Question about Compaq Presario SR1120NX 2.66GHZ Tower w/ CD-RW (2018267632) PC Desktop
Sleep mode when i shut down or put computer in sleep mode,what do i do to restart the computer
  • 31 Answers
Depends how it is set-up. If it is just in standby then simply moving the mouse or pushing a key should work. If it is in hibernate, then you have to push the power button for it to power back on.
Posted on Jan 08, 2008
My Toshiba Satellite S75D-A7272 laptop has always had a problem with getting it out of sleep mode. Is there a fix for this?
Sleep or standby mode should allow your computer to conserve energy yet respond quickly to power back on when you need it. Most Toshiba laptops should exit sleep mode if you press a key on the keyboard or use the trackpad mouse. If the lid was closed, opening it should also wake up the computer. If none of these methods work to bring the computer out of sleep mode, you may have a power issue or software glitch. Causes Insufficient power can cause this problem, so try plugging in your Toshiba laptop before attempting to wake it from sleep mode. If this does not immediately fix the issue, your problem is more likely a software issue. If your laptop was shut down incorrectly prior to the sleep mode incident, it may be stuck on a blank screen that makes it appear to be in sleep mode when it actually is trying to start up.
Indications Press the power button for a few seconds to see if your computer will wake up. If it does, the laptop was not truly stuck in sleep mode, but rather went into hibernation mode. If your laptop is truly stuck in sleep mode, you may be able to force a shutdown by holding down the power button, but when you power back up it will move right back into sleep mode. In some cases, the power button may not shut down the computer from this mode at all.
Solution The best way to solve your Toshiba's problem is to completely remove all power from the laptop to ensure a fresh restart. Close the laptop's lid, turn over the unit and remove the battery. Also remove the power adapter cord from both the laptop and the wall socket. Open the laptop lid and press and hold the power button for approximately 20 seconds. This will drain any stored power in the backup battery. Wait a few seconds, then put the battery back in, plug in the laptop and press the power button to turn on the computer. It may start up with an error screen; in this case, select the option to start your computer normally. If the error recurs, start the computer in "Safe Mode" to see if a program running on your computer outside of the basic Windows operating system is causing the problem.
Further Help Sometimes this issue also requires holding down a specific key, such as "F8," when you restart. If the basic power drain and restart process doesn't work, you can use Toshiba's support website to look up further information for your specific model. Just click the "Product support" tab and enter your laptop's model information, then read through the support bulletins listed for your particular Toshiba model. Toshiba also maintains a support hotline at Call us : +1 850-610-1013 https://www.instantprintersupport.com/toshiba-printer-support
May 28, 2018 | Toshiba Computers & Internet
How to open hp laptop in sleep mode
This is a common problem on HP computers but also has many causes. If your laptop is not coming back on after being put into sleep mode, it could be a software issue among a few other things. If your computer has a hibernation mode I would suggest using it to get around the sleep mode issue. This mode will save everything the way it is and shut down completely. When you restart the computer it will open up just as you left it. Just like sleep mode except with a restart. This does not solve the sleep mode problem but easily provides a power saving alternative to it.
Jun 25, 2013 | HEWLETT-PACKARD HP Mini 5101 Netbook
Enable Hibernation in Windows 7 Starter on Samsung N150
Sleep mode on a Windows 7 PC saves power without you having to turn your computer off and without losing any work. This option cuts the power to your monitor, powers down the hard drive and pauses all functions until you awaken the computer from hibernation. Whether you have a laptop, desktop or workstation, putting your computer into sleep mode will lower your electric bill and save money! Click the "Start" button in the lower left corner of your desktop. In the lower right corner of the Start menu, next to the "Shut Down" button, is a button labeled with a small, right-pointing arrow. Mouse over the arrow. The Shut Down menu appears. Point at "Sleep" and click on this option. Your Windows 7 computer goes into sleep mode. Wake your computer from sleep mode by jiggling the mouse. There may be a delay of a few seconds before your hardware powers on. All of your open programs are still open and your work is intact, just as you left it before the computer entered sleep mode. Configure your Windows 7 PC to go into sleep mode automatically when it is not used for a certain amount of time. Click "Start" and select "Control Panel." Click "System and Security." Click "Power Options." A menu opens. Click on "Choose when the computer sleeps" and select the number of minutes of inactivity. You can also set a separate time interval to put your monitor into sleep mode. If you set both to 10 minutes, then your PC and monitor will automatically go into sleep mode after 10 minutes of inactivity Your Computer in sleep mode b> First, save all of your work. Information in computer memory is not saved while your computer is on standby. From the Start menu, select Settings, then Control Panel, then Power Management. Click Standby Beside When I Push the Power Button. Push the Power button. b> Automatically Putting Your Computer on Standby b> Save all work before leaving your computer. From the Start menu, select Settings, then Control Panel. Double-click Power Management. Set the times that you want your system to go on standby, to shut off the monitor and to shut off the hard disks. Click OK. Your computer will go on standby according to the schedule you have entered. b> Putting Your Computer in Hibernation b> From the Start menu, select Settings, then Control Panel. Double-click Power Settings. Click on the Advanced tab. At the When I Push the Power Button On My Computer screen, click Hibernate. Click the Power button. Hope this helps.
Jan 16, 2013 | Samsung N150 Series Netbook
Windows sleep mode problems
Dec 21, 2012 | Computers & Internet
Won't go into sleep mode
Which operating system ?
A menu opens.
Hope this helps.
Nov 25, 2012 | Dell Factory Refurbished 4700-HH79N81...
How to put my computer to sleep mode
I do not recommend sleep mode for windows because it eventually causes windows files to corrupt because of in proper shutdown, forcing you to do a full install of the operational system.
Mar 17, 2012 | Dell Latitude D830 Laptop Computer PC...
Computer will not start after going into sleep mode
Shut pc down unplug power supply press and hold power button for 20 seconds to remove all remaning power.open case clean any dust find ram sticks remove them make sure there clean and re seat them back into there slots.your monitor could be the cause also unhook it while pc is unplugged. now put it all back together and turn it on..if it doesnt shut it down un hook monitor and fire up pc see if the pc boots by watching the lights.if so bad monitor does light turn blue on monitor when power on.
Mar 16, 2012 | Computers & Internet
At times when I awaken the computer from sleep mode or hibernation, the screen gets all screwy with lines and blocks of grey. It returns to normal once I shut it down and start it up
control panel---->power options--->change plan setting---> Turn off the display-never Put the computer to sleep-never control panel---->power options--->change plan setting--->advanced power setting -set hard disk "turn off hard disk after" to never -set Sleep "Sleep after" to never -set hybrid sleep setting to off -set hibernate after setting to never Restart pc
Mar 25, 2010 | HP VM114UA notebook
Sleep vs Shut down
It depends on how long computer is being used in a day.
for general use
you can shutdown your computer once in 2 days but i highly recommend not to put in sleep mode and betting putting in hibernate mode instead of sleep mode.
note: most of simple issues are resolved by restarting PC so you can guess now how important is to shut down computer.
Good luck,
Mar 25, 2009 | Apple 24" iMac Desktop
Compaq Presario SR1120NX 2.66GHZ Tower w/ CD-RW (2018267632) PC Desktop Logo
135 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
