My 2000 cavalier has a heasation problem while
My 2000 cavalier has a hesitation problem while driving at around 3000 rpm's and higher it is a five speed it cut's in & out like a fuel problem i put new parts on it like new fuel pump,fuel fuel filter,fuel pressure regulator,spark plugs and wires,throttle position sensor can any 1 help
  • minear2 Nov 14, 2009
    But its not throwing a code it acts like its starving for fuel i have a code reader with live data and the o2 is working we have had this car 2 years and no problems my farther in law owned it since it was new and he had no problems either.
  • 1,056 Answers
Refer to a wiring diagram. Look to see anything that is connected in series with one of the TPS wiring. Then check if they are open or has a bad connection. It could be a map sensor, or something.
Posted on Nov 14, 2009
  • Ronado Panaligan
    Ronado Panaligan Nov 14, 2009
    Even if it doesnt have a code. I have experienced this same problem where you rev up the motor, and it will not go past 3000RPM. It is as tho the car had a governor that keeps it from going past 3000RPM. In fact this is the only possibility that could make a car act that way without throwing a code. The TPS sensor has three wires to it. There is one single sensor that is connected to one of its pin. Check the connection to that. Let me know what that sensor is, and we may be able to get solve the problem.
Sounds like an o2 sensor to me
2002 jaguar xj8 when I drive it won't go over 3000rpm
Jaguar wont rev 3000 rpm Questions & Answers - Fixya
www.fixya.com > Forum > Tags > wont rev 3000 rpm
1998 Jaguar XJ8 won't rev over 3000 rpm ... Wont go beyong 3000 Revs s type 2001, wont go beyond 3000 Revs and it' in limp ... Question about 2002 X-Type ... My jaguar xjr8 year 2000 battery went dead started car went for short drive back ...
Jaguar engine cuts 3000 rpm Questions & Answers - Fixya
www.fixya.com > Forum > Tags > engine cuts 3000 rpm
1998 Jaguar XJ8 won't rev over 3000 rpm ... engine cuts out and shudders at 3000 rpm won't accelerateobd code p0332 2002 jaguar x type 3.0 l P0332 - Knock ... Car is boging out in park and will not go over ... driving, don't worry about it.
Rev Won't go up
www.jaguarforum.com/showthread.php?t=14662
Dec 15, 2015 | Jaguar Cars & Trucks
Driving on the road the RPM goes higher wituout speedind
Check out related help links to troubleshoot these problem:----Click the link below:---Idles Fine but RPM jumps in drive mode?http://technoanswers.blogspot.in/2012/07/idles-fine-but-rpm-jumps-in-drive-mode.html
---------Mitsubishi Lancer rpm needle bounces?http://technoanswers.blogspot.in/2012/02/mitsubishi-lancer-rpm-needle-bounces.html
--------How to adjust rpm on 2009 dodge charger SRT8?
http://schematicsdiagram.blogspot.com/2011/12/how-to-adjust-rpm-on-2009-dodge-charger.html
Engine cuts out at 3000 RPM?http://schematicsdiagram.blogspot.com/2011/12/engine-cuts-out-at-3000-rpm.html
Cold start problem and vehicle shudder around 2500 to 3500 rpms
http://repairhelpcenter.blogspot.com/2012/10/cold-start-problem-and-vehicle-shudder.html
High rpm in neutral? Inconsistant high RPM in neutral?http://technoanswers.blogspot.in/2012/02/high-rpm-in-neutral-inconsistant-high.html
Jetski Sputters and Low RPM? http://whatisbyme.blogspot.in/2012/07/jetski-sputters-and-low-rpm.html
Fuel Injection Problem And RPM suddenly increaseshttp://whatisbyme.blogspot.in/2012/07/fuel-injection-problem-and-rpm-suddenly.html
2005 Toyota Highlander: Engine runs hard RPM below 3000?http://whatisbyme.blogspot.in/2012/05/2005-toyota-highlander-engine-runs-hard.html
1987 Toyota Camry: RPM Drops going Up hills?http://whatisbyme.blogspot.in/2012/05/1987-toyota-camry-rpm-drops-going-up.html
Cruise Control stops working, Excessive cranks to start the engine and RPM goes max 2500 http://whoisbyme.blogspot.in/2012/07/cruise-control-stops-workingexcessive.html
1990 Toyota 4Runner: Engine cuts off when reaches 2000 RPM?
http://whatisbyme.blogspot.in/2012/05/1990-toyota-4runner-engine-cuts-off.html
1999 Toyota Camry: Erratic stalling and high engine RPM at idle?
http://whatisbyme.blogspot.in/2012/05/1999-toyota-camry-erratic-stalling-and.html
1995 Toyota LS: Misfire at idle or low RPMhttp://whatisbyme.blogspot.in/2012/04/1995-toyota-ls-misfire-at-idle-or-low.html
Lexus RX: Tapping noise under Valve Cover At Low RPM?http://technoanswers.blogspot.in/2012/04/lexus-rx-tapping-noise-under-valve.html
These will help.
Thanks.
Nov 22, 2012 | 2008 Toyota Avalon
2001 sunfire will bog after giving it gas and stay around 2000 and 3000 rpm no higher in park, and its making a funny noise like its not getting enough gas and sucking in to much air, when its in drive it...
Have your fuel pressure and volumn checked, nd if ok, have the exhaust checked for restriction(usually clogged converter) If converter is bad, have engine performance anylized,as there is a reason it clogged. Don't overlook coolant getting in the combustion chambers.
Oct 22, 2011 | 2001 Pontiac Sunfire
My 2004 Odyssey at 1000 to 1500 rpm will growl and the tach will fluctuate quickly. If we raise the rpm at higher speeds it does not happen. Local dealer cannot resolve the issue...its driving us...
Try replacing TPS (Throttle Positioning Switch) These are basically a rheostat and after time they develop a wear/hot spot - usually right around highway cruising position. When they develop a hot spot you get hesitations and RPM fluctuations
Feb 24, 2011 | 2005 Honda Odyssey
The RPM of Nissan Altima stays high when drive over 65 MPH.
No....the rpms differ from engine to engine and from manufacturer to manufacturer. RPM's are always higher at higher speeds.
Aug 25, 2009 | 2002 Nissan Altima
Computers & Internet Logo
184 people viewed this question
David Payne
David Payne
