\
30,31,00,00,00,00,00,00,00,00,0d,04,89,b2,15,1b,c4,ee,62,4f,e6,64,6f,01,00,\
00,00,00,00,27,ed,85,43,a2,20,01,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\
00,00,00,00,00,00,00,00,00,00,00,31,34,35,30,34,00,00,00,00,00,00,00,ce,0e,\
00,00,12,42,15,a0,00,08,00,00,87,01,00,00,00,00,00,00,00,00,00,00,00,00,00,\
00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,94,a2,b3,ac
"LicenseInfo"=hex:9e,bf,09,d0,3a,76,a5,27,bb,f2,da,88,58,ce,58,e9,05,6b,0b,82,\
c3,74,ab,42,0d,fb,ee,c3,ea,57,d0,9d,67,a5,3d,6e,42,0d,60,c0,1a,70,24,46,16,\ 0a,0a,ce,0d,b8,27,4a,46,53,f3,17
3- then save this file by this name Xp.reg
4 -
After you save the file run it and restarts your Pc
Good luck
Jun 10, 2011 | Microsoft Windows XP Professional With...
C;\Documents and Settings\admin\My Documents\downloads\Silverlight.exe is not a valid win32 appplication
HI,
causes for these problems are:
1. File is corrupt, bad, or missing.
2. File is not designed for your version of Windows.
3. File is a virus, worm, or other malware file.
4. Hardware incompatibility.
Step 1: Verify that the program installation CD is clean. If the CD is dirty or bad, you could get this error during the install and/or get this error after the program has been installed because it was not copied properly onto the computer.
Step 2: Make sure the program or file you're attempting to run does not contain the same name as the long file name directory it is contained in. For example, executing a file named "program" in the "program files" directory can cause errors.
Step 3: If you're trying to run a program that is not designed for your version of Windows you may get this error. Although many older programs designed to work in older versions of Windows will work with new versions of Windows, unfortunately, not all programs will work.
· If the program is an older MS-DOS program or early Windows program you may get this error.
· If the program is designed for a 64-bit version of Windows and you're running it in a 32-bit version of Windows, it will not work and generate this error.
Step 4: Run an online scan for any threat and try to fix them
http://onecare.live.com/site/en-Us/center/cleanup.htm
Thanks and regards
Nandy
Oct 26, 2010 | Microsoft Computers & Internet
I have a shortcut to an internet site that has somehow had its name changed to a line of ??????? ? ?????????. The computer will not allow me to delete it, stating "the file name or directory name or volume...
run a check disk first, those kind of names is not allowed in windows, so it should pop up some error.
in msdos command prompt:
chkdsk C: /F
(assuming it is in drive C)
It should give you an error, saying the volume is locked, so you need to reboot, during the reboot, it will check the file system.
Still in command prompt, just try to delete the file using:
del "??????????" /F/S/Q
USE the quotes please, or it won't work.
OR... the hardway ;) get a Linux Live CD, mount the filesystem, and delete the file.
Sep 14, 2009 | Microsoft Windows XP Home Edition
Quicken won't load
Your data file name is too long.  This is from the Quicken Support website:
Quicken Launcher has stopped working, or encountered an error and needs to close when backing up or closing data file
Updated: 02/05/2009 Answer ID: 7273
This error may occur when backing up or closing your data file, if the file name is excessively long or if the file path exceeds 250 characters.
To resolve this issue, make sure your data file is saved to this location (if not, move it there):
Windows XP: C:\Documents and Settings\username\My Documents\Quicken
Vista: C:\Users\username\Documents\Quicken
If your file already resides in the above location, shorten the file name by renaming it to 8 characters or less. Avoid using in the file name.
I had the same problem with my program, I shortened the name and it launched.
Aug 25, 2009 | Intuit Quicken 2008 Deluxe Full Version...
