Question about Acer Aspire 4315 Notebook
I know it's disconnected but cannot work out how to turn it on again.
    Sergeant:
  • 267 Answers
Ok i need you to be more pesific. are you say you dont know how to turn the unit on? or are you say you cant get it to reconnect to the network?
Posted on Nov 14, 2009
My router disconnect frequently
Question: the connection to router disconnects OR the internet disconnects,
If router disconnect: then try being in range, choose a better spot, keep router in a good spot,
If internet disconnects, cal ISP get it checked, make sure you run ping test to make sure its consistent , here is an example,
E.g:
open run: type cmd, hit enter,
type : ping google.com -t
hit enter, it should give regular pings without timeouts....if too many timeouts, internet service has issues,
call them and report..
Nov 29, 2013 | TP-LINK 300Mbps Wireless N ADSL2+ Modem...
Battery disconnect switch not turning on & off properly
i am a tech at a ford dealership. it sounds like you have a short some wheres around your steering column that maybe what we call "backfeeding" to other systems. the area where the tilt is on the steering column is a good place to check. also remote starters can cause alot of havoc on a vehicle.
Oct 21, 2012 | Cars & Trucks
I just purchased a used 2006 Honda accord. The radio/clock does not come on. The dealer had someone to disconnect the battery and then reconnect it. After that, the radio came on. We turned the car off...
Not familiar with your vehicles systems,but it sounds
like a retained accessory relay, and the dealer surely
knows what it is.
You don't keep disconnecting the battery to diagnose that.
Go to a competant repair shop close to home
Jan 27, 2011 | 2006 Honda Accord
My receiver turns on but no sound comes out. I know for a fact nothing is wrong with any other component.
Check the audio connection from unit to the system speaker, try to disconnect and reconnect it again, make sure that you remember all the connections before disconnecting it. Try also to use other audio wire available.
Let me know and advised me here again for any development.
micro~
Feb 23, 2010 | Sony STR-DE595 5-Channel Amplifier
1 day afte I switch from Comcast to AT&T, I can't turn on TV. Why
Might it ur tv have prob.Disconnect the tv comming in signal,see any stactic in the tv screen?
Sep 28, 2009 | Mitsubishi WD-65733 65" HDTV
Hp photosmart c5180 ink system failure
Hi ok then try I found this I know your error not in here but it may work for It worth a try nothing to lose and it may work. I know your error code is not in this but it some times it clean the error with this type of error number you can gave it a go try not harm it Error code: 0xc18a0201, 0xc18a0206, 0xc18a0306, 0xc18a030a, 0xd0620130, 0x887dd03a, 0xd05d010d, 0xf0af8004, 0xc19ac3ff, 0xc18a050...
Reset the product:
1. Without turning off the product, disconnect the USB cable from the rear of the product.
2. Remove the cartridges from the product.
3. Wait for the 'Insert Cartridges ' message to display on the control panel.
4. Disconnect the power cord from the back of the product.
5. Wait 60 seconds.
6. Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
7. Reinsert the cartridges, and then close any open doors on the product.
8. If you receive a prompt to print a calibration page, do so.
9. Reconnect the USB cable to the rear of the product, and then try printing again.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Apr 20, 2009 | HP Photosmart C5180 All-In-One InkJet...
Sansa 1g clip wont turn on.
did you try holding the power button on for ten seconds (the reset) after trying to charge it again? does it even power up when you plug it into the usb. if it powers on when connected to the usb and then shuts off immediately when you take it off the usb (rather than "refreshing database") then your battery is either 1)disconnected inside 2)dead or there may be issues with power management. Same thing happened to me (disconnected) but I soldered the loose connection and it only worked for two days, even checking the connections again. Now I don't know what's going on. It's more likely the battery has reached the end of its life.
Nov 16, 2008 | SanDisk Sansa Clip MP3 Player
MTP Mode Doesnt Work
Try uninstalling MTP Mode in the Windows Device Manager, and replugging the player - set the menu setting in the Sansa itself to "auto" for USB Mode before replugging. Let me know how it works.
Jun 13, 2008 | SanDisk Sansa e260 MP3 Player
Gogear
Battery is too low for player to charge. There is a firmware fix for this at www.p4c.philips.com
Fix cannot be applied until player is working again.
If you know someone who has the same player, put their battery in your unit to power up and apply firmware update to fix problem. Then swap batteries back again
Another way to get the player working is to remove the side panel to disconnect battery. Plug in the mains charger and reconnect the battery. You may need to do this several times before the player springs into life.
If this doesn't work try disconnecting the charger and battery alternately and wait 5 secs between attempts.
Feb 21, 2008 | Philips GoGear HDD075/17 MP3 Player
Acer Aspire 4315 Notebook Logo
24 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
