Question about Xerox DocuColor 12 Color Copier
How to print C5 & C4 envelopes
How do you print envelopes on a Xerox DC12
  • JP repro Jan 10, 2008
    Thanx for your answer, I thought I would be able to get a special feeder, I have recently bought Xerox envelopes that have special flaps to stop jams....
    Need to print envelopes somehow, any ideas appreciated.
    President:
  • 2,072 Answers
Here is the answer from Xerox.
> Support & Drivers > DocuColor 12 Copier/Printer Support > Search Results Solution: Printing on Envelopes is Not Supported How to print C5 & C4 envelopes - bttn_print.gifMake Printable bttn_email.gifEmail this page
CAUTION: Printing on envelopes may cause damage to the copier / printer.
Posted on Jan 08, 2008
How do I print envelopes. I'm using Open Office 4.1.1 and Samsung printer CLX3305FW
From the main menu click on Format, Page, then choose one from among five envelope sizes available from the Paper format. Available envelop sizes are DL, C6, C6/5, C5 and C4. Click OK. You must now be able to see in the print menu the envelope size you just chose.
Nov 22, 2014 | Samsung Office Equipment & Supplies
How to print #10 envelopes on a Xerox 3610 printer?
Solution : Print on Envelopes You can print envelopes from the Bypass Tray only.
Guidelines for Printing Envelopes
  • Print quality depends on the quality and construction of the envelopes. Try another envelope brand if you do not get desired results.
  • Maintain constant temperatures and relative humidity.
  • Store unused envelopes in their packaging to avoid excess moisture and dryness which can affect print quality and cause wrinkling. Excessive moisture can cause the envelopes to seal before or during printing.
  • Remove air bubbles from the envelopes before loading them into the tray by setting a heavy book on top of them.
  • In the print driver software, select Envelope as the paper type.
  • Do not use padded envelopes. Use envelopes that lie flat on a surface.
  • Do not use envelopes with heat activated glue.
  • Do not use envelopes with press and seal flaps.
  • Use only paper envelopes.
  • Do not use envelopes with windows or metal clasps.
To Load Envelopes in the Bypass Tray:
  1. Open the Bypass Tray.
  3. Move the width guides to the edges of the tray.
    NOTE: If you do not load envelopes in the Bypass Tray right after they have been removed from the packaging, they can bulge. Flatten them to avoid jams.
  4. To load envelopes, select an option:
    • For Number 10 envelopes, load the envelopes with the short edge going into the printer, flaps down, and flaps to the right.
    • For C5 envelopes, do one of the following. If the envelopes wrinkle, try another option.
      • Insert envelopes with the print side up, flaps closed and down, and flaps going into the printer.
    • NOTE: When loading Monarch or DL envelopes, remove the Multipurpose Tray.
  5. On the printer Control Panel, press the Menu button.
    NOTE: To navigate through the menu, use the Up or Down arrow buttons.
  6. Navigate to Tray Settings, then press OK.
  7. Navigate to the Bypass Tray, then press OK.
  8. Navigate to Tray Mode, then press OK.
  9. Navigate to Panel Specified, then press OK.
  10. To return to the previous menu, press the Left arrow button.
  11. Navigate to Paper Type, then press OK.
  12. Navigate to Envelope, then press OK.
  13. To return to the previous menu, press the Left arrow button.
  14. Navigate to Paper Size, then press OK.
  15. Navigate to the required envelope size, then press OK.
Phaser 3610 Support Drivers
Apr 09, 2014 | Xerox Office Equipment & Supplies
I need to know the value of the capacitors at C4 and C5 thank you
Hi there, im assuming you have the ARF 2001 scanning/transceiver.
I found your print and C4 is 1000 and C5 is 1000.
Example: capacitor 101, it is measuerd at micro (uf) and picofrads (pf) therefor this is calculated at 0.001 (uf), 1000 (pf).
The answer to your question is capacitor code for C4 & C5 is 1000.
0.0001 (uf) or 1000 (pf).
I hope this helps.
Feb 09, 2013 | Radio Communications
Printing C4 Envelopes on a CANON 2620N
try to use this linkhttp://www.canon.com.sg/section/contactus/?enqtype=TechEnq&enq_detail=Copiers
Aug 09, 2009 | Canon imageRUNNER C3200 Copier
Unable to print #10 envelopes on my Xerox WorkCentre 7675... I am using Microsoft Word and selecting the Bypass tray, but I'm still unable to print on these envelopes. Are there any other solutions?
Although you can lie to the 76XX series machine and get it to print on envelopes, the machine clearly shows that it does not take envelopes on the tray pictures. "Only C4 (229 x 324 mm / 9 x 12.7 in.) and C5 (102 x 229 mm / 4 x 8.7 in.) sized envelopes can be used with this printer; Number 10 envelopes are not supported. Attempting to use any other envelope sizes in this printer could result in jams. or damage to the printer. Do not use envelopes other than what is supported. "
Insert them Face up, flaps closed, leading edge to the right. When it asks, tell it envelopes, and give the size.
In the Envelopes section, under Mailings, Options, choose face up, and the 5th picture. It should work, but the envelopes sure get wrinkled.
Jul 31, 2009 | Xerox Office Equipment & Supplies
I cannot print C5 envelopes on HP C7280
In page setup manage custom paper sizes. Enter the size of the envelope and save it. In print dialogue box you can find the C5 envelop. Paper size: defined by driver. This should work
May 07, 2009 | Office Equipment & Supplies
Graininess on xerox dc12 print s
hi i think u took print in low resulution photo. pls check ur phot resulution.
Nov 21, 2008 | Xerox DocuColor 12 Printer
Paper Type and weigth Fot Lexmark C912
Media paper weight: is 20lb or 75gsm.
Media type: card stock, envelopes, Glossy paper, Paper Labels, Plain Paper, Transparent.
Media size: A3, A4, A5, Banner up to 11.69"x36", Executive, JIS-B4, JIS-B5, Ledger, Letter, legal, Super Tabloid, B5, C4, C5 DL, 7 3/4 9, 10 Envelopes.
demension is in inches, you need to convert it to centermeter.
Oct 30, 2008 | Lexmark C912 Led Printer
My dc12 don't print good. They print as shadow
If there is a shaddow on the printed documents, then it may be you drum needs replaced in the printer...
Hope this helps.....
Oct 28, 2008 | Xerox DocuColor 12 Printer
Xerox DocuColor 12 Color Copier Logo
1,331 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