When I insert a cd in my player I get this error oe 0028:c182b573
Method ONE Disable the SCSI1HLP.VxD using the Microsoft Configuration Utility:
  1. Restart your computer, press and hold down the CTRL key while Windows is starting, and then choose Safe Mode from the Startup menu.
  2. Click Start, click Run, and then type msconfig in the Open box.
  3. On the Static VxDs tab, click to clear the Scsi1hlp.vxd check box, click OK, and then follow the instructions to restart your computer.
Method Two loadTOCNode(2, 'resolution'); NOTE: By following the steps below, any device that uses the Scsi1hlp.vxd file may not function properly or you may not be able to restart your computer. Some SCSI devices and some ATAPI devices use this file. If you are not sure if your hardware uses this file, check with your hardware manufacturer before you proceed.
Rename the Scsi1hlp.vxd file in the Windows\System\Iosubsys folder:
  1. Restart your computer, press and hold down the CTRL key, and then choose Safe Mode from the Startup menu.
  2. Click Start, point to Find, and then click Files or Folders.
  3. In the Named box, type scsi1hlp.vxd, and then click Find Now.
  4. In the list of found files, right-click the Scsi1hlp.vxd file that is located in the Windows\System\Iosubsys folder, and then click Rename.
  5. Type scsi1hlp.old, press ENTER, and then restart your computer.
Apr 04, 2009 | Microsoft Windows 98 for PC
Fatal exception error on shut down - VXD VWIN32
you need to start in safe mode and remove your video drivers. Hopefully you have a win98 disk to get the drivers off of. Remove drivers and restart, it will then recognise that the drivers are gone let it ask for drivers and let it find them automatically and install them. Then see what happens
Feb 23, 2009 | Dell Computers & Internet
Windows dvd maker
What OS are you using? Ultimate, Premium, Basic?
Windows DVD Maker has stopped working Issue : While trying to create DVD in Windows DVD Maker in Vista, or while creating a DVD from Windows Movie Maker, which uses Windows DVD Maker, the burn process stops with error message.
Error message : " Windows DVD Maker has stopped working. A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is available. "
Cause : Windows DVD maker stops working because of incompatibility with one or more codec files which are outdated or incompatible with the particular project or the DVD Maker software itself.
Resolution :
These Codec files should be located and renamed to resolve the issue.
1. Open Start menu and type Event Viewer in the Start menu search bar. Open Event Viewer from the menu.
2. In the Event Viewer window Click on Windows Logs in the left panel
3. Click on Application Logs under Windows Logs
4. Locate error messages listed in the Central panel of the Event Viewer window and double click the error to check if this is log is related to DVD Maker.
Sample Error Log :
Problem signature
Problem Event Name: APPCRASH
Application Name: DVDMaker.exe
Application Version: 6.0.6000.16386
Application Timestamp: 4549b5b0
Fault Module Name: nevideohd.ax
Fault Module Version: 4.6.15.0
Fault Module Timestamp: 459bb828
Exception Code: c0000005
Exception Offset: 00008b89
OS Version: 6.0.6000.2.0.0.256.1
Locale ID: 1062
5. Locate Fault Module name, it should be a file with extension .ax.
6. Once the file name is identified, try to locate the file in C:/Windows/System32 folder. ( Please click on Show Contents if the files are not listed Automatically ).
7. If the files are not listed in System32 folder, search for the file, with search containing system files and folders.
8. Locate the file and rename it.
9. Check if the issue persists. If the issue persists and the error message again appears, locate the new .ax file that is causing the issue from the Event Viewer, error log.
These steps will resolve the issue instantly without a restart.
Sep 18, 2008 | Computers & Internet
Belkin F5D7132: cannot open exe program
Windows Vista; belkin says it's compatible. install program downloads, but desktop shortcut does not appear. When I attempt to open the file, I get error message "IP802MR MFC application has stopped working." IP802MR is the name of that file.
Jun 17, 2008 | Belkin (F5D7132) 802.11b/g Wireless Access...
Computers & Internet Logo
82 people viewed this question
David Payne
David Payne
