Question about ASUS P5RD1-V Motherboard
ASUS P5RD1-V MOTHERBOARD BOOT PROBLEM
ASUS P5RD1-V MOTHERBOARD FAILS TO BOOT. NO DISPLAY SOMETIMES. AND SOMETIMES IT SAYS CMOS CHECKSUM ERROR. REMOVED RAM AND CLEANED. ALSO REMOVED DUST.
  • raghutronics Nov 14, 2009
    reset the cmos too... no use
    changed the CMOS battery... still no use...
    Gets stuck at the initial ASUS splash screen. Doesnt respond to the keyboard also....
    Novelist:
    Champion:
  • 256 Answers
Booting issues might be caused by power supply problems. If you plug in some other power cord, the laptop might turn on. This may be because the supply of power from the wall socket is not proper as per the needs of your laptop, or the cable that you are using with the laptop is damaged or broken from inside. You may try by changing the power cord or using another wall socket to power your PC. This can prove to be of great help most of the times.
Posted on Aug 12, 2011
    President:
  • 2,976 Answers
It sounds like you have a dead battery on your motherboard.  Just replace it and your settings will remain.
Posted on Nov 14, 2009
I can't boot from sata CDs with my motherboard asus p5rd1
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS
after you make any changes in BIOS press Esc then press the F10 button save to cmos to restart
cmos is located in BIOS
http://majorgeeks.com/ASUS_Update_Utility__d4435.html
ASUS recovery
hope this helps you
Aug 03, 2011 | ASUS P5RD1-VM Motherboard
P5RD1-V BOOT PROBLEM
The CMOS, which stands for complementary metal-oxide semiconductor, is the hardware component of a computer that supports the BIOS, or basic input output system. The two terms are often used interchangeably, and the two technologies work together to perform the same basic function. They maintain the low-level settings on a computer, letting the computer know, even before the computer's operating system starts, what kinds of hardware the computer has available, such as hard drives and video display adapters. A special battery located on the computer's motherboard powers the CMOS. To reset the CMOS on a Dell computer, briefly remove and then replace the battery
  1. Turn off the computer. Disconnect all cables and detach all devices, including USB devices, from the computer. Press and hold the computer's power button for 10 seconds after it has been unplugged. This grounds the system board.
  2. Step 2 Remove the computer cover. All Dell systems have a cover panel on the chassis that you can remove so that you can access the system's motherboard and internal components. For some Dell computer lines, such as OptiPlex, the computer cover is held in place by a release latch located on the back of the computer. Pull the latch to release the cover and then slide the over up and away. Other lines, such as Dimension, have large, slotted thumbscrews. Turn the screws counter-clockwise until they disengage from the chassis, the slide the cover off the computer. Dell computers often ship with the computer's user guide in CD form or with the guide pre-loaded on the system's hard drive. You can locate the instructions for removing the cover from your particular system in the user guide.
  3. Step 3 Locate the CMOS battery on the system's motherboard. CMOS batteries range in size from size and thickness from about the size of a nickel to about the size of a quarter. The CMOS battery will generally be labeled CMOS on the motherboard and will be the only battery openly exposed on the motherboard.
  4. Step 4 Remove the CMOS battery by prying it gently up out of its socket. The sockets are specifically designed to allow the battery to be replaced.
  5. Step 5 Wait 30 seconds, and then replace the battery in its socket. This will reset the CMOS. Replace the computer cover to complete the process.
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
Nov 14, 2009 | ASUS P5RD1-V Motherboard
ASUS P5RD1-V FAILS TO BOOT
Pls check with USB key-board
I hope that this has been very helpful for you
CMOS checksum error
Can you leave a better description of the problem?, are you getting 'cmos checksum error' msg when you startup? If so, this is normal after removing the CMOS battery and replacing, it should only display error msg after 1st start then no more...
Dec 30, 2008 | ASUS A8N5X Motherboard
Checksum error
Hi robynonis
Yes, definatly the cmos battery. Please make sure you replace with same type battery.
Regards Go-Tech
Dec 22, 2008 | ASUS P4PE Motherboard
Cmos Chechsum bad
your CMOS battery needs to be changed..u can find it on motherboard...
Dec 12, 2008 | ASUS GREEN MODEL N6200/TD/128M - GRAPHICS...
CMOS checksum error
rahul23petit
"CMOS" checksum error default loaded" means ur mother board cmos battery fail (which is locate at mother board), to solve this problem replace it by new one (u can buy it form any computer accessories shop). all oher problem happen for it.
Jul 06, 2008 | EliteGroup BKi810 Motherboard
Cmos checksum error
cmos checksum errors are caused by a bad battery.
If that dont work then the board is bad from the factory.
Dec 24, 2007 | ASUS A8V-VM Motherboard
Bad BIOS checksum.... CMOS bad checksum errors
BOOT BLOCK COMPATIBLE VERSION VER .005
BAD BIOS CHECKSUM
CHECKING FOR CD ROM
READING FILE "P5SD2VM.ROM"
NO CD-ROM FOUND
CHECKING FOR FLOPPY DISK
NO FLOPPY DISK FOUND
Does someone already fix this problem??????
Nov 15, 2007 | ASUS M2N-MX Motherboard
ASUS P5RD1-V Motherboard Logo
235 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
