Question about Maytag Neptune MDE5500AY Electric Dryer
Loud squealing noise
I began taking my dryer apart and now all i have accomplished is removing the sdrews. how do i get the top of this dryer to pop loose
  • Anonymous Jan 08, 2008
    How do you pry the top of the dryer open?
After i take off the front panel, how do i get to the rollers?
Posted on Sep 19, 2008
    Sergeant:
    Champion:
  • 262 Answers
On the maytag you need a putty knife use the knife and slide it across the top slit on the front you will fell it stop pull the knife out and push in on on that spot do the same thing on the other side and wala the top will swing up
Posted on Jan 08, 2008
6ya staff
SOURCE:
Is it dangerous to run a dryer that needs the rear bearing replaced? My dryer just began making the noise tonight. When I started it there was a loud pop then a grinding noise. However, when I removed...
Not dangerous, per se, but if the rear bearing has failed, instead just replacing the bearing sleeve you may have to replace the drum if it wears too much. You have metal and metal contact.
Whilst you have the dryer in bits, replace the front drum slides as well as they will be the next to go.
Dec 06, 2017 | Hotpoint NVLR333EE Dryer
Frigidaire Dryer GLER642AS3 loud squeaking. Squeaking sound probably coming from drum rotation bearing. Is there an easy way to get in to oil that location to stop squeaking noise? Thanks!
yes but you will have to take the front of the dryer apart and pull out the drum/tub. to do this you must open the dryer door and look up for two screws, remove them. next close the door and using a flat head screw driver, pop the dryer lid/top up (be careful not to bend apart the two green snaps that are holding it tight on each side). now using a phillip head screwdriver in each inside corner you need to unscrew the screw. now lift up and out slowly to remove the front of the dryer ( unplug the dryer door wires before removing front completely). now you must pull the tub straight out (you might need to reach in and take the belt loose first). Now you are where you need to be.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/charles_c2f37a3461344482
Jul 16, 2011 | Dryers
Really loud whirring/squealing noise
Yes, It is still safe but very annoying...
The source is probably the guide rollers for the drum or the belt tensioner pulley. To know for sure you will need to pull the dryer apart and turn it by hand slowly and see where the noise is coming from...
Heatman101
Mar 03, 2010 | Whirlpool Dryers
Maytag electic dryer noise
First, pop up the top of the dryer -- use a large slotted screwdriver under each corner of the top. There will be screws holding the front of the dryer -- take these out and take the front off. The squealing is coming from roller bushings which need lubricating. Apply machine oil to all the axles/bushings -- this most likely will stop the squealing -- and don't forget to unplug it first.
Apr 23, 2009 | Maytag Dryers
Noisy dryer......when engaged...making squeaking/squealing noise.
If the noise is like a shaking of rattling , like coins being shaked , then it is an object trapped inside the drum.
If instead the noise is a loud grinding , that may get louder on high speed, then it is usually a bad drum bearing.
If dryer is not cooling, check that the noise is not coming from the ventilation fan.
Rollers and belt tensioner can also make noise.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Apr 09, 2009 | GE Spacemaker Washer and Dryer Electric...
Craftsman Tiller makes loud, shrill, squealing noise when tilling
Noise comes and goes sound like metal on metal not a belt squealing
Apr 03, 2009 | Craftsman Garden
THE DRYER STARTED MAKING A SQUEALING NOISE AND THEN IT STOPPED AND WOULD START AGAIN AND SOMETIMES IT WOULDN'T MAKE A NOISE BUT NOW IT'S SO LOUD THAT YOU CAN'T STAND TO HAVE IT ON.
you may have to take it apart and check two things...
1. the motor on dryers can get pluged with dust and lint and dry out. the motor bearings may simply be dry. it might be too late for the motor, but you could try lubing the motor bearings and at least stop the squeal for a while.
2. remove the drum and lubricate the wheels or bearings that the drum rides on.
lubricate all rollers and belt guides as well.
hope this helps..........jay
Mar 21, 2009 | GE DBSR453EBWW Electric Dryer
I have a Maytag Dryer MDE9806AYW Intelli Dry SQUEALS
Yes its worth repairing, it sounds like a simple fix, could be pulley, or seal replacement but for the price of some machine oil, or part, well worth it. The intelli dry pulls apart from front, with the door and top is hinged. A little time consumeing but I think still worth it.
Feb 04, 2009 | GE DBSR453EBWW Electric Dryer
Continuous Squealing
take the dryer apart and oil the drum support rollers and the idler pulley. If this does not fix it. Replace the support rollers and the idler pulley. To acces the rollers, take the 2 screws out under the lint filter and then raise the top of the dryer. then remove the 2 screws holding on the front. Take the front off and remove the drum and theres the rollers and the idler pulley. (taking apart the dryer applies to a whirlpool, kenmore, roper, kitchenaid, estate.) If you have another brand let me know i will tell you how to take it apart. (if oiling doesnt fix it your local parts store should have all the parts needed in stock.)
Nov 15, 2008 | Whirlpool LER4634J Electric Dryer
Frigidaire LEQ332DSO Squealing Noise
sounds like rear bearing is dry you will need to remove drum to get to it pop clips in top and raise 2 phillips scews 1 in each side remove front remove belt from drum lift drum up in rear and remove ck to make sure plastic bearing is not worn down to metal bracket if it is it will need to be replaced
Jul 07, 2008 | Frigidaire GLER341A Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
90 people viewed this question
Top Maytag Dryers Experts
Marvin
Marvin
Archie Ferrarini
Archie Ferrarini
Gerry Harvey
Gerry Harvey
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
