Question about Nokia 6500 Slide Cellular Phone
My nokia 6500i working good in charging mode but when i remove charger it not working .phone get restart n screeb get white n phone switch off after 2 3 sec. plz tell me what can i do???????????
    Sergeant:
  • 297 Answers
Replace ur battery
Posted on Nov 14, 2009
Hi my Nokia 6121c has a white screeb problem. when i turn it ON it comes up with a white screen for a few seconds and then switches off. can you please help me. Thanks.
Hi, it is the software that has crashed and requires a full software reimage. The LCD ribbon cable must be replaced. You will need to take it to the repairers who can connect to computer and reload fresh image.
The cheapest place would be one of those small independent phone shops as the bigger one will have to send it off and you will be charged extra for this, the smaller phone shop should be able to fix it while you wait or the next day at the latest. GoodLuck=)
Aug 01, 2011 | Nokia 6121 Classic Cellular Phone
I restarted my cellphone the Nokia sign is shown and the two hands, aftre that, iw ill setup the date, the keypad does not work. what can i do?
this problem due to virus problem. Remove memory card. And connect charger and switch on when charging phone . And if you have n series phone press pencil key while switching on
May 04, 2011 | Cell Phones
1100 nokia model charging problem when i put charger into the charging ject charger lite off and batry not charging
First you need to understand that this might have been caused by either the phone or the charger.
To test if it is the charger, test it with another phone to see if it will work, if it does not, then it means the charger is faulty and needs to be replaced.
But if the charger works, then it means the chasrging port of your phone is faulty. To replace it is quite simple, remove the battery cover, the battery and the sim card.
Unkey the hook that are by the two lower end of the phone, they are black and connecting the front cover to the back, then you run a flat object like a credit card or knife around the edge and pull it up from the bottom, the front cover will be easy to pull out now, then you should have some 6 screws around the phone, 2 on top, 2 in the middle and 2 by the lower end, once you remove the screws, you will be able to remove the screen, it is attached to the metal try that protects the keypad. From there, you will be able to also remove the white board, and assess the charging port and replace it with a new one.
After doing this, your phone shoud be in good condittion once again.
Also try out your battery in another phone to ensure the battery is not the problem.
Take care and have a lovely day.
Good luck
Oct 25, 2010 | Nokia 1100
Sonim xpi jcb toughphone,the phone won't switch on,but when the battery is removed and replaced the phone comes on.However none of the buttons pressed gets a response,can,t enter pin and it won,t turn...
Remove battery,attach and switch on charger,for about 10mins or until charge mode displays,should flash.Insert battery, donot disconnect charger,leave for 2 hours,disconnect charger ,phone should switch on.
Jan 24, 2010 | Sendo Sonim XP1 JCB phone extreme...
How can i fix my nokia 6500i?
there are lot of possible problems... firstly try by formating your phone using this code...
*#7370# if still facing the same problem... then you may go to the Nokia service centre..and ask them to re install software....
Oct 06, 2009 | Nokia 5800 XpressMusic Smartphone
Unlocked Nokia 5310 doesn't turn on. I just gave up my iPhone (got a blackberry from work) and started using this phone again. Worked fine the first day; the next morning I noticed the battery was dead. It...
Maybe its your battery or charger port.Try to use another battery, if did'nt work then it's charger port.To avoid this kind of error please do not overcharged your phone.
Aug 02, 2009 | Nokia 5310 Cellular Phone
NOKIA 5310 can't turn on
Did you replace battery recently? Sounds like it has bad or wrong battery. If not, it is just dead.
To fix:
Power up phone on charger
While it is ON, pull the battery
Leave out for 1/2 to 3hr - phone still plugged in
Replace Battery, phone will power cycle and start charging
Leave plugged into charger 10-14hrs
Should be good now
Mar 26, 2009 | Nokia 6500 Slide Cellular Phone
Nokia 6131 wont switch on
the phone need to be flashed take it to agsm service store and tell them to read the user area for reaching ur cantacts okay ??
rate me
Aug 10, 2008 | Nokia 6131 Cellular Phone
Phone stuck in Test Mode
my did that when i plugged the charger in while the phone was off. i yanked the battery, went to the bathroom, came back and put the battery back in, and i was good.
Dec 15, 2007 | Cell Phones
Nokia 6500 Slide Cellular Phone Logo
145 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
