Question about Enteractive FPS Creator for PC
When I am testing my game it is saying debug string game core and could not find path
  • 981 Answers
It's having trouble loading the basic libraries; you might have to populate those global environment variables for it.
Posted on Nov 14, 2009
Joint Strike Fighter crash
sorry to say bt i think that your operating system is not able to open taht game
Jul 29, 2013 | Eidos Interactive Jsf Joint Strike Fighter
How to enable usb debugging acer a510
I finally found it myself after looking for hours and testing.
Go to settings -> Options for developers -> Right top corner, turn it ON -> scroll down to debugging -> USB-debugging -> click it.
Jan 29, 2013 | Acer 10.1" Iconia A510 32gb Tab Android...
Since yesterday, after playing Call of Duty and installing a game, my laptop crashed and it showed a blue screen saying something like "Windows has shut down to prevent it from being damaged bla bla...
first try to restore them in a previous date, if not done then go to safe mode and uninstall the software/game which you have installed recently. if all not done then you have to reinstall OS (assuming VGA/Graphic is in gud condition as this can also happen due to display card/driver faliure)
Aug 21, 2011 | Computers & Internet
Batch convert image files, that keeps a folder tree?
If your not using version 2.20 then upgrade because there is no limit according to the manufacturer.
Dec 14, 2009 | Microsoft Windows XP Home Edition
How to analyze windows 7 installation log files for cause of BSOD.
  1. Download and install the Debugging Tools for Windows from this link. My installation is a 32bit one, so I downloaded the 32 bit version 6.10.3.233.
  2. Download and extract the debugging wizard (debugwiz.exe) from Windows BBS. There is a note on the site saying this tool does not work properly with Vista 64 bit. My guess is it probably does not work with Windows 7, either.
  3. The debug wizard relies on a registry key HKCU\Software\Microsoft\DebuggingTools to find the binary files for the debugging tools. This key is not generated by the debugging tools installer any more. You have to enter the key manually using regedit.exe .
  4. Right click on the debugwiz.exe extracted in step 2 and select Run as administrator.
  5. Click on the Browse button and pick the memory dump file.
  6. There is one more step before you try to generate the analysis log. The Command String is not correct. Check the Advanced checkbox and change the string from c:tempdebuglog.txt to c:debuglog.txt .
  7. Click on Generate log and the analysis log will be generated and saved in c:debuglog.txt .
Ok, you now have a analysis log, but it’s filled with jargons. What can you do? I usually only look for the line that starts with “Probably caused by”. In this case, the acutal line is
Probably caused by : memory_corruption ( nt!MiFindNodeOrParent+5 )
I know then the cause is probably due to bad memory module. On most cases, it’s usually a system file or a driver. You have to find the proper update for the offending file or uninstall the software which uses that file to fix your system.
Dec 02, 2009 | ASUS W2W-A1 PC Notebook
DeBug appears whenever
what IE are you using?
the debug will appear when you using IE6. the reason is that most of th web site have activex. IE6 can't handle it. you need to install IE7 sp1.
Mar 27, 2009 | Microsoft Windows 2000 for PC
Application.FileSearch
'!!! Replacement solution including searching in subdirectories !!!!
Sub FileSearchByHavrda_Example_of_procedure_calling()
' Example of FileSearchByHavrda procedure calling as replacement of missing FileSearch function in the newest MS Office VBA
' 01.06.2009, Author: P. Havrda, Czech Republic
Dim FileNameWithPath As Variant
Dim ListOfFilenamesWithParh As New Collection ' create a collection of filenames
' Filling a collection of filenames (search Excel files including subdirectories)
Call FileSearchByHavrda(ListOfFilenamesWithParh, "C:\Temp", "*.xls", True)
' Print list to immediate debug window and as a message window
For Each FileNameWithPath In ListOfFilenamesWithParh ' cycle for list(collection) processing
Debug.Print FileNameWithPath & Chr(13)
MsgBox FileNameWithPath & Chr(13)
Next FileNameWithPath
' Print to immediate debug window and message if no file was found
If ListOfFilenamesWithParh.Count = 0 Then
Debug.Print "No file was found !"
MsgBox "No file was found !"
End If
End Sub
Private Sub FileSearchByHavrda(pFoundFiles As Collection, pPath As String, pMask As String, pIncludeSubdirectories As Boolean)
' Search files in Path and create FoundFiles list(collection) of file names(path included) accordant with Mask (search in subdirectories if enabled)
Dim DirFile As String
Dim CollectionItem As Variant
Dim SubDirCollection As New Collection
' Add backslash at the end of path if not present
pPath = Trim(pPath)
If Right(pPath, 1) <> "\" Then pPath = pPath & "\"
' Searching files accordant with mask
DirFile = Dir(pPath & pMask)
Do While DirFile <> ""
pFoundFiles.Add pPath & DirFile 'add file name to list(collection)
DirFile = Dir ' next file
Loop
' Procedure exiting if searching in subdirectories isn't enabled
If Not pIncludeSubdirectories Then Exit Sub
' Searching for subdirectories in path
DirFile = Dir(pPath & "*", vbDirectory)
' Add subdirectory to local list(collection) of subdirectories in path
If DirFile <> "." And DirFile <> ".." Then If ((GetAttr(pPath & DirFile) And vbDirectory) = 16) Then SubDirCollection.Add pPath & DirFile
DirFile = Dir 'next file
Loop
' Subdirectories list(collection) processing
For Each CollectionItem In SubDirCollection
Call FileSearchByHavrda(pFoundFiles, CStr(CollectionItem), pMask, pIncludeSubdirectories) ' Recursive procedure call
Next
End Sub
Jul 09, 2008 | Microsoft Office Professional 2007 Full...
Help me
this the code for your problem. by the way this for vb6.0
Sub CountCharacters(Text As String)
Dim iVowel As Integer
Dim iCons As Integer
Dim iNum As Integer
Dim iSpace As Integer
Dim iOther As Integer
Dim cnt As Integer
Dim sChar As String
For cnt = 1 To Len(Text)
sChar = LCase(Mid(Text, cnt, 1))
Select Case sChar
Case "a", "e", "i", "o", "u" ' And sometimes "y"?
' Vowel
iVowel = iVowel + 1
Case "a" To "z"
' Includes the first case, but VB matches the first case and stops
iCons = iCons + 1
Case "0" To "9"
' Numbers
iNum = iNum + 1
Case " ", vbTab, vbLf
' Space characters
' Not including vbCr as this will likely be dealing with Windows text
' and I only want to match one character for a newline
iSpace = iSpace + 1
Case Else
If sChar <> vbCr Then iOther = iOther + 1
End Select
Next cnt
Debug.Print "Text: " & Text
Debug.Print "Vowels: " & CStr(iVowel)
Debug.Print "Consonants: " & CStr(iCons)
Debug.Print "Numbers: " & CStr(iNum)
Debug.Print "Space characters: " & CStr(iSpace)
Debug.Print "Other: " & CStr(iOther)
End Sub
Feb 21, 2008 | Computers & Internet
Help me
Dim iNum As Integer
Dim cnt As Integer
Dim sChar As String
Select Case sChar
' Vowel
iVowel = iVowel + 1
Case "a" To "z"
iCons = iCons + 1
Case "0" To "9"
' Numbers
iNum = iNum + 1
' Space characters
iSpace = iSpace + 1
Case Else
End Select
Next cnt
End Sub
Enteractive FPS Creator  for PC  Logo
122 people viewed this question
Top Enteractive Computers & Internet Experts
David Payne
David Payne
Are you an Enteractive Computer and Internet Expert? Answer questions, earn points and help others
