How do i use the roland cleaning liquid for sol ink cartridge?
2 Suggested Answers
  • 1218 Answers
SOURCE: cyan and magenta test prints
Mostly, printer cartridge error occurs when the printer head is unable to identify the cartridge properly. And the basic reason behind this is that the cartridge is improperly attached. To reattach the cartridge, turn on the lid of the printer and then remove the cartridge from the printer head. Check the cartridge to make sure that there are no scratches or other damaged parts that can contribute to a printer cartridge error report. Take note that the cartridge should not be left open for more than 30 minutes; otherwise the ink will start to dry up and the cartridge will get clogged.
Posted on Nov 04, 2010
For the roland SJ-740, the yellow and black heads are completely missed from the test print, what should we do to fix this problem?
Ahmed?
Are the cartridge heads dirty, or clogged with old dry ink?
You may clean dried ink by using a lint-free cloth that is wet.
If you do that, make sure the cartridge head is dry before re-inserting it in the right place.
Good luck.
Dec 02, 2016 | Office Equipment & Supplies
How do I fix my printer it prints blank sheets it acts like its printing but the paper is still blank I did nozzle and print head checks nothing still blank
I hate to state the obvious, but how long has it been since you've changed the ink cartridges on the printer. If you have done both the nozzle cleaning and print head alignment and nothing appeared on the paper, I don't know what else it could be.
This following suggestion is very rare - if you recently replaced the cartridges and your printer hasn't printed since then, it is possible that you installed them incorrectly; OR perhaps you left the head protector tape on the cartridge. But then it wouldn't "see" the cartridge.
In the "rare" situations, you should try to remove and replace the cartridges to assure that they are properly installed.
Mar 05, 2015 | Epson Stylus CX6600 All-In-One InkJet...
Replace black ink cartridge, printer does not print
Hi
Reset the ink resetter if any or print nozzle to clear some clog ink. Check also the new ink cartridge and maybe there are sticky liquid after you remove the protective tape that will tends your printer not to print. Clean it will alcohol and try printing again.
Jan 11, 2011 | HP OfficeJet Pro k550 Printer
I have a roland sc545ex printer and there must be an air leak the ink doesn't fill the dammper, I can see air in the line if one of the feeder hoses so the head isn't getting any ink How can I find the...
Hello, I present myself I am technician operator digital printers such as Vutek, Nur, Inca, Durst, jeti, oce, roland ...
Your problem is symptomatic of the 545ex roland sc and know that from my point of view it may be difficult to resolve.
First of all ... if you have a great system ... check that the ink cartridge ink corresponding to the head is properly sealed. If c is ok:
Turn on the machine and then open the hood.
the heads are therefore naturally arises on capping.
determine the top corresponding to the problem and the capping on leqel it. output of this capping there are 2 pipes connected to a T. unplug the vacuum hose and a syringe. the ink is coming ... does not relachrz the syringe so that it is not stable ... reconnect ... cleaning .... And it should go.
esrant be answered in ...
thank you for the evolution of m inform ..
ben
Nov 17, 2010 | Office Equipment & Supplies
Cyan and magenta test prints are 1/2 way clogged.Regular cleaning and blotting heads have not worked. What could be done, and how and when is the cleaning liquid for sol ink cartrige used and how?
Nov 04, 2010 | Office Equipment & Supplies
The cyan isn'r printing. I cleaned and changed the cartridge. If clogged is there a way for me to unclog the nozzle?
Use a syringe filled with a liquid head cleaner. Add tip syringe with flexible hose (like the hose on the outlet head cleaning mechanic). Remove the ink tanks. Hose into the nozzle.Give the pressure slowly until the liquid head cleaner in the syringe out. Make sure no liquid is spilled in the vicinity of the nozzle. Replace the ink tanks, nozzle check and head cleaning. Is there a change from the nozzle check from the previous?
Sep 29, 2010 | Epson Artisan 700 InkJet Printer
Have replaced old black ink caartridge plus the other 3 ink colors and machine still says replace black ink cartridge which i now have 3 times now and it still repeats the same message. whats wrong?
Probably the printhead of black cartridge side in the printer is damaged in the worst scenario.Else,just clean the contacts where the black cartridge connects after snapping into the printer,with some cleaning liquid (Nephtha,CCL4)etc.I hope this solves the issue.
Aug 21, 2010 | Brother Multi-Function Center MFC-3360c...
Have a Roland SP 540 V Eco Sol MAx printer/cutter. Magenta/Yellow print head clogged (hadn't been used in a few weeks) can't seem to get the ink to flow in those heads! Any idea other than head...
you should have to use the syringe method to **** the ink before anything, then make a powerful cleaning, test, you may have to do it several cleanings and should be solved.
Jan 08, 2010 | Office Equipment & Supplies
Lexmark x80 wont print colour new cartridge
On your printer, there is a clean print head adjustment,it is in your menus on the printer itself, It should also be on your print driver in properties. I would try running that up to 5 times before proceding to anything else.
Check and be sure the cartridge expiration date is not exceded. The liquid ink cartridges have an expiration dates. Even though the cartridge is new, Do not rule out a bad or for some reason dryed out cartridge or blocked port at the bottom. If it is indeed brand new and you have the receipt, I honetsly would suspect the cartridge itself.
Ok now, we tried the print head cleaning, and a second cartridge.
Next, I would remove the cartridge, turn the printer off and lightly, very lightly dampn a dusfree cloth with some alcohol, and where the cartridge is located, clean those contacts. reinsert the cartridge and see what happens.
Lastly, you can unplug the printer, remove the cartridges, and place a paper towel under the area where the cardtidge latches in, and dribble in a soapy cleaner, like fantastic, because those inks will dry out in the ports and not allow the ink to flow properly, If you do that, wipe all the excess cleaner up and leave the printer off for an hour or two to allow any remaining liquid to evaporate. Don't use a lot, but trickle it in until you see the ink start to wash out and all the ink is removed.
Take your time, and go from easiest to more difficult. I think that is the process I presented.
Dec 05, 2008 | Lexmark Office Equipment & Supplies
528 people viewed this question
jasbo
jasbo
